Under drive/ lighter Pulley?
Discussion in '4 Cylinder' started by cicada83, Jul 14, 2012.
  1. Jul 14, 2012 at 6:56 PM
    cicada83
    cicada83 [OP] Well-Known Member
    Midland, MI
    Retro white SR5 4x4
    Volant ram air, Bestop soft topper
    I have searched the site and there is not much on this. I am thinking of switching to an electric fan to get rid of that drag and if I can install a lighter under drive pulley. Just looking for a little mpg and hp increase if possible. I am not having any luck finding if anyone makes an under drive pully for the 4 banger. Anyone have info in this?
  2. Aug 12, 2012 at 1:20 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    Im also interested in the electric fan
  3. Aug 12, 2012 at 1:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The electric fan will draw more from your charging system.
    The underdrive pulley will reduce the output of the charging system.
    If you spend a fair amount of time at idle, particularly in heavy traffic in warm weather where the fan kicks on a lot, you may have trouble maintaining battery charge.
  4. Aug 13, 2012 at 1:28 PM
    BamaToy1997
    Bill
    Navarre, FL
    While I agree that you will draw more from your charging system with an electric fan, research has shown that the increase in engine load from the alternator is outweighed by the HP drain from a belt-driven fan under load.
    Also, even if you spent a long time at idle, you are not going to have any trouble maintaining charge. Cars and trucks all over use electric fans and have no trouble at all with battery state at idle.
    Just my experience.
    URD and LCE both carry different underdrive pulleys for Tacoma trucks. however, if you do install one OP, Rich is right that you may suffer slightly on Alternator output, as well as power steering and AC system. Probably not enough to notice, but you should know.
