unconventional mpg increases
Discussion in 'Technical Chat' started by ChewbacaTW, Apr 27, 2011.
  1. May 23, 2011 at 5:22 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    With the right technology it is possible to utilize hydrogen in our vehicles,homes,workplaces, basically anywhere we need power. A Japanese company came out with a water car a few years ago , check " genepax water powered car " at youtube. It is an electrical/ hydrogen design with an on board generator.
    when we develop really good batteries it may be best to just do an all electrical set up ( Tesla roadster )but adding hydrogen to the mix will be added performance.
    putting hydrogen in underground tanks at gas stations that need to be constantly filled up like gasoline is not going to happen, that whole delivery system /infrastructure will have to collapse. On board generators like the genepax design will most likely be the best way to do it...
  2. May 23, 2011 at 5:55 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    The Genepax car is a fraud:
    http://en.wikipedia.org/wiki/Water-fuelled_car#Genepax_Water_Energy_System
    http://www.popularmechanics.com/cars/alternative-fuel/gas-mileage/4271579
  3. May 23, 2011 at 7:21 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    gona finally run mine today..for the first time in 6 months I'll let you know if it doesn't run! Otherwise, i save money every day..beat that!! That's what the OP wanted and was outside the box. Everyother idea was BS snake oil. I get 19-20 mpg with 3 inch lift and 285 ATs with corn 87 gas. I only use the AC a handfull of days a year anyways..about ready to pull the whole thing out and get rid of the parasitic drag on the belt.
    Hot air intake is on the way this winter. Pull air from the header area.
  4. May 23, 2011 at 8:51 AM
    ChewbacaTW
    ChewbacaTW [OP] My progeny will be awesome!
    Sam
    Flagstaff, Arizona
    02 Xtra Cab TRD off road
    K&N air intake, custom exhaust, Powerslot Brakes, urethane steering rack bushings
    So I'm running a v6 automatic and and I noticed that my truck cant really tell whether or not it needs to stay in OD or not. I was currious what it would do for me if I changed out my rear diff gears with the v6 manual gears since they're dfferent. Has anyone tried this?
  5. May 25, 2011 at 11:46 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Used the AC last September if I was lucky and she popped right off yesteday (5/24)...so money in the bank not running the condenser with the knob in the defrost setting. I only let it run a minute cause its still only in the fricken 60s here...
  6. May 25, 2011 at 11:52 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You are wrong in several ways.
    1.) It is not a sealed system because a, it has hose fittings for gauges, and b, it utilizes partially rubber line set which leaks naturally, which is why it is common to have to recharge your A/C every few years.
    2.) The oil is mixed in the refrigerant. Refrigerant is greatly effected by the temperatures of ambient air. If you are driving without your A/C on, your refrigerant is going to migrate to the evaporator (cooling coil) inside the cabin of the truck, because it is cooler and the pressure there is going to be less than the high temperature condenser or compressor inside the engine compartment.
    3.) When the refrigerant migrates and stacks in the evaporator, it's bringing all of the system oil with it.
    4.) It can seize.
