Uncontrollable on the freeway
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guyofnowords, Jul 16, 2022.
  1. Jul 17, 2022 at 6:30 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Which Bilstein shocks did you use? Are you sure they're for this truck? Did you also change the coils?
  2. Jul 17, 2022 at 6:32 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Wisconsin has 70mph zones on Interstates where flow of traffic is usually about 78. Most of our big highways are 65mph where flow is usually 72. It sucks down the MPG's but you sure move around quickly...
    DG92071 likes this.
  3. Jul 17, 2022 at 2:26 PM
    guyofnowords
    guyofnowords [OP] Well-Known Member
    I used these shocks: Bilstein 24188401 Shock
    I'm sure that it's for the truck and no I left the stock coils on
  4. Jul 17, 2022 at 2:28 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Bent frame
  5. Jul 17, 2022 at 3:38 PM
    OkieCowboy
    OkieCowboy Well-Known Member
    Lloyd
    Choctaw, Oklahoma
    2012 TRD 4X4 Access Cab
    Oklahoma turnpikes are 80 mph. Better be in the right lane if that is all you are doing. Interstates are 75.
    DG92071 likes this.
  6. Jul 17, 2022 at 3:58 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Why in the hell would you need a spring compressor to remove the springs from the truck? To put new shocks on sure but?
  7. Jul 17, 2022 at 6:40 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    What state do you live in, stay out of the left lane Bob?
  8. Jul 17, 2022 at 6:53 PM
    guyofnowords
    I was removing the shock like how it is shown in this video
    https://www.youtube.com/watch?v=uQ9oW-VNWWo
    But yeah, I was replacing my front shocks. In order to safely remove the shocks, you need a spring compressor to compress the coil springs since they are under compression.
    I didn't want to go this route, so I went with the route that is shown in the video above.
  9. Jul 18, 2022 at 12:57 AM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Dude, rent a coil compressor from autozone for free before you follow some sketch YouTube vid and loosen your cam bolts. Whole coilover comes out at full droop. Use free rented compressor to remove shock. Put everything back together.
    Free compressor is cheaper than killing someone on the road cause your front end is all janky.
    Grey 2015 likes this.
  10. Jul 18, 2022 at 2:16 AM
    Tacoche
    Tacoche Well-Known Member
    2008 trd sport
    3rd gen trd sport suspension
    This is your problem. You need to torque everything with the truck on the ground. Now all your bushing have a hard time
  11. Jul 18, 2022 at 3:15 AM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    The lower ball joint pictured in the third photo (not your LCA per say) is spewing grease, that should be replaced, a little is fine but that's everywhere. The end links don't look too, too bad, but the inner joint (attaching to the sway bar) is definitely a little weather worn but the quality of the image is too low to tell if it's actually ripped. As for loosening the cam bolt, shouldn't have done that but y'know.
    You want to torque lower shock bolts on the ground, cam bolts, leaf shackles, ubolts etc. Knuckle/balljoints should be torqued when off the ground.
    Go get an alignment, road force balance, and if that doesn't help have someone look into the pinion bushings in your rack and pinion (steering components). You wouldn't necessarily drift if this was a problem. You'd likely experience uneven difficulty turning to one way more than the other, looseness/sloppy wheel feel/sloppy steering, unusual noises or vibrations during steering. From what I can tell this is not the case.
    To clarify; what you're calling bushings are all a type of ball joint with and/or a rubber cover called a boot. Your sway bar has rubber boots on either end of the link sealing small ball joints. Your lower control arm has bushings inside the two arms where you loosened a cam bolt. Bushings are typically metal, rubber, or polyurethane cylinders - you will also find these bushings in shocks mounts and leaf spring eye/eyelets (ends). Your lower control arm connects to your steering knuckle in a single place via a ball joint which has a boot to hold in the grease. The grease that looks to have spewed all over your knuckle from it tells me it needs replacing; this is shown in the third photo you linked.
  12. Jul 18, 2022 at 4:15 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    This ^^^^^^^^^^^^^^^^
    DG92071 and guyofnowords[OP] like this.
  13. Jul 18, 2022 at 12:40 PM
    guyofnowords
    First off, thanks for offering a solution and attempting to remedy the issue!
    This is very helpful information that's helping me learn. I will definitely retorque everything the way you mentioned
    Alright, I'm going to buy a replacement and get it done. For the end links, it's actually ripped. I can pull apart the rubber part and see the inside. For the cam bolts, when I did the job I figured that I can get an alignment and that would set everything back in place.
    Yeah, the steering isn't the issue at all... it turns smooth and rides smooth in the city. The only issue is the highway speed
    photogr4x4[QUOTED] likes this.
  14. Jul 18, 2022 at 4:39 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    BUT, you will need to loosen all the bolts to let the bushings relax at ride height, then retorque. You can do this on ramps so the weight of the truck is on the suspension but you still have room to work. Don't loosen the ball joints, just the lower control arm bushings and the lower strut mounts.
    photogr4x4 and DG92071 like this.
  15. Jul 18, 2022 at 4:42 PM
    #35
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Montana, Wyoming and Colorado are all places I've been that have 80 Mph posted speed limits.
  16. Jul 18, 2022 at 4:50 PM
    #36
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Probably really low caster.
  17. Jul 18, 2022 at 4:55 PM
    #37
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Even when it snows?
  18. Jul 18, 2022 at 4:57 PM
    #38
    ScrippsRanch67
    Bob
    Fiberglass shell
    At age 69 I am in no hurry to get anywhere. Only usually to the bathroom!
  19. Jul 18, 2022 at 5:01 PM
    #39
    mic_sierra
    Elsewhere
    It is a different world than Scripps / Mira Mesa / Southern Cal. My experience has been that people drive as conditions allow and those that don't end up royally effed in the A because you are on your own out there. I have driven hours with no cell reception in the Wyoming mountains. It does wonders for weeding out the stupid. It is a different feeling: knowing you are on your own.
  20. Jul 18, 2022 at 5:48 PM
    #40
    guyofnowords
    Excellent! I was wondering how I should go about this. I will use your method because I literally jacked up the truck and loosen everything. It appeared as if it relaxed itself, and then I lowered the car and retorqued the bolts.
    I just bought a new floor jack and wanted to test it out... it's a good thing I did because the floor jack didn't lower smoothly. So, I had to return and get another one
