Undercarriage Corrosion Protection Services - Winchester, VA Area
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Captains1911, Nov 11, 2022.
  1. Nov 12, 2022 at 5:40 AM
    #41
    old.shopteacher
    old.shopteacher Active Member
    2022 Tacoma TRD Sport AC MT
    I use Krown. I guess that it is a Lanolin based product. Cost me about $160 for the first application. Reapplied yearly after that. $500 seems pricey to me. Have used it on all of my vehicles for the past few years & am very satisfied with the results. I live in a heavily road salted area & it really works.
  2. Nov 12, 2022 at 5:49 AM
    #42
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I think painting a boat with that anti fouling paint can be worse depending how big the boat is. I use to do my 19' one when i use to fish the ocean....lousy job.
  3. Nov 12, 2022 at 5:51 AM
    #43
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    Do you really need to protect it? Your truck is under warranty. My guess is, if you don’t want the hassle of spraying the frame with some goo once a year, you won’t want the hassle of anything else that might arise out of warranty. If you really care about the vehicle and want to keep it a long time, you will do what’s needed to take care of it. If you are going to take it to a mechanic every time it needs washer fluid, then I say just drive it for a couple years and trade it in when it’s out of warranty.
  4. Nov 12, 2022 at 5:59 AM
    #44
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Hey op, I understand not wanting to DYIl it’s a messy nasty job. not hard, but nasty. That said, I wouldn’t run it naked either, these trucks rust!
    I only DYI because I am in California and there are no services near me.
    If I were in your shoes I would drive to NH oil, get it done while having lunch, and drive back.
    If you are not willing to do that plan on trading the truck after 4. Winters and buy new. Nothing wrong with that either.
  5. Nov 12, 2022 at 7:26 AM
    #45
    Captains1911
    Captains1911 [OP] Well-Known Member
    2023 Tacoma TRD OR 4x4 AT DCSB
    I think I might just take it to the nearest Krown which is 2 hrs away. $160 seems reasonable. They don’t make on oily mess anywhere on the outside of the car do they?
    10thMTNgrunt likes this.
  6. Nov 12, 2022 at 7:28 AM
    #46
    Lando_Landician
    Lando_Landician Member
    2022 Tacoma TRD OR DCSB LR
    They give it a wash after the application, it will drip and seep off the frame onto your driveway after the application for several days.... so don't park it in your living room.
    Durango95 likes this.
  7. Nov 12, 2022 at 8:14 AM
    #47
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    Like everything, the tools make the job.
    With a lift or good ramps, spraying the truck is fairly easy. Same with painting a boat on stands.
    Lying on your back with the boat on a trailer and your nose an inch away from the hull, that sucks.
    In the OP’s situation, given the closest local guy is charging about 2.5X the going rate, I’d invest in good ramps and equipment to do it myself.
    Is there a regional VA sub forum? I’d bet there would be a crew of locals interested in having their trucks sprayed. The OP could probably find a guy willing to spray his truck for him too.
  8. Nov 12, 2022 at 8:16 AM
    #48
    Captains1911
    I just read that they have to drill holes…not sure I like that…
  9. Nov 12, 2022 at 8:19 AM
    #49
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    I used Automotive Protection Services in Fairfax for the last 2 yrs. Under carriage looks great. Was worried about this in general and all the reviews about trapping moisture and creating hidden rust. They use nuxodol which seems good. They also have rly knowledgeable staff and do good work.
    Oh and I go back annually for a touch up for about $60 which keeps the warranty for ten or so years.
  10. Nov 12, 2022 at 8:21 AM
    #50
    Lando_Landician
    Yes, they drill a 1/4" hole in the doors to stick the wand in to spray the panels. They will put a plastic plug in the hole afterwards, it looks factory. When you go back for a re-application, they can just pop those plugs out and reuse those same holes.
    Drilling holes in a new truck seems daunting, but it's part of the process. Like I stated earlier, if your vehicle is new you will get a lifetime corrosion warranty (with yearly re-applications)
    Here is what they do: https://youtu.be/WgvL40QefZ0
  11. Nov 12, 2022 at 8:26 AM
    #51
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's a big nope considering that the holes won't be primed / painted afterward. You'd have to put a big bet on the protection of the fluid.
    Durango95, MadKatt and usmc2msu like this.
  12. Nov 12, 2022 at 8:28 AM
    #52
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is interesting as all the clean up that I needed afterward was barely a hand wash. Loving the WW scent. It is almost like new car smell and not strong at all. I'm somewhat sensitive to odors, like perfume, candles, and such.
    usmc2msu likes this.
  13. Nov 12, 2022 at 8:29 AM
    #53
    Lando_Landician
    They put some type of grease on the hole before popping that plug in, so it will not be rusting there.
  14. Nov 12, 2022 at 8:34 AM
    #54
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but that would not work for me. I've painted and RTV'ed the few holes that I have drilled and we really don't have a corrosive environment here.
    Just my own feelings there.
  15. Nov 12, 2022 at 8:43 AM
    #55
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    I believe it is an oil base that it tar like. It never gets real hard and can be scraped with your finger nail. It is good to keep an eye on it and do touch ups every once in awhile. By me they will wash your underside and do touch ups for $60. Give them a call and ask any questions or better yet go see them and have them show you also.
  16. Nov 12, 2022 at 8:51 AM
    #56
    Gatafly
    Shawn
    Ziebart does not use a rubberized undercoating. It is oil based and has a tar like finish that can be scraped with a finger nail. I used Ziebart years ago and again on my Taco. I would have done it myself, but I wanted all the insides of the doors, fenders, rockers etc done well and I just did not have the time or space to really do it right.
  17. Nov 12, 2022 at 9:06 AM
    #57
    Lando_Landician
    Awesome, I couldn't tell from the pics on their website, and the video said "abrasion resistant material". Thanks for clarifying.
    Gatafly[QUOTED] likes this.
  18. Nov 12, 2022 at 9:51 AM
    #58
    Captains1911
    Do people choose to forgo the inside the doors treatment, eliminating the need for any drilled holes? I’m more interested in protecting the underside of the truck, not inside the doors.
  19. Nov 12, 2022 at 11:15 AM
    #59
    Lando_Landician
    I don't know if that's a common request or not.
    Your best bet is to call and ask them directly.
  20. Nov 12, 2022 at 11:31 AM
    #60
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I just spray the frame and suspension yearly and leave the body alone. If you decline the inside the door treatment at a shop, they will likely decline to give you a warranty, which would be fine with me.
    Lando_Landician likes this.
