Unchained 5150's DCLB 4X4 Build and Upgrades
Discussion in '2nd Gen. Builds (2005-2015)' started by Unchained 5150, Jan 30, 2019.
  1. Aug 10, 2019 at 5:45 PM
    #1201
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall Modified bed extender
    I’m pretty sure it’s 4gauge
  2. Aug 10, 2019 at 5:49 PM
    #1202
    Unchained 5150
    Unchained 5150 [OP] Well-Known Member
    Rick
    Auburn Ma
    Thank you Rebecca
  3. Aug 10, 2019 at 8:46 PM
    #1203
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    I don't have a blue sea, but I used 6 ga for both....colored coded of course
  4. Aug 12, 2019 at 7:03 AM
    #1204
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Oxford, MA
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME Nitrochargers, 887 coils, JBA UCAs, Dakar leaf pack, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I've got some 6AWG we'll use for that. Everything else will pretty much be there already, we may need to splice a couple leads to fit the new location, but I don't think it'll take anything I don't have on hand already.
  5. Aug 12, 2019 at 7:08 AM
    #1205
    Unchained 5150
    Rick
    Auburn Ma
    Just wanted to get it mounted and run the positive and negative line beforehand
  6. Aug 12, 2019 at 7:34 AM
    #1206
    Unchained 5150
    Rick
    Auburn Ma
  7. Aug 12, 2019 at 8:10 AM
    #1207
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Don't use those- they're 3' long! You'd just be replacing one rat's nest with a thicker gauge rat's nest. Unless you plan on cutting them down to size and installing new terminals. In which case, it'll actually be cheaper to buy bare cables and separate terminals, just don't forget the heat shrink or electrical tape. Here's a handy trick I've been using to install terminals on battery cables when installing electrical systems:
    place the terminal in a vise- open side up. Make a bundle of solder and fill the cavity of the terminal with it. Use a plumber's propane torch to heat the sumbitch up so the solder melts. Add more solder without reheating. Dip the cable end in flux (you can use the plumber's stuff too). Heat the terminal again so the solder melts fully and dip the cable end into the melted solder. If you applied flux properly, the solder will wick into the strands of the cable and once it cools (about 5 seconds), you'll have a solid connection. You don't even have to crimp afterwards (although I do just for redundancy and because I have a large terminal crimper tool).
    BTW, you'll need more than just two cables:
    neg- from battery to blue sea
    pos- from battery to breaker
    pos- from breaker to blue sea
    Oh and to answer your PM question, I'm pretty sure it's a 5/16 terminal on the blue sea. I don't remember off hand, but 3/8 is too big. Another thing to note is that if your cable is too big, you might have to trim the blue sea cover slightly so that it closes over the completed and assembled project.
  8. Aug 12, 2019 at 8:13 AM
    #1208
    Unchained 5150
    Rick
    Auburn Ma
    Okay then @BadDNA I will be waiting for you in this job
  9. Aug 12, 2019 at 8:17 AM
    #1209
    THEPYRITETACO
    THEPYRITETACO Well-Known Member
    San Diego
    2014 TRD Sport 4x4 DCLB
    Huge fan of your truck. It’s always interesting to see what others have done to their DCLB pyrite micas!
  10. Aug 12, 2019 at 8:19 AM
    #1210
    Unchained 5150
    Rick
    Auburn Ma
    Thank you my friend
    THEPYRITETACO likes this.
  11. Aug 12, 2019 at 8:45 AM
    #1211
    Old Marine Cal
    2015 MGM DBLCAB
  12. Aug 12, 2019 at 9:16 AM
    #1212
    GHOST SHIP
    GHOST
    Do I need to take you to my barber shop?
    https://youtu.be/74I7Nl1mKig
  13. Aug 12, 2019 at 11:25 AM
    #1213
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    What a great install, would love to see pictures of the finished cable and your panel
  14. Aug 12, 2019 at 11:29 AM
    #1214
    Sgt.Tee
    Pete
    NE Pa
    The blue sea panels I found, the breakers I did not, have a link?
    I am going to install the Bluesea 5032 split buss. For what I need to do this will be my install. I will need to bring 2 positive leads off the battery, one will go for constant, the other to switched on the panel, so will need 2 breakers
  15. Aug 12, 2019 at 4:02 PM
    #1215
    Unchained 5150
    Rick
    Auburn Ma
    Guys help, this is on my daughter's battery, what the hell is it and why?
  16. Aug 12, 2019 at 4:10 PM
    #1216
    GHOST SHIP
    GHOST
    Thems hi-amp fuses. What kind of car? Hybrid? 120 amps and 60 amps is for something hi powered.
  17. Aug 12, 2019 at 4:11 PM
    #1217
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Taco
    What type if car does she have? Aftermarket stereo system? That is a lot of positive 12v wires going to something.......the distribution block does look factory though...
  18. Aug 12, 2019 at 4:17 PM
    #1218
    Unchained 5150
    Rick
    Auburn Ma
    KIA Mini Van older model
  19. Aug 12, 2019 at 4:18 PM
    #1219
    Unchained 5150
    Rick
    Auburn Ma
    2007 Hyundai Entourage
  20. Aug 12, 2019 at 4:20 PM
    #1220
    crashngiggles
    Jared
    What has power in the vehicle? Sliding doors? Aftermarket stereo?
