Under the hood LED install using mercury tilt switch
Discussion in 'Lighting' started by acdronin, Jul 5, 2013.
  1. Jul 5, 2013 at 12:26 AM
    acdronin
    acdronin [OP] Well-Known Member
    SO I've been wanting to add a dedicated circuit of super white LED's under the hood, I've seen a bunch here and elsewhere so that's nothing new, I want to have the power source connected to the posts underneath the terminals so that you can disconnect the battery cables and still have lighting under the hood. I was thinking of different contact switches and another member mentioned mercury tilt switches. Intrigued I picked one up and started screwing around with it. It seems like a little bit more of a challenge and I don't think I've ever seen anyone else do it. For those of you that don't know what a mercury tilt switch is, it's a tiny little glass cylinder with a drop of mercury and two electrical contacts inside one end of it. As the cylinder tilts, the mercury slides down and closes a circuit by contacting both contacts at once.
    Mercury switch.
    Switch installed inside of a gutted ball-point pen
    Switch has two wires coming out of it, I installed the switch in one end sheathed by some shrink tubing to act as a shock dampener and ran the wires out the other end with more shrink tube on it. I heated the pen to cock it at angle that I will explain later.
    The switch and LED's I got a Fry's Electronics but I'm sure you can find these online. The LED Cree bulbs are sealed in an epoxy resin for "splash-proof".
    For the install I have 18 ga wire, 14 ga wire, zip ties, harness tubing and a butane soldering torch with lots of extra butane.
    First was to prep and solder up the LED's I used shrink tube for each connection and a larger piece of shrink tube to create a 'boot' over the wires where it connects to the LED pod.
    Now I had pre-cut the wires to about how long i think they needed to be to all solder at the same point to one larger wire, I could have daisy-chained them too but it would have taken longer (don't ask me how I know). The pods come with some 3M adhesive on the backs of them which came in real handy in holding them in place to drill the holes.
    After mounting the pods with sheet-metal screws and being very careful not to accidentally drill a hole through the top of the hood, I then could mock up the wires to where they will run and then cut them all off at the same spot. I then uninstalled the pods and set to work on the 4 into 1 (4x18ga into 1 14ga), solder connections, with everything shrink tubed I then installed everything into the harness tubing. The trick was to have the pods sticking out of the harness tubes at approximately the right spots. I started with the longest run first, installed it back to the 4 into one and put a zip tie at the pod end to hold the tubing still, then I worked my way down to the shortest pod wire run. At each of the last three pods I put a zip tie on the harness tube to hold the pod in place but I didn't tighten the zip tie all the way so that I would have wiggle room when I reinstall the harness.
    This is the finished harness ready to be installed, It long enough to go all the way back to the battery and all i have to do is fish the hot wire out of the harness at the point where I will mount the mercury tilt switch.
    That's all I got down tonight, will finish the install and write up tomorrow:)
    Ok, finally the stupid heat wave broke and I finished this
    So, I mounted the lights back up under the hood and began to mount the harness tubing with 3/8 clamps and sheet metal screws.
    When I got over to where the switch is going to go, I fished out the how wire and soldered the switch into it and tucked the extra wire back into the harness tubing. Now I had wired up the circuit with the switch and played around with it to see where the right "tipping" point would be for the switch to close. I figured out that the right angle would have meant that the pen would end up mounted at a weird angle so I bent the pen to around 22*, what I wanted was the lights to come on when the hood was lifted but not come on when driving up a hill or over bumps. The bend meant I could securely mount the switch and still get the angle. With the 3/8 clamps on the pen, it's snug but I can still swivel it in case i need to still get the lights to go on with the truck facing downhill.
    Switch solders
    ALWAYS fuse your circuits, no matter how small the amp draw!
    I wanted the lights to stay on even if I disconnected the battery from the rest of the truck, not the most elegant solution but it worked perfectly, an electrician would know these as 1/2 inch conduit nuts.
    (Yes that is a can of Monster that I used as a little platform to hold the wire :) )
    Lights on and all is groovy.
    Now I just had to wait another hour and a half for darkness till the final result! The pics are a little misleading, it's actually pretty bright, I was able to work on some other stuff without any other lights needed.
    Oh and what was I working on waiting for night to fall?
    Moar blue LED's this time I mounted two pods under the hood scoop for moar evil blue glow coming from the hood.
    Everything on all at once and my alternator groaning under the strain :)
    Come to the light!
    At the end of my driveway 80 feet away
  2. Jul 5, 2013 at 5:54 AM
    dan33900
    dan33900 Well-Known Member
    Dan
    Maumelle, Arkansas
    2009 DCSB 4X4 MGM
    Nice.
  3. Jul 5, 2013 at 6:49 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Looking good!
  4. Jul 6, 2013 at 10:24 PM
    acdronin
    Bumpity bump, finished the install:D
  5. Jul 6, 2013 at 10:52 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Looks good Chris! I like the idea of doing something so that if you need to disconnect the battery you still have light. Good going!
  6. Jul 6, 2013 at 10:53 PM
    babytruck
    NorCal
    So when are you going to do the puddle lights? If it's this week, I want to come learn please?
  7. Jul 6, 2013 at 10:54 PM
    acdronin
    Not sure if I'm gonna have the time before I go on vaca, might save that for the Mod Day
  8. Jul 6, 2013 at 10:58 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Ya but what are you going to do when it is -37.894 degrees Fahrenheit and the mercury freezes? :D
  9. Jul 6, 2013 at 11:00 PM
    acdronin
    Ain't gonna happen:cool:
  10. Jul 6, 2013 at 11:04 PM
    babytruck
    NorCal
    The front lights are reflecting blue, they do not actually shine blue as this pic shows.
    Plus they are not on when driving. And that SHOULD make a difference.
  11. Jul 6, 2013 at 11:05 PM
    babytruck
    NorCal
    If it's hella hot on Mod day, I'm going with you to BAMF. I can't be in 90-100 weather for 12 hours.
  12. Jul 6, 2013 at 11:05 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Bravo. If you hit the gas hard enough, do the lights come one?
  13. Jul 6, 2013 at 11:08 PM
    acdronin
    Haven't driven yet, but how the heck would I be able to tell from inside the truck while it's moving by myself?
  14. Jul 6, 2013 at 11:50 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    In the daylight, you'd never know. But at night - you might get an unexpected "close-encounters-dead-aliens-hidden-in-the-engine-compartment-glow"
    Or, you could deploy an unneeded small child to hide in the engine compartment while you're running. No, that's cruel. You'll have to use a specially trained cat.
    I better get off the internet before I get myself into trouble. :p
  15. Jul 6, 2013 at 11:53 PM
    acdronin
    Kinda like the Cat idea:rolleyes:
  16. Jul 7, 2013 at 4:50 AM
    Tbird
    Tbird Well-Known Member
    Tom
    Santa Teresa, NM
    05 4X4 TRD Sport Access cab (white)
    ICON Ext.trav coilovers, rear ICON w/res. TC UCAs. All-pro 3" leafpac & U-bolt flip kit. Konig Countersteer offroad wheels. Goodyear Durtracs 260/75/16. Blacked-out badging, BHLM, Extra D-rings, Satoshi grill, SockMonkey "All Terrain" decals, Avid Off-road light bar and rock rails, Wet Okey seat covers. Weathertech digital fit floor mats. GROM ipod interface.
    SWEET...very nice job on that! Gonna have to copy. :D
  17. Jul 7, 2013 at 5:06 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Wow, nice job! I really love all the lighting on your truck it looks awesome
  18. Jul 7, 2013 at 7:45 AM
    acdronin
    Thanks Guys!
    Oh ye of little faith!
  19. Jul 7, 2013 at 8:11 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Good stuff!
    Question why the mercury switch? Considering the potential mercury contamination of the engine compartment after an accident?
  20. Jul 7, 2013 at 8:15 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Just wondering if the lights come on when 4wheeling and bouncing around over rocks and such?
