Under the seat subs
Discussion in 'Audio & Video' started by stormtrooper37, Oct 23, 2011.
  1. Oct 23, 2011 at 5:10 PM
    stormtrooper37
    stormtrooper37 [OP] N
    Toytec 2.5 Bilsteins Tint Rims Tires Exhaust
    Does anyone know of a sub woofer that will fit uder the front seat ?
  2. Nov 8, 2011 at 7:27 PM
    the yota is here
    the yota is here Member
    Brandon
    3 inch lift two 10" subs 33" tires
    what year truck?
  3. Nov 9, 2011 at 5:18 AM
    stormtrooper37
  4. Nov 9, 2011 at 5:36 AM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
  5. Nov 9, 2011 at 6:20 PM
    TRDSport17North
    TRDSport17North 06SR5,17TRDSport,22TRDSport
    Al
    Ontario Canada
    22 TRD Sport D/C L/B Premium
    Oem LEDs Heads and Fogs, Interior and exterior LED's, Tonneau Cover, Tint, Running Boards, decals overlays and inserts, Bed mat and lighting, Mats, Speaker upgrade, amp, powered sub, Dsp. Meso Stage 1 tails. Complete front end Expel paint protection, ceramic coated, rust protection, 265 70 17 Cooper at3 4s on 17" OEM Sema Pro wheels. More to come...
    Just installed the Sound Ordnance B-8PT under my passenger seat in my 06 Access Cab. I originally had it on the floor behind the passenger seat, with the jumper seat when folded forward hides it petty good also. But to get it fully under the seat you you need to take the seat out and re-position the seat support bar up and out of the way. There is screws holding it (the bar) into place, a bit of a chore getting to the screws but much easier than trying to bend it out of the way. Cheers Al
  6. Nov 9, 2011 at 6:35 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I started to put my SO B8PT under the driver's seat but I decided it was easier to just put it behind the rear seat. Still sounds good, but I might try to move it up under the driver's seat at some point. I know other folks have done it, but I'm pretty sure they take out the seat to do so.
  7. Nov 10, 2011 at 5:50 AM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    Taking out the seats only takes about 3 minutes (not exaggerating) and involves four easily accessed bolts and one (passenger) or two (drivers) quick release electrical harnesses.
  8. Nov 10, 2011 at 6:31 AM
    stormtrooper37
    sweet how does sound ordanance sound
  9. Nov 10, 2011 at 7:09 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Kenwood. I have one under the driver's side seat. It adds bass, but don't expect a big punch.
  10. Nov 10, 2011 at 8:05 AM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Be careful if you re-position that bar...when I did it it affected my passenger side airbag. The bar's position made it so the airbag would only come on when the person in the seat was 200lbs or more!
    My gf didn't like driving around with me without the airbag on, so i put the bar back the way it was and now the airbag works again...and the bar rubs on my amp when I move the seat. It seems that the bar in the up position prevents the passenger from activating the air bag sensor...There are more threads on this issue if you search it. Some people have had no problems...but I did when I tried moving that bar.
  11. Nov 10, 2011 at 8:16 AM
    crazyjeys
    crazyjeys Well-Known Member
    SoCal
    2018 TRD Off Road 4x4
    noob question: can i install a powered sub on my stock 02 taco radio or do i need a new HU?
  12. Nov 10, 2011 at 8:48 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Yes, you can do it with the stock radio, but you would be better off with an aftermarket HU. You would tap into one of the speaker wires and wire it to the amp's high input. Preamps from an aftermarket HU would eliminate the noise.
  13. Nov 10, 2011 at 5:07 PM
    TRDSport17North
    Al
    Ontario Canada
    It is up and towards the back rest on a 45 degree angle with no issues. I think it is just for support for the seat myself, maybe a big ass stopper! there were no wires attatched to it or to the brackets holding it that i saw. The harness is more of a issue i would think, i moved it also around a bit. I would think it senses someone in the seat for seat belt reasons, and then the seat belt being used would trigger the airbag sensor to work i think.
  14. Nov 10, 2011 at 5:15 PM
    Polymerhead
    Missouri
    Pretty clean and tight if you don't try to over power it. It's an 8", and won't sound like two 12" subs no matter what you do to it. The wired dial remote is nice because you can tweak the sub for each new song or album on the fly.
  15. Nov 10, 2011 at 6:37 PM
    TRDSport17North
    Al
    Ontario Canada
    Yes i am very happy i went this route too Poly!
  16. Nov 10, 2011 at 7:11 PM
    stormtrooper37
    i found one that is a ten im currently trying to sell my 2 12s and the amp no hits tho
  17. Nov 12, 2011 at 7:32 AM
    tombiosis
    T
    Ottawa Canada
    45 degree angle should work...I had it straight up, which prevented the seat cushion from going low enough to activate the sensor. The seat belt clip has nothing to do with it...the airbag needs to see at least 80lbs to come on, that way it won't come on with a small child there.
  18. Nov 12, 2011 at 9:51 PM
    krudawg
    krudawg Well-Known Member
    Ted
    Goodyear, AZ
    06 PreRunner V6 SR5
    Check out the underseat sub from Focal. I have one in my '06 Pre Access Cab. I like it. If you are looking for something to thump the daylights out of everyone within 20 feet - look elseware. This sub is a powered sub and will ad bass to your music but the guy sitting next to you at the light probably wont be able to hear it.
