Undecided what size to go with- 245/75r16 (stock) vs 265/75r16 vs 235/85r16 vs 255/85/r16
Discussion in 'Wheels & Tires' started by barch88, Jan 19, 2024.
  1. Jan 19, 2024 at 2:30 PM
    barch88
    barch88 [OP] Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    2022 Tacoma SR, not much talk out there after googling with other 3rd-gens with stock steelies (+30 offset).
    From my understanding, all sizes I listed fit completely stock with no rubbing, correct me if I'm wrong...?
    Looking to replace my 245/75/16 stock SR tires. I want something more aggressive-looking, and something with a bit more off-road capability, so I'm set on an A/T tire, probably not a M/T since I will use them in the snow.
    My biggest concern is the gearing. I have a 2.7L with the AUTO transmission, I think it's a 6-speed auto? Not sure what the stock gearing is, someone can comment?
    Someone else said 255/85/16 would be too much for the truck. Is this true? Should I go with stock size or would 265/75/16 be okay? I don't mind the narrower tire either since it'll perform a bit better in snow, but not look as cool.
    Thanks for the advice.
  2. Jan 19, 2024 at 2:48 PM
    surfingtaco209
    surfingtaco209 Well-Known Member
    Jamie
    2019 Tacoma
    I run a 265 75 16’s on a stock Tacoma SR5, my stocks tires were 245. Drive lots in the snow, run Faulkin wild peak ar3/w’s. I dig them. Much better on snow and ice than the stock tires that came w the Tacoma. Much better. Had maybe a loss of 0.5 mpg with the wild peaks.
  3. Jan 19, 2024 at 3:09 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Normally I'd say 265/75/16, but not sure with the 4 cyl. That tire is only about 1" taller than stock and 1" wider. The loss of power with the 6 cyl engine is minimal, but you might notice it with your truck.
    I'll suggest 265/70/16. That is an optional factory size on some trucks. It is the same height as 245/75/16's but about 1" wider. It doesn't change the power, but the width makes it look a little more aggressive.
