Uncertain about towing performance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by el_smurfo, Aug 1, 2017.
  1. Aug 1, 2017 at 1:48 PM
    el_smurfo
    el_smurfo [OP] Well-Known Member
    I have an old travel trailer that weighs about 2000lbs. I have it loaded properly with about 200lbs tongue weight and it's towing pretty level. Additionally, I have the latest recall 4 leaf springs, 5100 shocks front and back (fronts set for lowest lift, 0.8"?).
    I find that even this trailer seems to really "wag the dog", giving us all a little bit of seasickness from the rear bouncing. It never seems to bottom out, and I have limited towing experience, so I ask, does the Tacoma just kind of suck for towing or is this how all smaller vehicles feel? Should I bother investing in some Timbrens or other spring helpers or just take some Dramamine before we head out?
  2. Aug 1, 2017 at 1:52 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my 09 pulled a 2700 lb trailer well, no bouncing at all
    what tire pressure? if too low it will bounce a bit
  3. Aug 1, 2017 at 1:54 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    wagging the dog, and bouncing are two different things.
    "Wagging the dog" is a side to side motion. VERY DANGEROUS. if this is what you are experiencing, you need more tongue weight. I personally like 15-20% tongue weight. you are at 10% which is right on the cusp of almost too little.
    Bouncing up and down is simply a symptom of extra weight out back, So long as you are not bottoming out you are good. If you really do not like this sensation get a weight distribution hitch, this will solve things up real quick.
    Hoover likes this.
  4. Aug 1, 2017 at 2:00 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    +1 for weight distribution hitch set up. I pull over 4600lbs and it does not bounch, i should note I have the old man emu dakar leafs
  5. Aug 1, 2017 at 2:08 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Do you have a profile pic of the truck and trailer? Also, how much gear is in the bed of your truck?
    FWIW, I tow a travel trailer that is just over 5k lbs loaded and I think the Tacoma tows it pretty well.
  6. Aug 1, 2017 at 2:47 PM
    el_smurfo
    Sorry about the confusion in terms...I have no side to side sway, only a pretty good amount of up/down motion.
    The truck bed had a few kid's bikes, a camp stove and some lanterns and the rest was in the camper.
    The Tacoma is a DC OffRoad and has BFG A/T...I think 265/75. They are aired to 35lbs and the trailer tires are aired to 30 (was 35, but I lowered to try and get a less bouncy ride).
    Here's the best photo I could find right now...it's pretty level when on flat ground and the rear is about 1-2 inches lower than normal with the trailer hitched up.
  7. Aug 1, 2017 at 2:54 PM
    nd4spdbh
    SoCal
    id suggest a smidge more tongue weight and get a weight distribution hitch setup. Cheap easy insurance to cover all your bases.
  8. Aug 1, 2017 at 3:07 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Something ain't right. You shouldn't even know that is behind you. A little more tongue weight might be the answer, and a WDH shouldn't be needed for that little trailer. Your trailer, loaded out may weigh more than you think. Ever had it on scales.
  9. Aug 1, 2017 at 3:18 PM
    el_smurfo
    Never had it on a scale, but it's only about 14 feet hitch to bumper and they built them pretty light back in '65. I rebuilt it from the frame up and it's 3/4" plywood floor, 1x wall framing and 1/8" ply interior cabinetry. The wife and I could easily lift each side wall into place. Similar sized campers I've seen weighed were around 2000lbs, but I guess I should get mine weighed before any extended trips.
    It has a size 27 battery and full propane tank on the tongue. Inside, there's not much room in there to add more weight forward of the axle, but I guess I could fill the 7 gallon waste tank in the front and dump it when we get there.
  10. Aug 1, 2017 at 3:22 PM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    I tow a popup that has got to have a good 450lbs tongue weight (carrying two group 29 Interstate batteries and two Viking propane cylinders) and the camper is probably 2800lbs loaded, and it tows like a dream - no sway and no bounce.
  11. Aug 1, 2017 at 3:27 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Looking at your picture, your ball should sit up higher. Trailer nose is to low.
  12. Aug 1, 2017 at 3:30 PM
    jake72
    Jake
    N.E. PA
    Andersen rapid hitch with the 4 inch drop would work great for you. You can adjust it excactly where you need it.
  13. Aug 1, 2017 at 3:32 PM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I agree with @jake72, if you can adjust the nose of the trailer by raising the hitch you should be better off. Also be sure the weight in the trailer is evenly distributed, I understand that this may be hard to do because you rebuilt the trailer and you are unsure of the current weight. But rear weight and front weight makes a big difference with a single axle trailer. IMO, you will always have some bounce...the idea is to alleviate as much as possible.
  14. Aug 1, 2017 at 3:33 PM
    Gun guy
    Gun guy Tacoma Fanboy
    05 Trd Off road AC MT & 08 Tacoma 2.7 AC MT
    Not very experienced with Towing so I can't give advice about weight distribution or anything fancy, but with my Trd OR I did a bit of towing boats and trailers. It think the trick is to just take it slow. There is no reason to hit the fast lane when towing. Take it even slower if there is wind.
  15. Aug 1, 2017 at 3:39 PM
    el_smurfo
    Optical illusion...that site had a sloped entry and flatter area in the rear. It leveled out exactly where the hitch was, so it makes it look low. A low hitch should actually increase the tongue weight though?
  16. Aug 1, 2017 at 3:40 PM
    el_smurfo
    With this old thing that wasn't built to be towed by a modern vehicle, I always tow at 55.
  17. Aug 1, 2017 at 3:44 PM
    Gun guy
    That's great. I used to tow too fast when I was young and dumb, got speed wobbles once and it scared me straight. Now a days, I always get annoyed when I see some douche nozzle in his brodozer towing some crap tail gating people and flying in the fast lane.
  18. Aug 1, 2017 at 3:45 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    It looks okay to me. Nose down is better than nose up but lower in the front will not give you more tongue weight. Get it weighed and maybe look into a WD hitched it turns out to be heavier than you think.
  19. Aug 1, 2017 at 3:47 PM
    el_smurfo
    Yeah, that's what I'm trying to get a feel for. It didn't feel unsafe, but so many folks post about towing 5000lb trailer that they can't even feel, so it makes me wonder how much bounce is too much. Taxifornia roads are pretty terrible, so maybe it's fine.
  20. Aug 1, 2017 at 3:51 PM
    jake72
    Jake
    N.E. PA
    Believe what you like, but that trailer would pull better with the nose up higher.
