Undercoat question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jesusc, Oct 18, 2011.
  1. Oct 18, 2011 at 6:25 PM
    jesusc
    jesusc [OP] Well-Known Member
    06 access cab sr5
    Do any of you guys have a apart on undercoat if so what do you recommend? Trying to prepare for winter
  2. Oct 18, 2011 at 6:32 PM
    fjrmurph
    fjrmurph Well-Known Member
    Rust Check
    I do this every fall. I live in Eastern Canada they user a lot of salt on the roads here+ i installed "Counter Act" rust control module, its elactronic. Some say it works some say it doesn't, i look at it as extra insurance
  3. Oct 18, 2011 at 6:37 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I recently sprayed my frame. I got under there with a wire wheel and ground off flaky sections and then went over it in rust-oleum spray paint. Once that dried I painted on a layer of wax-oyl and I must say I really like the stuff.
  4. Oct 18, 2011 at 6:39 PM
    jesusc
    06 access cab sr5
    How good is the undercoat spary from a auto parts store?
  5. Oct 18, 2011 at 6:40 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Krown. No question.
  6. Oct 18, 2011 at 6:40 PM
    malander
    max
    01 limited trd 4x4
    Depends on the brand. I wouldn't go with anything that's suppose to rubberize the frame or seal the rust in like a line-x or anything.
  7. Oct 18, 2011 at 6:43 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Rubberized undercoating only really works on a virgin frame that has been meticulously prepped and cleaned.
    Oil based yearly treatments seem to be the best option if there is already some rust in place.
    Use a grinder to touch up what you can reasonably touch up, oil the rest of it.
  8. Oct 18, 2011 at 6:54 PM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    Its illegal in Mass for for oil based treatments I believe, but a guy about 20 minutes away just barely into VT does it for people for like 80 bucks, oil based, supposed to be very very good!
  9. Oct 18, 2011 at 6:59 PM
    malander
    max
    01 limited trd 4x4
    Wax-Oyl is about 16 bucks a can and gets rave reviews from the land rover crowd. Just another option and if you do it yourself you know you're getting all the little places that someone else might miss
  10. Oct 19, 2011 at 5:29 PM
    blacktaco07
    blacktaco07 Active Member
    Canada
    2007 4DR Tacoma TRD
    IMO...
    #1...Krown
    #2...Fluid Film
    Krown will drip for about 3-4 days.....if it drips, it means it's getting in the small crevices
    Fluid Film is good as well, no drip but I find it comes off a bit easier throughout the winter
  11. Sep 29, 2012 at 11:52 AM
    bob1008
    bob1008 Member
    Fluid Film undercoating kits are available here:
    http://www.kellsportproducts.com/fluidfilmkits.html
  12. Sep 29, 2012 at 12:01 PM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC
    5100's @ 1.75", Firestone Ride-Rite Air Bags, Extang Solid Fold Tonneau cover, Weathertech digifit floor mats, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521, ECGS clamshell bushing
    How big of a compressor do you need to operate the Fluid Film applicator gun? I only have a cheaper small compressor.
    I am not home now, but I think mine is a 6 gallon probably 2hp compressor.
  13. Sep 30, 2012 at 5:02 AM
    bob1008
    bob1008 Member
    Any small compressor will work fine You only need about 80 - 90 psi to apply fluid film. The length of of hose will cause some variation, but I have never heard from anyone that their small compressor would not work.
    TacomaWorld forum members receive a discount on Fluid Film orders. Just enter coupon code "tacoma" at checkout.
  14. Sep 30, 2012 at 5:30 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    While I realize this may not apply to your '06, I was truly amazed after looking around under my 2012. Toyota went almost overboaord at sealing or caulking just about every seam or joint under the truck. Due to that, I made sure to caulk all the accessories (side steps, front hitch, etc) I installed underneath as well. If other recent models years are the same, doubt anyone today would even need an undercoat.
  15. Sep 30, 2012 at 5:51 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    The hard wax type stuff most dealers use is. It cracks and peels and moisture rusts out the frame where no one see it. And most only cover a rust-through. I had that on my first truck, and never again. I spent a month looking at different products before I got our Tacoma, and went with Corr 3000. DND did a study a few years ago and based it off an earlier US military study. It had the best combined results of all major products. Here is a link to a PDF copy, and a link to the Corrosion FREE website FAQ page. The first application lasts for 18 months, and they touch it up at a reduced price every 18 after that. I'm due in next week for my second application, and I've had no issues with the first.
    Frank
  16. Sep 30, 2012 at 7:18 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    100% agree
  17. Sep 30, 2012 at 8:11 AM
    Fightman80
    Fightman80 Well-Known Member
    Capreol Ontario Canada
    05 TRD DCLB Speedway Blue
    Tinted Tail lights, Nerb Bars, Tonneau Cover, Vent Visors, Hood Deflector, Foglight/highbeam mod, Custom homemade grill, Carbon Fibre Interior.
    I know this isn't going to be a popular statement, but here goes! HA HA! I've been rust proofing my vehicles since 2000, using nothing more than used motor oil from my oil changes. I use an air compressor and undercoating gun, lay a plastic on the floor of the shop, drive the truck on it, and spray the entire underside of the truck with it. I've also drilled holes into the doors, and rocker panels, and remove the headlights and tail lights in order to reach inside the fenders of my vehicles. I've done my 95 Monte Carlo, my 98 4Runner, my 2004 Impala, and plan on doing my 2005 Tacoma using this same method. Is it messy? YES! Is it cheap? YES! Does it work? YES!If you don't have a garage, or the tools to do it, Crown is a great alternative. I've paid to have it done once, then decided to start doing my own.... never looked back!;)
