Under powered truck.
Discussion in 'Towing' started by rcballard, May 1, 2018.
  1. May 1, 2018 at 12:25 PM
    rcballard
    rcballard [OP] Member
    I have a 2017 Tacoma v-6 4x4 with tow package. Pulled our new trailer, 20’ GeoPro apprx.3400# this weekend and truck couldn’ hardly get out of 4th gear (auto trans) on Interstate at 65 mph. Worried that extened towing at higher rpm’s will be hard on engine and trans. Does have trans. cooler.
    Any thoughts or experiences?
  2. May 1, 2018 at 12:35 PM
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
    Gen 3's have 6sp Auto yeah? I have an 2006 Gen2 and I am always in 4th (Auto 5spd) and in 3rd or 2nd at 55-60 up hills w/ 4500lb trailer. Monitor trans & engine temp and perform your regular maintenance and all should be well and good.
    PROseur likes this.
  3. May 1, 2018 at 2:35 PM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    You dont want to tow in 5th or 6th, they are overdrive gears! The owners manual states you can tow in 5th, I personally would only do so on downhill and level situations. There are advantages to towing in higher (2500/3500 rpm) less heat caused by excessive shifting and the transmission pump runs more efficiently. The 3rd gens have a thermostat on the transmission that can be pinned to allow the transmission cooler to work all the time and will allow the Temps to work much lower than the 195 degree setting. Also always tow in S mode and with the ECT on. Good luck, happy and safe towing!
    RyanL likes this.
  4. May 1, 2018 at 5:37 PM
    rcballard
    Thanks awdvkd115, always helps to read manual first. You said the transmission thermostat can be pinned? Not sure what that means or how to do that. Do you have a transmission temp. guage in your truck? Was thinking I would like to add one to mine.
  5. May 1, 2018 at 5:41 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I have a 4 speed and only tow in 4th on flat roads. If it’s gear hunting, downshift. It’s okay to tow in overdrive gears as long as the trans isn’t trying to work too hard. But your truck has a high rpm powerband engine, just like my old 4cyl. You gotta get the rpm up to get into the powerband.
  6. May 1, 2018 at 7:24 PM
    awdvkd115
    Bud
    2017 Tacoma TRD OR
    I use a Scan gauge to monitor all the sensors, the 3gens have two transmission temp sensors already in the transmission. Just research Scangauge II they are very handy, if the computer monitors it the Scangauge will too. As for pinning the transmission thermostat just research 3rd gen tacoma pin thermostat, they have lots of threads that explain how to do it. It very simple, all you do is push in a button on the thermostat and it bypasses the thermostat. It will drop the temps a lot and the recovery tme is a lot faster. There are a lot of photos around to show you where it is.
  7. May 4, 2018 at 1:04 PM
    n1as
    n1as Well-Known Member
    2016 Tacoma DCSB TRD OR
    Don’t your trailer tires have a speed limit of 65? Faster increases the risk of tire failure.
    Which of course doesn’t answer your question!
    koditten likes this.
  8. May 4, 2018 at 1:16 PM
    JoeK
    JoeK Well-Known Member
    NC
    15 MGM TRD Sport DCLB
    The speed limit for towing in many states is 55mph. Check your local laws...
    14TACO4X4 likes this.
  9. May 4, 2018 at 3:01 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    The max speed for towing trailers in some states is 55 like here in California, but for many states it’s what ever the max speed limit is. I seen places in a Texas where it’s 80 or 85 mph. However you are correct the max speed rating for most “trailer tires” is 65 mph. Towing in excess of the speed rating of tires can be dangerous as the tires may over heat and fail. All trailer tires unless otherwise noted are 65mph rated max. You can buy trailers with higher speed ratings but they of course cost more.
    Misfit likes this.
  10. May 15, 2018 at 4:15 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I tow a boat that's around 3800-4000 lbs fully loaded. I had a '14 TRD Sport with tow package and the Taco just doesn't have the torque it needs to tow. I was getting 12 mpg when towing, and the truck struggled up hills... and that's without the AC on.
    I said fuckit and got a RAM EcoDiesel. 420 foot pounds of torque, 25+ on the freeway and better MPG when towing than when the Taco was NOT towing. Got tired of the shit mpg and weak torque.
    OneWheelPeel and RyanL like this.
  11. May 15, 2018 at 4:50 PM
    n1as
    Describe what you mean by struggling up hills? What RPM? What speed? What gear?
  12. May 16, 2018 at 5:37 AM
    Indy
    Indy Master of all I survey.
    In 7 dialects of chinese "tacoma " means "underpowered". You can google it.
    OneWheelPeel and 14TACO4X4 like this.
  13. May 18, 2018 at 9:19 AM
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    266 ft lbs of torque... Struggling is not being able to run your AC because if you do the truck shifts into 3rd going up hill and you're doing 50 by the time you reach the top and people behind you are pissed.
  14. May 18, 2018 at 9:27 AM
    El_Rocinante
    El_Rocinante Well-Known Member
    Pete
    2019 Cavalry TRD OR dcsb 4X4
    It's not a tow truck...Buying a Tacoma to tow is like getting a ram for offroading... ill advised!
  15. May 18, 2018 at 3:32 PM
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I dunno... it has a TOW pkg, and says the limit is 6400 lbs for the MY I had. Anywho... it IS a great truck, and I really loved mine while I had it. Got the boat after the fact, so I had to upgrade my towing ability.
    Not hating on the Taco... just needed more power. I kept my Toyota keychain and it's now attached to my new truck's fob as a reminder of the old girl.
  16. May 23, 2018 at 8:29 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
  17. May 23, 2018 at 11:01 AM
    n1as
    A couple of days ago I picked up my new TT. 3900 lbs dry. Drove about 9 miles to get it home. Some urban surface streets, some freeway. My taco definitely had to work to get the trailer moving and keep it moving. The freeway section was mostly uphill. RPMs were my friend. I was hitting 4k on the on-ramp and it felt sluggish.
    So was the truck under powered? I guess it depends on your perspective. Sure I'd like more power but I don't want a full size truck. The Taco got the trailer home with no issues. If I wanted to have good throttle response and the ability to accelerate up hills while towing, then I'd say it is under powered. I had that with my 2900 lb trailer but the new trailer is a bigger load.
    It will be interesting to see how it does on our upcoming camping trips where we'll be crossing (small) mountains.
    Ridgerunner likes this.
