" Under load / uphill " vibration
Discussion in 'Technical Chat' started by OZ-T, Jul 15, 2013.
  1. Jul 15, 2013 at 5:45 PM
    OZ-T
    OZ-T [OP] You chose ... poorly
    Peter North
    British Columbia
    I have been experiencing a vibration since new that occurs at varying speeds but only when the vehicle is under a slight load , usually climbing a slight uphill portion of smooth pavement .
    I only noticed it at around 40-44 mph locally , but I was on a road trip and it occured again , fairly severely at 65-70 mph over the weekend
    The vibration seems to come from behind / under my seat , the steering wheel does not shake side to side during the vibration , but the head rests on the front seats can be felt to move forward / backward .
    I originally thought CB carrier wobbling but I set up a GoPro to film it and it does not appear to move oddly .
    This has occured through many changes in my truck from stock / stock wheels + tires to lifted and larger tires
    The common denominator seems to be the slight uphill load on the truck .
    Is there any component that would vibrate in these conditions ?
    FWIW , my driveshaft has been replaced under warranty for signs of cracking near the union at the CB .
    Tires have been road force balanced , OEM Sport alloy wheels have been replaced for another warranty issue ( bubbling )
    Any thoughts ?
    Thanks in advance .
  2. Jul 15, 2013 at 5:53 PM
    Large
    Large Red
    Noob search, geez..
    Actually I would torque your u-bolts, also there is a transmission mount TSB that I would look in to.
  3. Jul 15, 2013 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^^
    Aim the camera at the tail shaft output of the tranny, and see if you can reproduce the issue.
  4. Jul 15, 2013 at 5:59 PM
    OZ-T
    Peter North
    British Columbia
    I already read all the vibration threads
    and my U bolts are torqued to 85 ftlbs
  5. Jul 15, 2013 at 6:00 PM
    OZ-T
    Peter North
    British Columbia
    K
    I did look for cracks in the transmission isolators and found none
  6. Jul 15, 2013 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I don't think cracks are the issue, but rather too soft of a mount.
  7. Jul 15, 2013 at 6:04 PM
    OZ-T
    Peter North
    British Columbia
    K , I'll rig up the GoPro and check it out
  8. Jul 16, 2013 at 8:16 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
  9. Jul 16, 2013 at 9:12 AM
    OZ-T
    Peter North
    British Columbia
    Any other input ?
    Won't get around to rigging up the GoPro till at least tomorrow
  10. Jul 16, 2013 at 9:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    One step at a time. That's the most probable cause given the description you gave. Get off your ass, and mount the camera for verification.
  11. Jul 16, 2013 at 12:48 PM
    OZ-T
    Peter North
    British Columbia
    Hey Captain Butthole , I wasn't doubting you , I have to work today and part of tomorrow
  12. Jul 16, 2013 at 12:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You don't work 25 hours a day. Im sure you have 30 mins. to beat your junk, so instead of working your wrist, install the camera so we can help you.
  13. Jul 16, 2013 at 1:25 PM
    OZ-T
    Peter North
    British Columbia
    Tomorrow is camera day
  14. Jul 18, 2013 at 5:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It is now, the day after tomorrow. We still ahve no video, or update from our OZ-T.
  15. Jul 18, 2013 at 5:59 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Maybe he's busy installing his front BUMBER. Vid's can wait.
  16. Jul 18, 2013 at 6:20 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I would second (or third) the rear engine mount (that's what Toyota calls it even though it's not connected to the engine directly). Only other thing I would check is u-joints while you're under the truck.
  17. Jul 18, 2013 at 7:01 PM
    OZ-T
    Peter North
    British Columbia
    Yeah sorry boys , got busy , didn't even drive the truck at all today
    Hopefully tomorrow
  18. Jul 18, 2013 at 7:02 PM
    OZ-T
    Peter North
    British Columbia
    My U jounts are all new from having my driveshaft replaced 6 months or so ago
  19. Jul 18, 2013 at 7:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Doesn't matter how old they are, if they are not torqued correctly. Check Da Torques.
  20. Jul 18, 2013 at 7:09 PM
    OZ-T
    Peter North
    British Columbia
    Sure
    My vibe has been there since day one though , so unless these ones and the old ones are the problem , I'm leaning towards it being something else
