Under Hood Lights
Discussion in 'Lighting' started by claymore, Dec 29, 2012.
  1. Dec 29, 2012 at 8:46 PM
    claymore
    claymore [OP] Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    I have been wanting some under hood lights for a while now. It is dark under there, even in the day light. I have looked at some LED's like these,http://www.tacomaworld.com/forum/lighting/95593-led-hood-lights.html#post1826234, but they just seem vulnerable. I liked the light they put out and the low amp draw, but I didnt like adhesive holding them on in a hot engine compartment. I also worried about them when pressure washing the engine bay. I bought some cheap fog lights from Pep Boys for $24. They just seem a little more sturdy.
    I found a spot to drill into the underside of the hood. Very Carefully!
    I attached the mounting bracket with rivots and used a washer to be sure
    Light mounted and carefully checked to make sure there is no contact when the hood is closed. I also got it away from the radiator to try to help with it getting too hot.
    The hardest part as mentioned by DWreck in his post is feeding the wires up through to hood. Patience and tie wire are the keys. I made a little hook out of the wire and it helped feed it in. I installed a switch and wired it up with a relay. It is like bright sunshine under there at night! :D
  2. Dec 29, 2012 at 9:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Dec 29, 2012 at 9:09 PM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Well done! Idk if you stated it or not, simply because the tapatalk app doesn't show text sometimes, but how'd you wire in a switch??
  4. Dec 29, 2012 at 9:14 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Very nice indeed.
  5. Dec 29, 2012 at 9:17 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    I just used a cheap LED switch mounted by my aux fuse block. I figured I could just turn it on when I need it. I might put a normally closed switch on the ground for a safety just in case I forget to turn it off!
    Thanks Chris
  6. Dec 31, 2012 at 7:40 AM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    Thanks
  7. Mar 2, 2013 at 8:29 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
  8. Mar 10, 2013 at 6:42 PM
    Aeon
    Aeon FOX HOUND
    Puerto Rico
    PreRunner SR5 4x2
    Coming Soon!
    nice job!
  9. Mar 10, 2013 at 6:46 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    Thanks all. They are sure handy, and bright!:eek:
  10. Mar 10, 2013 at 6:51 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You can always use a mercury switch, or magnetic reed relay.
    Problem with the magnetic switch is if the magnet gets dislodged, they come on.
    Mercury switch is how Detroit did it in Buick/Olds/Caddy/Lincoln/Chrysler for decades.
  11. Mar 10, 2013 at 6:53 PM
    AnTiFuBaR
    AnTiFuBaR Well-Known Member
    Grand Junction, CO
    '13 TRD OR 4x4 DCSB
    BHLM
    Looks good! Great idea.
  12. Mar 10, 2013 at 6:55 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    How does this work? Interupt the ground? I have thought of adding this, so I dont forget to turn them off.
  13. Mar 10, 2013 at 7:10 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Mercury switch is simply a bulb containing 2 contacts and a "ball" of mercury.
    Might be hard to find because of enviro regs, but they used to be in every thermostat in every house.
    The mercury rolls back and forth in a glass tube and joins the contacts when it reaches the end. It's just a switch. It can switch either the hot or the ground.
    Install it to the hood securely, slightly "nose down" and when the hood is opened the lights will come on.
    Detroit used them to switch 20w lamps, so the pair of LEDs won't be a problem.
  14. Mar 10, 2013 at 7:17 PM
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    Looks great, but I have to wonder what you're doing in the engine bay, in the dark....
  15. Mar 10, 2013 at 7:26 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Just saw this. Looks good.
  16. Mar 10, 2013 at 8:07 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    It's a secret:spy:
  17. Mar 28, 2013 at 1:27 PM
    lslownslow
    lslownslow Active Member
    jacob
    raleigh nc
    02 sr5
    AP Front bumper Fabtech spindles 1.5" strut spacer Daystar 2" shackle lift 15x8" 0mm offset Pacer Soft 8's 30x9.50" BFG Kos 6" PIAAs reverse lights 6000K Kragens 7 inch fogs
    wow thats super bright
  18. Mar 28, 2013 at 1:32 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Nah, they are super cheap and all over ebay.
    sealed type:
    http://www.ebay.com/itm/WEATHERPROO...692?pt=LH_DefaultDomain_0&hash=item19d2d2e404
    Open:
    http://www.ebay.com/itm/10pcs-Mercu...926?pt=LH_DefaultDomain_0&hash=item3a637e64ee
    I'd just use a normal switch tho. I can imagine the hood lights flashing on and off while you are wheeling :D
  19. Mar 31, 2013 at 4:30 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Checking oil, jump starting someone, adding windshield washer fluid, hooking up the winch control, etc.
