Unbelievable service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myth01, Oct 20, 2011.
  1. Oct 20, 2011 at 10:05 PM
    myth01
    myth01 [OP] Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    So I got a 20.00 oil change coupon for my local dealer. So when ever I change my oil I rotate my tires. So I figured let them do it. So get my truck back and it shimmied at 40-65mph. So I took it back and said something was up. They supposedly rebalanced the front tires. So the issue was still there. Took it back today to have them rerotate the tires back. Well,with road test shimmy was stil there WTF could they have done!!!
  2. Oct 20, 2011 at 10:06 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Loose lugs
  3. Oct 20, 2011 at 10:07 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    Nope checked them yesterday
  4. Oct 20, 2011 at 10:15 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Are the wheels seated on the hubs correctly?
    Can you see where they removed the weights?
  5. Oct 20, 2011 at 10:27 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    That would be the ultImate solution
  6. Oct 20, 2011 at 10:56 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    x3
  7. Oct 20, 2011 at 11:04 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    Ya they said they wanted their master tech to do the balancing
  8. Oct 21, 2011 at 6:33 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    Wheel balancing machines are so easy to operate they shouldn't need a master tech.
    Put wheel on machine.
    Machine spins wheel.
    Machine says where and how much weight to apply.
    Apply weight as instructed.
    Retest.
    Done.
    Go to a different dealer and/or call Toyota care and piss and moan.
    The 2 dealerships I go to here in Portland are exceptional and I have had no issues.
    1 even detailed my entire truck for free. I was very surprised, but I did have a lot of work done.
  9. Oct 21, 2011 at 6:37 AM
    saugus
    saugus Well-Known Member
    I think you may have lost a weight when they pulled your tires.
  10. Oct 21, 2011 at 7:10 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Welcome to the shimmy club! I finally got rid of my shimmy after dealer road force balanced my tires 4 times, rotated tires around vehicle several times, realigned front wheels to the leaf spring TSB specs & lowered my tire pressures to 32 psi from 35 psi. Only took 3 1/2 years to get rid of the shimmy above 45 mph.
  11. Oct 21, 2011 at 7:12 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    a master tech to do a tire balance?? lol
