Under coating NHOU product
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacofish, Oct 27, 2019.
  1. Oct 27, 2019 at 5:53 AM
    tacofish
    tacofish [OP] Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
  2. Oct 27, 2019 at 5:57 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Why not just look for any biodegrable oil that will do the same thing ? If it’s cheap, it should be fine. But if it’s going to cost you an arm and a leg to do yearly which has to be done, look for something cheaper. Oil based is oil....and it’s great to help prevent rust, especially in the body panels and around welds where most rust occurs.
    tacofish[QUOTED][OP] likes this.
  3. Oct 27, 2019 at 6:34 AM
    69L46Vert
    69L46Vert Well-Known Member
    Rick
    Maine
    2007 Regular Cab 4x4
    A friend had his Chevy done in it recently. It's REALLY messy but looks like it will hold up good. Personally, I prefer Fluid Film but I may be biased as I bought the FF gun and have done about a dozen cars/trucks with it. I think the NH is comparable to FF just not lanolin based like FF is.
    Dagosa and tacofish[OP] like this.
  4. Oct 27, 2019 at 12:54 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Boiled Linseed Oil dries protects and cheap.
    Dagosa likes this.
  5. Oct 31, 2019 at 3:37 AM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Yup. Another good alternative used for decades.
  6. Oct 31, 2019 at 3:57 AM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    It’s important too in this advertisement to read the problem in rust proofing. Here is an excerpt of the actual process by which rust occurs and why it needs to be addressed routinely.
    Most people will rarely see the underside of their car or truck, but that won’t change its condition. It’s important your vehicle’s chassis and undercarriage are well protected from the elements. The fact is, a new car is subjected to thousands of spot welds and numerous bends and folds during production.
    This process damages the pre-coated metal, allowing exposure to the corrosion process. Besides cosmetic damage, corrosion also weakens a vehicle’s structural integrity and can affect steering and suspension components. The destructive force of auto corrosion is the single greatest threat to your vehicle. It can lead to rapid deterioration of metal, not only resulting in poor appearance, loss of value but real safety hazards.“
  7. Oct 31, 2019 at 4:06 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    When I was a kid, we just put used oil in a spray bottle and sprayed the under carriage a couple times a year. It worked and was close to free.
    EPA don't read this post.
  8. Oct 31, 2019 at 7:55 AM
    george3
    New Jersey
    Cheap - easy - drys - doesn't collect dirt. Can't beat it can you buddy ?
  9. Oct 31, 2019 at 12:23 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Never used it on cars but have on my attachments for my tractor.
    Didn’t find it any better or worse....which is to say, it’s fine.
    tacofish[OP] likes this.
  10. Oct 31, 2019 at 3:24 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Exactly !
    And since then, we’ve learned the problem of using extremely carcinogenic materials that finds its way into ground water.
