Uncontrollable on the freeway
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guyofnowords, Jul 16, 2022.
  1. Jul 16, 2022 at 9:50 PM
    guyofnowords
    guyofnowords [OP] Well-Known Member
    I own a 2006 Tacoma off-road.
    When I drive it on the freeway, specifically at 70 to 80 mph, it feels uncontrollable. The car feels like it jumping or jerking around.
    Note: I changed the front two shocks with aftermarket Bilstein. I didn't do an alignment yet, but I marked the cam bolts and put them back to the original position.
    I'm used to smaller cars, like a 4-door sedan. So I'm just wondering if this is a characteristic of the truck or is my alignment that bad?
    Edit:
    I replaced the shocks with Bilstein 24188401 Shock. The car has 175k miles
    I went back to see if any of the bolts were loose. They all seem to be tight. I couldn't even turn it anymore.
    I check the bushings as well. Both of the sway bar end links seems to be in bad condition. The protective rubber covers are ripped. Here are a few pics of the passenger side. The driver side is similar.
    Passenger side end link. As you can see, the surrounding area from the top of the end link is dark.
    Here is a photo of the driver side LCA bushing. The surround area seems to be dark. Especially by the bolt. Could be leaking, or it could be because I saturated it with WD-40 when I did the job. But, that was awhile ago, and I did do a lot of car washes already... and the areas that did have WD40 did seem to wash away so far
  2. Jul 16, 2022 at 9:52 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Get an alignment and have the tires road force balanced.
  3. Jul 16, 2022 at 9:55 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Might be your alignment. Or slow down! What State can you legally drive 70 to 80mph?
  4. Jul 16, 2022 at 10:32 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Consider Archive Garage Hammer Hangers especially if your truck has added weight to it like bumpers sliders or even a camper shell.
    AGHH really planted my truck and took it from rolling boat wild to potted plant static.
    RustyGreen and Steves104x4 like this.
  5. Jul 16, 2022 at 10:44 PM
    guyofnowords
    Yeah, I'll probably get an alignment done. I'll probably wait until I change my rear shocks and front tie rod end links
    I'll have the shop do a road force balance as well
  6. Jul 16, 2022 at 10:56 PM
    guyofnowords
    My truck is all stock with an empty bed... Did you install it yourself or do you know a shop that can do it?
  7. Jul 16, 2022 at 11:02 PM
    Key-Rei
    Key
    Florida
    I did it myself but I kinda am a shop.
  8. Jul 16, 2022 at 11:06 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If you like the tires you have on the truck, do it sooner than later. If you change the ride height on the front of an IFS vehicle, you'll change the alignment. You'll scrub the tread off those tires in short order.
  9. Jul 16, 2022 at 11:06 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Texas. Havw a few 80mph areas but most on freeway is 75 near me
    DG92071 likes this.
  10. Jul 16, 2022 at 11:12 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    Quite a few also around socal if you're doing 70 you better be in the right lanes.
    Check tire pressure and if you lifted the truck the old cam tab settings don't mean anything but it shouldn't be so severe it makes the truck jump around.
    Also check all the bolts to make sure they are torqued properly. Even slightly loose suspension parts will have a large impact on steering feel.
    Key-Rei likes this.
  11. Jul 16, 2022 at 11:20 PM
    guyofnowords
    I definitely should do it soon since tires are expensive! My ride is completely stock btw
  12. Jul 16, 2022 at 11:27 PM
    guyofnowords
    My ride is completely stock... I just replaced the shocks with the regular bilstein not the Toyota bilstein
    Also, it's good that you mentioned that something could be loose... I realized that I torqued everything while it was still on the jack stand
    edit: I'm sure that if it was really loose I would be hearing a clunking sound, which I don't hear, but I will most likely just go under the truck and re-torque the bolts
    dirtnsmores likes this.
  13. Jul 16, 2022 at 11:32 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Why did you mess with the cam bolts when changing the front shocks?
    it’s an old truck at this point. Did this out of control feeling happen suddenly, like after you messed with the cam bolts, or did it progressively happen over time?
    I too am in an ‘06 (original owner). Every wear item in the suspension has been replaced at least once. If it was progressive look into bushings, ball joints, tie rods (inner and outer), steering rack bushings and bolt torque, and wheel bearings.
    If it was sudden after messing with the alignment…get an alignment. You can verify the toe at home using a string, Google it. But if it’s “jumping” that sounds like something is loose.
    Grey 2015 likes this.
  14. Jul 16, 2022 at 11:38 PM
    chueflee
    chueflee Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    I had that happened to me before. My truck would jump all over after i hit a bump or hole. And I had to hold the steering tight. It turn out to be the steering rack bushing were worn. https://www.suspension.com/8.10106
    CHange the bushings and have not had a problem since
    DG92071, Steves104x4 and Key-Rei like this.
  15. Jul 16, 2022 at 11:43 PM
    guyofnowords
    I needed to drop the lower control arm in order to take out the shocks... so that is the reason why I messed with the cam bolts
    I'm thinking that it was after I messed with it... but then again, the only time I drove it at that speed was when I first bought the truck and the only thing I noticed at that time was that it was sort of pulling to the right
  16. Jul 16, 2022 at 11:50 PM
    guyofnowords
    This actually sound a lot like my issue too. Especially after I go over uneven roads on the freeway, I would have to hold on to the steering wheel tight because sometimes it felt like it would throw the car towards one side
    I'll definitely look into the part you mentioned
    Steves104x4 likes this.
  17. Jul 16, 2022 at 11:51 PM
    dustin19d
    Dustin
    Washington
    front shocks come out with the suspension at full droop. No need to remove the LCA. But I guess that doesn’t matter at this point.
    my bet, not being able to look at it or drive it, is that something’s loose.
    loose steering rack bolts or worn steering rack bushings do exactly what you’re describing but you didn’t touch that. If it didn’t jump around before the shock change id focus on what you touched. Make sure it’s all torqued. Get the alignment verified.
    Running Board Man likes this.
  18. Jul 16, 2022 at 11:52 PM
    Running Board Man
    Running Board Man Well-Known Member
    Check for worn/broken parts
    The bushings that isolate the rack from the frame always need ti be replaced with polyurethane, I would make solid ones if I had a lathe to make them on because any play there is too much
    guyofnowords[OP] likes this.
  19. Jul 17, 2022 at 12:05 AM
    guyofnowords
    Well I didn't exactly remove the LCA I just needed to loosen it so that it can move down since I wanted to remove the shock without wanting to use spring compressors.
    But yeah, I'll recheck the bolts by hand first to see if anything is even slightly loose.
  20. Jul 17, 2022 at 4:53 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    What you are experiencing is not normal at hwy speeds. Take it to an alignment shop so it can get aligned along with getting the front end looked at.
    Blockhead and guyofnowords[OP] like this.
