Underbody rocker protection
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacowin1013, Feb 24, 2025.
  1. Feb 24, 2025 at 5:41 AM
    Tacowin1013
    Tacowin1013 [OP] Well-Known Member
    2017 OR DCSB 6MT MGM
    What are you guys doing now other than mud flaps to protect this area? I already have frame sliders that protect most of the underbody, just the immediate part behind the wheel. Was giving my truck a thorough after winter cleaning yesterday since it was a bit warmer and saw a couple rock chips underbody rocker---nothing major, i sanded it slightly and put some touch up paint, but i want a more solid solution...I'm sure i could use POR 15 and paint it on down there or at least on the bottom part of where the metals join...thoughts?? What are ya'll doing to keep this area rock and rust free?
    **Yes i know theres tons of threads on this, but most of them i've found are 5-10 years old so im just seeing if there's a newer product you guys are using or have found that works well!**
  2. Feb 24, 2025 at 5:44 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    POR-15 is excellent stuff IF and only if you are extremely thorough with surface preparation. Otherwise it tends to let rust creep underneath, like powdercoat can do.
    You would probably be best served in that area by masking a line and applying Woolwax Hard-On. It's not crystal clear, but that area is not visible unless you are underneath the truck.
    Old metals and Tacowin1013[OP] like this.
  3. Feb 24, 2025 at 5:51 AM
    Tacowin1013
    Yeah, i definitely don't need a clear, even with MGM---you can't really see the black there, nor would I care if you could--i'd rather it be rust free. Thanks! I had no idea wool wax made a product like this---i've used a handful of frame coatings like CRC rust inhibitor and FF. Looks like you just paint the hard-on. Odd name for a product... lol
    deanosaurus[QUOTED] likes this.
  4. Feb 24, 2025 at 6:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    For prevention I just run longer flaps than OEM, RokBlokz XL. They're similar length as 2nd gen OEM flaps, but more flexible. I've dragged them over rocks on trails for 5 years now.
    IrishRed and Chew like this.
  5. Feb 24, 2025 at 9:21 AM
    Old metals
    Old metals Well-Known Member
    02 x-cab 4x4 2.7 2018 TRD Sport 4x4 3.5
    Original
    Wool-wax hard-on for the win. Super impressed with that product.
    deanosaurus and Tacowin1013[OP] like this.
  6. Feb 24, 2025 at 1:53 PM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    I noticed the same condition on my truck. I touched up the chips like you did, and then purchased and installed a set of second gen running boards. The boards do a fairly good job of protecting the rockers. I still have a few chips that I have to touch up every fall right before I re-apply my Surface Shield.
    Tacowin1013[OP] likes this.
  7. Feb 24, 2025 at 3:43 PM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    I live back a mile long lane covered in 2B limestone, I’m often on gravel roads, and they use cinders on our roads here in the winter. So, my rockers feel your pain.
    I too have Rokblokz XL flaps installed and they do a pretty darn good job at minimizing the damage. However, chips are still inevitable.
    I’ve been contemplating having a local shop spray that area with Rhino Liner or Line-X. I’ve seen others do this as well and seems like a solid solution.
    Tacorific likes this.
  8. Feb 24, 2025 at 5:25 PM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    Will bedliner get chipped and allow moisture to get behind it I wonder?
  9. Feb 24, 2025 at 6:04 PM
    IrishRed
    Central PA
    I suppose that is a valid concern. However, that is some pretty tough stuff. From the abuse I’ve seen Rhino Liner & Line-X take in truck beds, I’d lean towards believing that it would hold up just fine.
    Rhino Liner is more “rubbery” than Line-X so it may be able to absorb the stone impacts better without chipping or flaking. Like so many types of paints and coatings, success hinges largely on the quality of the prep work.
    I’ve seen numerous people spray their rockers with various bed liner products and I haven’t heard of any ill effects. However, I’m always open to being educated by those more knowledgeable than myself.
    Finn-2187[QUOTED] likes this.
  10. Feb 24, 2025 at 6:17 PM
    InThePlains
    InThePlains Well-Known Member
    Mine got washed 3 times a week during the salt season at the local drive through car wash, so far so good.
    $40/month unlimited, including under carriage wash. I can wash it 10 times a day, they wouldn't even care.
  11. Feb 24, 2025 at 6:24 PM
    IrishRed
    Central PA
    Keeping the salt off with frequent washes is definitely a smart move. However, OP is also concerned about preventing rock chips. Unfortunately, no amount of washing can do that.
  12. Feb 24, 2025 at 7:01 PM
    Finn-2187
    Thanks, I didn't know there were any real differences, that's helpful. I'm also contemplating this issue.
    IrishRed[QUOTED] likes this.
  13. Feb 24, 2025 at 7:07 PM
    IrishRed
    Central PA
    The vehicle I had prior to my Tacoma was a 2010 F-150. I had the bed Rhino Lined by a local shop that does really nice work, & I used it fairly hard. That truck, as a whole, was the biggest disappointing p.o.s. I’ve ever had the pleasure of owning. However, when I traded it in on my Tacoma, the bed was still in perfect shape despite the abuse I subjected it to over 7 or 8 years of ownership.
  14. Feb 24, 2025 at 7:53 PM
    Tacowin1013
    Yeah I'd be concerned with any rubber coating trapping moisture like those rubber frame costing sprays, all it takes is a chip to allow moisture in...
  15. Feb 24, 2025 at 7:56 PM
    Tacowin1013
    Grew up in the Midwest so I'm all too familiar with salt and how shitty it is! I've treated the underbody and frame from day 1 so it's pretty damn immaculate for 80k miles and 8 years old! But no amount of fluid film, cosmoline, or any barrier spray will prevent a rock chip that exposes bare metal! I do agree that frequent washes help.... I take mine to a self spray wash and spray it down weekly
  16. Feb 24, 2025 at 8:12 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the second gen running board gives alot of protection
  17. Feb 25, 2025 at 5:14 AM
    Tacowin1013
    I have these: https://www.amazon.com/Tyger-Auto-TG-AM2T20048-Textured-Running/dp/B01AH5IEO6?th=1 I put them on the first week i had the truck in 2017 and its been on since. Last summer i took them off and sanded/resprayed them since the underside was starting to rust out. I coated it with POR 15 and repainted them. It should last me another 5 years or so before i need to get a different set
    RIX TUX[QUOTED] likes this.
  18. Feb 25, 2025 at 8:53 AM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    Put me in the camp that would avoid any "permanent" coatings at all costs if you're trying to avoid rust. Can it work? Absolutely, but IMO there are too many variables that could lead to it accelerating rust rather than preventing it. Personally I would just touch up the area yearly before applying fluid film or whatever other non-permanent rust preventative. Gives you a chance to inspect everything and see where the chips/rust has started, any permanent coating takes away the inspection portion and puts blind faith in the product applied until it's too late. I used POR-15 on my bedsides when I cut for my high-clearance rear bumper but I spent hours prepping it due to my rust paranoia. I also run the Rokblokz mudflaps in the front and they help a ton. I wonder if there is some sort of clear coat you could apply? At least that way you could see if bigger issues were lurking underneath. I also don't know if I would apply anything on the joints/seams of the pinch weld, that seems like it's asking to trap moisture.
  19. Feb 25, 2025 at 9:07 AM
    Tacowin1013
    That's always been my general stance as well---in terms of being able to visibly see it and stay proactive. As far as clear coat, i use this... https://www.lexuspartsnow.com/parts/lexus-clear-coat~00258-0000c-21.html?gQT=2 --- I'm not sure how much "protection" it provides, but i generally touch up with factory paint pens x 2-3 light coats, and then apply 1 or 2 clear coats on top and it blends in pretty well...
    TacoGranny[QUOTED] likes this.
  20. Feb 25, 2025 at 9:58 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Mud flaps, running boards, and fluid flim, wool wax, or surface shield, in the rocker access plugs, and down pinch weld area. You need to stop the chips first, that is what allows the moisture and salt to start the corrosion process. Ski
