Undercarriage Protection / Rust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by emtlibby, Feb 27, 2010.
  1. Feb 27, 2010 at 11:19 AM
    emtlibby
    emtlibby [OP] Slaughtering goats
    Boston, MA
    2010 4x4 DBLCAB
    Anybody use any products to protect the underbody/frame? I know there are commercial treatments, but I have access to a lift, so if there was some kinda grease or something I could spray on there, it'd be sweet. Anyone:confused:
  2. Feb 27, 2010 at 11:20 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Sand it down and hit it with a good coat of rustoleum black paint. It is a pretty good preventative.
  3. Feb 27, 2010 at 11:30 AM
    PreRunner
    PreRunner Well-Known Member
    got the toyoguard package thrown in for free, which includes undercoating. is it worth a damn?
  4. Feb 27, 2010 at 11:33 AM
    badguybuster
    Michael
    anything is better than nothing...right?
  5. Feb 27, 2010 at 12:02 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Sometimes...There's also the thinking that if water gets trapped behind the undercoating from cracks and rock chips you won't see the rust. I'd rather see it ahead of time and hit it with rustoleum like you mentioned.
  6. Feb 27, 2010 at 12:06 PM
    rendertrust
    rendertrust Member
    Line-X ?
  7. Feb 27, 2010 at 1:35 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Carwell.
  8. Feb 27, 2010 at 2:01 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    I didn't get the undercoating...read a couple good tips here on TW though:
    - Use a lawn sprinkler and shove it underneath the car every now and then to rinse the salt/grime off
    - When spring hits, go under your truck (lucky if you got a lift) and hit the rusty spots with a wire brush/sandpaper then paint w/ Rustoleum
    This is what I plan on doing to prevent my frame from being ruined by rust.
  9. Feb 27, 2010 at 2:30 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    I just got mine undercoated professionaly. In chicago winters rust WILL form. No matter how preventative you are.
  10. Feb 27, 2010 at 2:48 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Got mine profesionally done by a shop that uses krown rustproffing. Fortech will be a good one to ask. Did a great job on my truck.
  11. Feb 27, 2010 at 3:29 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    You'll laugh but go buy 4 cans of WD-40. Spay the undercarriage good and drive it. This spring get a pressure sprayer and wash down the undercarriage. In the fall, pressure spray and hit it with WD-40. Repeat the process in the fall. It takes about 15 miinutes to spray with WD-40 and 15 minutes to pressure wash. It's that easy and seems to work.
    The WD-40 eats rust, surface coats metal, and loosens dirt. I've done this for a year now and afte I pressure spay, the undercarriage looks great. In Maryland we've had a ton of snow this winter. With the snow came tons of salt and chemicals on the roads. I did an extra treatment of WD-40 just because...
  12. Feb 28, 2010 at 12:12 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Hmmm, I might try that. Makes sense... WD-40 might be a little thin though...
  13. Feb 28, 2010 at 3:27 PM
    oldsman71442
    oldsman71442 Well-Known Member
    Jeff
    oahu HI/ Redding CA
    10 DC 4x4 TRD Sport
    There is a product out there called ACF50. It is amazing.... It is what they use in aircrafts to help prevent corrosion and rust. It is quite a bit thicker than WD40 and it stays where you spray it. We use it at work to spray behind and under all the deck plates on the aircraft and every time we pull them up they look brand new. Our planes are 80's vintage and everwhere we spray the stuff its like brand new.... highly recommend. Apply it twice a year or so. Works great now where to buy it? search the internet not to sure of any vendors off hand but i am sure you can get it
  14. Feb 28, 2010 at 3:37 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
