Unable to Remove Top Rear Shock Nut
Discussion in 'Suspension' started by crhsharks12, Nov 2, 2020.
  1. Nov 2, 2020 at 6:10 PM
    crhsharks12
    crhsharks12 [OP] Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    It’s sort of not supposed to happen. It’s not a big deal if it does haha. yeah see for me vice grips did nothing. I might just grind it off ya
    Get that nut at Home depot or some shit
  2. Nov 2, 2020 at 6:12 PM
    crhsharks12
    Denver, CO
    I had this installed at a shop originally (5 years ago). It was installed correctly ‍♂️
    I don’t like how the rear shocks are done either on tacomas tbh
  3. Nov 2, 2020 at 6:14 PM
    crhsharks12
    Denver, CO
    oh shoot for that cheap? Damn
    Hmmm
    I think rather than even cutting the whole stem I’m just gonna try and salvage that and just cut The bolt barely
  4. Nov 2, 2020 at 6:15 PM
    crhsharks12
    Denver, CO
    Explain the threading a nut onto the bottom?I’m not following
  5. Nov 2, 2020 at 6:17 PM
    crhsharks12
    Denver, CO
    I tried it for 1.5 hours.......
  6. Nov 2, 2020 at 6:18 PM
    crhsharks12
    Denver, CO
    Yep, i got it pretty hot. Did you read the thing? Hahaha
    It was a heat gun not a torch, but same shit in the end
  7. Nov 2, 2020 at 6:18 PM
    crhsharks12
    Denver, CO
    In the shock body was where the lock tight was
    It was placed by icon! it was red.
  8. Nov 2, 2020 at 6:20 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Gas axe, cutting wheel on a grinder, metal blade on sawzall.
    Done in less than 5 minutes.
    If using a grinder, be sure to wear safety glasses and gloves. This is an awkward place, easy to shatter a wheel. Flying cutting wheel shards are wicked beyond belief. 4 1/2" grinders spin the wheel at 10,000 rpm.
    crhsharks12[OP] likes this.
  9. Nov 2, 2020 at 6:20 PM
    crhsharks12
    Denver, CO
    What in the fuck is that? Lmao
  10. Nov 2, 2020 at 6:20 PM
    gearcruncher
    Canadain bumper technician
    Get the nutt cherry red and it will come off with no issues and an added bonus , you can use the same nutt again . Its only the rust you are fighting
  11. Nov 2, 2020 at 6:20 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Usually people try penetrating lube/PB blaster for a couple days before starting the work - let it soak in. Id also try some map gas on the threads to heat things up. Or you could find someone stronger than you to help?
    Worse case scenario, you cut it off, and buy a new threaded piece from Icon.
  12. Nov 2, 2020 at 6:21 PM
    summithightacoma22
    summithightacoma22 Well-Known Member
    michael
    denver
    2013 grey tacoma trd sport
    front +2 allpro long travel with kings. Marlin crawler lca reinforcements, alpine design cab mount. All pro spindle and upper control arm reinforcements. Willwood 6 piston front calipers and 2 piece rotors. rear 7 pack expedition soa, 12 2.5s, archive garage shock relocation kit. Archive garage shackle flip kit. wheels 285/75/17 geolander g0003 on 17x9 with a zero offset. engine bay. antigravity atx hd-20 lithium battery arb high capacity air compressor. 3* exhaust cam timing. intake spacer custom stuff custom made sliders, custom bed rack system, custom drawer and bed system, modified mounts for arawak awning. Fiberglass/lexan cap door. Boxed out frame in spots I could reach. soon to be a chopped bed at the rear axle interior -lathewerks co polymer stainless shift knob, modified from a wrx to fit. -pioneer mid and treble speaker replacement. -future mods -4.56 gears arb front and rear lockers -traction bar for the rear. -full carbon front clip. -supercharger eventually.
    There's a little bit of threaded rod sticking out the bottom yes? If u r particularly concerned with not destroying that part try finding out the thread pattern of that rod, and putting a nut on the bottom to get more leverage of a 6side than a 2. But also heat that bitch, metal contracts and expands and if u have any locktite in that nut up top it should melt it out.
  13. Nov 2, 2020 at 6:22 PM
    gearcruncher
    I see I am waisting my time here .
    Have fun
  14. Nov 2, 2020 at 6:23 PM
    crhsharks12
    Denver, CO
    FAir. I’ll try doing it for a couple of days, and then I’ll try to heat it up even more with a torch. If that dont work, Then, cutting it is haha
    although cutting seems nice, quick, and easy. Very appealing:D
  15. Nov 2, 2020 at 6:23 PM
    #35
    fatfurious2
    David
    Ashburn, VA
    and/or plastic of a locnut
  16. Nov 2, 2020 at 6:24 PM
    #36
    crhsharks12
    Denver, CO
    Ahh ah, I see. That’s a good idea actually. I’m gonna try that haha
  17. Nov 2, 2020 at 6:25 PM
    #37
    fatfurious2
    David
    Ashburn, VA
    I always try manual first. Sometimes with cutting you could miss, and mess up something else.. Get a friend, or a long tube to go over your wrench, or both.
  18. Nov 2, 2020 at 6:30 PM
    #38
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    I just had a thought, that maybe it's reverse threaded, and dozens and dozens of taco owners have been resorting to cut off wheels and torches when all they had to do was turn the wrench the other way.
    Gave myself a good chuckle out of that.
  19. Nov 2, 2020 at 6:32 PM
    #39
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Magnetic Inductive heater on the top nut, heat it red hot and it'll turn right off.
  20. Nov 2, 2020 at 6:38 PM
    #40
    Knute
    Another method to try. Shock or Impact.
    Use something to lock the bottom (where the icon shock was).
    Box end wrench on the top nut.
    Place a piece of black pipe over the box end wrench
    Apply torque to loosen the nut while holding the black pipe (cheater piece).
    Strike the box end wrench near the end away from the nut with a 3 lb blacksmith hammer. You want to hit the black pipe at the joint with the box end wrench.
    Note: Apply as much torque as you can. The hammer strike will have a tendency to rebound the cheater piece.
