Unable to adjust e brake
Discussion in '1st Gen. Tacomas (1995-2004)' started by HeadlampRevamp, Apr 11, 2010.
  1. Apr 11, 2010 at 8:01 PM
    HeadlampRevamp
    HeadlampRevamp [OP] Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    So my ebrake is pretty much non existent. I looked up a DIY on adjusting it. So I got up under the truck, and noticed that the bolt that you adjust to tighten the ebrake can't be moved any futher because its in its "tightest" position so to speak. I don't know how else to word it.
    Is there another adjustment I can make so that my ebrake actually works?
  2. Apr 11, 2010 at 8:04 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    Wish I could help but i cant even find the DIY. Could u send the link?
  3. Apr 11, 2010 at 8:11 PM
    shift96
    shift96 Well-Known Member
    I have found that whenever my E-Brake was like you described it meant my back brakes were out of adjustment. I get under the truck and adjust the back brakes manually and it tightens up the ebrake and gives you a real nice pedal feel again
  4. Apr 11, 2010 at 8:24 PM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    http://www.lieblweb.com/ebrakeadjustment.html
    That's the DIY I used, its for a different year, but appears to be the same setup.
    Is there a DIY for this?
  5. Apr 11, 2010 at 8:42 PM
    shift96
    Not sure but it is really easy to do. You need to jack up the truck so both back wheels are off the ground (make sure to chock the fronts just for safety) and on the back of the drums is a little oval rubber plug. Pop it out and the brake adjuster is in there. Get yourself a brake adjusting tool from the autoparts store, it makes it much easier. You'll be able to hear the adjuster click as you adjust. The goal is to have a very slight drag on the wheel. Make sure to do both sides.
  6. Apr 12, 2010 at 5:24 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Thanks man. Its pretty rusty back there, hopefully none of the components have seized.
  7. Apr 12, 2010 at 5:35 AM
    98tacoma27
    Ben
    Not Beech Creek
  8. Apr 12, 2010 at 6:18 AM
    Jap
    Jap Loving this
    TRD supercharger, extractors, 7 psi pulley, Interceptor ECU
    wtf...where did 'e-'brake' come from?
    I thought they were a handbrake??
  9. Apr 12, 2010 at 6:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    Actually, it's a parking brake.
  10. Apr 12, 2010 at 6:56 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Call it what you will, ebrake, emergency brake, parking brake....
  11. Apr 12, 2010 at 8:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How are your shoes? do they need changed?
    Usually, when things are that outta whack in terms of adjustment, the shoes need changed. Check the shoes.....
    Like shift96 mentioned, there's a star wheel inside the drum that also adjusts the shoes. Move the star wheel and use your hands to rotate the drum. Keep adjusting until you get slight drag on the drum as you manually try to rotate it.
    Once you do that - you need to RE-adjust the ebrake again.
    If the star wheel doesn't move, then you'll have to take the drum off and check to make sure there's no dirt in there. Or, if the adjuster assembly is seized, it'll need replaced.
  12. Apr 12, 2010 at 8:51 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Parking brake levers are seized...
  13. Apr 12, 2010 at 9:06 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I'm going to start with the star wheel and see if that helps. Easiest thing first. However the shoes might be bad as my rotors are tad bit warped. I hear this happens if your drums are bad because it puts more pressure on the front brakes.
  14. Apr 12, 2010 at 9:07 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    As far as I know, none of the compents are seized unless its inside the actual drum. Looking under the truck while having someone else pull the brake, everything seems to be moving just fine.
  15. Apr 12, 2010 at 9:12 AM
    Janster
    Jandy
    Lancaster, PA
    The braking system acts the same in terms of hydaulic pressure.
    If your rear drum brakes aren't working properly, the truck isn't slowing down as fast as it should and you're applying the brakes harder to make up for it. Which - could indeed put more pressure on your fronts.....
    Good Luck & keep us posted!
