Under carriage rust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunter500ky, Dec 3, 2010.
  1. Dec 3, 2010 at 8:10 AM
    Hunter500ky
    Hunter500ky [OP] Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    How can I prevent it? I just climbed under my truck to look at my leaf springs, and noticed that my frame and under carriage is starting to surface rust, only one spot had a little pit in it.
    Its a 06 37k miles, I want to hang on to this truck for a long time.
    Am I just being paranoid? Already worrying about rust?
    Anyway how do I limit the rust?
    This is my first new(er) vehicle and I owe money on it, I thin thats why Im so paranoid about it lol
    Thanks and reps!
  2. Dec 3, 2010 at 8:20 AM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I have it too. I noticed it the worst though looking down at the frame through the engine compartment. I think road salt tended to wash up and lay in some places. I gave the frame a good hose down and sprayed places I could see in the engine compartment with soapy water just to try to get the salt residue out last spring.
    Haven't done anything else though.
  3. Dec 3, 2010 at 8:25 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    What else is there to do I want to keep her around for awhile.
    I know I need to get a stiff wire brush and get at the rust (I think anyway Im waiting till confirmed) then possibly just use some rhino lining stuff (the spray can).
  4. Dec 3, 2010 at 8:31 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    rudt reformer then hammered......once a year
  5. Dec 3, 2010 at 8:43 AM
    EBBS03
    EBBS03 Well-Known Member
    Rob
    Philadelphia, PA / Morgantown, WV
    '10 Tacoma TRD 4X4 Off Road
    Stock
    I wouldn't rhino line. I know that when looking for an older car, you tend to avoid ones that have rust protection plans, because they just hide the problem.
    I would scuff it to remove the rust, but then you would have to apply some sort of primer or rust prevention paint. A think coat of the tar crap or rhino liner would prevent you from knowing if the rust issue is still going on. With paint and primer, you will be able to see it bubbling, and you could just sand the area down again and spray the area again.
    Just sanding the area alone will not be enough, as rust will form again. You need something to seal it.
  6. Dec 3, 2010 at 8:53 AM
    inouk
    inouk Well-Known Member
    They don't hide, they correct it.
    To rust, you need two elements: air (O2) and water. Salt is worst because they accelerate the rusting. By putting a anti-rust paint over it, you're blocking air.
    That's the idea of anti-rust oil/wax traitement and any other specialized products like POR15 (it's thick).
    I use it and I can confirm you: when well applied, it works, rust stops.
  7. Dec 3, 2010 at 8:54 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I know what you mean. I'm debating on what to do with my '10 Taco. Ironically, on my '99 I had the truck undercoated five years in a row (or I guess one undercoating and then touched up) and in July the factory bought it back from me due to the frame rust issue. Guess my undercoating didn't help. With this truck, I can't help but wonder if it's just a waste of money to try and prevent the inevitable. I was thinking about it the other day but back when I first got the truck and was 17, I noticed some rust when it was a couple of years old. Both the dealer and my father told me I was paranoid. 10 years later I guess I proved them both wrong.lol
  8. Dec 3, 2010 at 9:09 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    See that's the thing I'm not sure if I'm just paranoid.
    so you say POR15 works. So do I just get a tough steel brush and get the rust off then put the POR15 on?
    I would rather try and stop it, even if it doesn't work at least I tried. I'm going to mention it to my dealer who I'm sure will say its normal. I'll upload a pic later
  9. Dec 3, 2010 at 9:11 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Also on a side note my buddy had a chevy 06 39k miles his frame looks a LOT better then mine which makes me more paranoid hahaha
  10. Dec 3, 2010 at 10:32 AM
    EBBS03
    Rob
    Stock
    Inouk- I know some can do it right, but I've seen cars that have rusted out with that stuff on, and the owner doesn't realize it. In my experience, I would avoid doing that. Just my $.02.
  11. Dec 3, 2010 at 10:35 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    So don't use POR15?
  12. Dec 3, 2010 at 10:48 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    About twice a year get under there and sand and paint with some rustoleum paint. I use a wire brush and a wire wheel at the end of a
    cordless drill. You do that twice a year, you will be fine.
    Do it before winter, then right after.
  13. Dec 3, 2010 at 10:49 AM
    EBBS03
    Rob
    Stock
    Well, this type of thing is like so many topics in that you will have some say yes and some say no.
    I usually avoid undercarriage spray, but inouk swears by it. I would suggest researching the product and if you do it, follow the instructions to a T, to ensure is works properly.
  14. Dec 3, 2010 at 10:53 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Sounds good man this first time is going to suck. Ok well omw to store to get brush and black rustoleum
  15. Dec 3, 2010 at 10:54 AM
    TACOMA TRD
    Tom
    PA
    I agree with Ebbs... I dont like the Rhino spray on the undercarriage because when you need to work on the truck, you have to scrape all that shit off the nuts and bolts. Paint is not that thick.
  16. Dec 3, 2010 at 11:00 AM
    TACOMA TRD
    Tom
    PA
    Dude, I know where your at..... When I bought my 07 it looked like it sat in a swamp for 3 yrs. :eek: However, thats what it looked like but most of it was just surface rust and did come off rather easy.:rolleyes:
    After a good Northeast Winter, Im sure in the spring it will be back again.
    There a lot of good topics here about rust and how to treat, just type in the search category on top.
  17. Dec 3, 2010 at 11:14 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Yeah its going to be a pain crawling under it, brushing it off (most looks easy as you said) then spraying it and it blowing back in my face while its 38 degrees outside LOL
    winter is almost here (snowing) so I want to go ahead and do it.
    I want to try and keep her rust free I love her.
    I checked under the hood as someone said it was and under there where you could see through I was surprised hardly any was there its mainly my frame.
    Also my axle is pretty rusted should I go ahead and do that to i dont see why not.
  18. Dec 3, 2010 at 11:16 AM
    TACOMA TRD
    Tom
    PA
    ummm yeah. But dont do it on a windy day like i did. Overspray got on the truck and I had to detail it.
  19. Dec 3, 2010 at 11:19 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    haha I would have totally forgotten about that!
    Thank you!!!!!!!!!
    I might do it after it is detailed and they fix everything on Wednesday and do it on Thursday or Friday I have access to a garage no lift or anything but its not in the cold :) also no wind conditions
    repped
  20. Dec 3, 2010 at 11:19 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Wash it once a week in the winter if possible, shove a lawn sprinker under it let it rise the under carraige, when I wash in the winter I make sure to rinse the grille area real good as road salt gets sucked into the radiator.
