uncaping the engine oil cap what are you suppose to see?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sergio1531, Oct 11, 2013.
  1. Oct 11, 2013 at 10:02 PM
    sergio1531
    sergio1531 [OP] Well-Known Member
    Zombie1531
    Las Vegas Nevada
    05 PreRunner SR5
    Painted Rims, and Grill
    When you uncap the engine oil cap on an 05 Tacoma are you seeing oil? What engine oil are you suppose to use? How many quarts?
  2. Oct 11, 2013 at 10:04 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    I hope you see some evidence of oil.
  3. Oct 11, 2013 at 10:07 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Generally there's oil under the oil cap. Sometimes even shiney things!
  4. Oct 11, 2013 at 10:13 PM
    sergio1531
    Zombie1531
    Las Vegas Nevada
    05 PreRunner SR5
    No evidence of oil!! Wtf!! Aren't they suppose to add it when you take it to the dealer to get an oil change?! Is the oil filled up almost to the top?
  5. Oct 11, 2013 at 10:15 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    If you fill it to the top you will blow the seals on the engine. That is what the dip stick is for. You might see some sheen from the oil...
  6. Oct 11, 2013 at 10:26 PM
    sergio1531
    Zombie1531
    Las Vegas Nevada
    05 PreRunner SR5
    I see no oil what so ever uncaping. What's my next step? My truck is trippin!
  7. Oct 11, 2013 at 10:28 PM
    nfs257
    DFW
    She gone
    Check the dipstick... yellow handle on passenger side of engine......... :cool:
  8. Oct 11, 2013 at 10:31 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    either im on drugs or im just tripping but you will see a little bit of oil. like nfs257 said that what the oil dip stick is for. now if you don't see oil on the dip stick better add some in there. from dot to dot its 1 qts.
  9. Oct 11, 2013 at 10:34 PM
    nfs257
    DFW
    She gone
    VERY
    And let us clarify at this point... You add to the oil cap and not to the dip stick that is only to check the oil...
  10. Oct 11, 2013 at 10:43 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    There's only supposed to be about 6 quarts of oil sitting in the pan at the bottom of your engine, and not filled to the top. When you start your engine, the oil pump then circulates it around to all of the moving surfaces sort of like your heart pumps blood around in your body. If you start your engine with the oil cap off, some oil will splash out from being thrown off of the engine's moving parts.
  11. Oct 11, 2013 at 11:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Trollolololololo
  12. Oct 11, 2013 at 11:04 PM
    nfs257
    DFW
    She gone
    x2
  13. Oct 12, 2013 at 3:55 AM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    Exactly
  14. Oct 12, 2013 at 4:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you have to ask questions like this - You probably shouldn't try to trouble shoot the dealerships work.
    Define "trippin" - Cause if the dealership really did forget oil and you keep driving/messing around w/ it you are only digging the hole deeper. Call them ASAP and let them fix their mistake, if that's what happened.
  15. Oct 12, 2013 at 4:28 AM
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    OK; but is it acting hinky at all? That's the more important question.
    PHM
  16. Oct 12, 2013 at 4:32 AM
    oldracer
    oldracer Well-Known Member
    I have heard of people filling it up, with engine oil, to the top of that hole!
    Really, true story.
  17. Oct 12, 2013 at 4:57 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Years ago, my wife thought the radiator was low so she took off the oil cap only to see nothing. She was at work. She went back in to get water and proceeded to dump a shitload of water into the crankcase. She then starts the car only to hear bad noises and the engine shaking. She then calls me crying telling me the whole story.:eek:
    So off I go to Walmart to get oil containers and some clean oil and filter. I think about 2 gallons of milkshake came out of that engine, I fill it with clean oil and she drives it home. 3 oil changes later, no more milkshake. That Grand Am was driven another 120K miles before we sold it.
    She is still not allowed under the hood:D
  18. Oct 12, 2013 at 5:10 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Yeah ... trippin is one thing. But Hinky :eek: now we might have a problem. :D
  19. Oct 12, 2013 at 5:24 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    I felt someone should also make a point of: YOU SHOULD SEE NO CONDENSATION ON THE IN SIDE OF THE OIL CAP. Condensation is bad. Capslock is gud :D
  20. Oct 12, 2013 at 5:56 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I don't think you can see oil when you look into the oil cap opening, although I've never tried that hard. I think most, if not all, fits down in the oil pan on the very bottom of the engine. This thread is funny.
