Under coating on new Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by surfponto, Oct 31, 2006.
  1. Mar 9, 2007 at 10:18 PM
    mugu07taco
    mugu07taco Member
    Another good topic. I will check mine tomorrow.
  2. Mar 12, 2007 at 3:00 PM
    TacoMan
    TacoMan Active Member
    good wife-
  3. Aug 22, 2016 at 3:38 PM
    Healyj7
    Healyj7 2010TRD Cape Cod
    Cape cod MA
    2010 Tacoma 4x4 crew cab...
    Led third brake light All bulbs changed to LED Blue... Bed cover Extra tie downs in bed Borla 3' aftermarket excuast Blacked out front grill Smoked front lights White turn/running lights Bed security Mod 2 inch front lift and level with bilstein front and rear shocks... 1 Inch wheel spacers BF Goodrich AT tires 270/75/17
    I live in Cape Cod MA beach sand and winter salt what parts do you undercoat? What parts do you avoid?
  4. Aug 22, 2016 at 3:59 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Undercoating like fluid film is better than the spray can rubberized stuff. With the rubberized crap if a hole/crack developes in it water gets behind it and you'll have way bigger problems than if you had done nothing in the first place (don't ask me how I know this.) The problem is you can't see the rust behind the material until it's too late. With products like fluid film it's more of a oil... able to see under it and you can still find the nuts and bolts.
  5. Aug 22, 2016 at 3:59 PM
    Markcal
    Markcal Well-Known Member
    Why not use Fluid Film or does the rubber coating do a better job?
  6. Aug 22, 2016 at 10:40 PM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
