Under hood stickers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aldo ct, Apr 4, 2015.
  1. Apr 4, 2015 at 11:49 AM
    Aldo ct
    Aldo ct [OP] Well-Known Member
    central California
    97 Tacoma 2rz
    LC header, prerunner/4x4 front end, hellwig rear sway bar/beefed brackets, instrument cluster w/tachometer, 60/40 bench seat, solid sideview mirrors, slider rear window, rearview mirror w/map lights, 27x8.50r14 tires
    Can someone post pictures of the stickers that should be found on the underside of the hood of the 2rz engine? I have a space on my hood where it appears there was a sticker. I am not sure if it fell off or if someone that worked on it ripped it off.
    On the passenger side is one large sticker with engine information including valve clearance, emissions. Above this sticker, there is an area outline with dirt where another sticker was. This is the one that is missing. On the driver side there is a vacuum hose diagram.
