Undercoat & Rustproof ?'s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mich3210, Oct 29, 2010.
  1. Oct 29, 2010 at 11:47 AM
    mich3210
    mich3210 [OP] Well-Known Member
    Dan
    Upstate NY
    2012 MGM DCLB TRD Sport 4x4
    Well, I talked to the dealer this morning and they are supposed to be working on getting the truck I want. That being said, I want to get it undercoated ASAP. The dealer is offering me the undercoating and rustproofing "at dealer cost" of $500. Or I can take it to Ziebart to get it undercoated for $400 or get their undercoat and rustproof for $600. I can take it back to Ziebart yearly for free touch ups.
    My questions are... which is probably the better product, Ziebart Undercoating or the Dealer Undercoating? With the rustproofing they spray a substance in the body and door panels. Does this actually work or am I better off not doing this one?
    Thanks!
  2. Oct 29, 2010 at 11:53 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I got both the undercoat and rust proof and sound proofing on my Taco in Feb.
    all i can say is, Too early to tell for undercoat and rust proofing but the sound proofing they put in the wheel wells is worth every penny if you do alot of highway. Makes the road noise nice and quiet
  3. Oct 29, 2010 at 12:04 PM
    mich3210
    Dan
    Upstate NY
    Did the dealer actually do it or did they send it out? The dealer I'm working with does it in-house, where as most of the other dealers send their work out to Ziebart.
  4. Oct 29, 2010 at 3:22 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Personally, I wouldn't undercoat. What some say is true...it's almost impossible to undercoat every nook and cranny under there that is prone to rusting. Also, if it does rust under the undercoating, you wouldn't be able to see it until it gets really bad.
    But since you're set on undercoating I think that Ziebart's would be a better choice. They would probably do a better job than the dealer and the yearly free touch ups would be a plus.
  5. Oct 29, 2010 at 3:45 PM
    mich3210
    Dan
    Upstate NY
    Are others really against undercoating? I guess I was always under the impression that it was doing good protecting things. I had it done on my current car and it seemed to help. Whereas my parents car is pretty rusty underneath.
    Any and all opinions are welcome. Thanks!
  6. Oct 29, 2010 at 3:53 PM
    808hiker
    Justin
    Big Island, Hawaii
    Well from what I read some people are against the rubberized type of undercoatings since they are porous and can trap moisture between the undercoating and frame, which would speed up the rate of rust.
    I personally gave much, much thought to undercoating my own truck but in the end I decided to just leave it as it is. At least this way, I can see the rust and fix it accordingly.
  7. Oct 29, 2010 at 3:58 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I got my truck undercoated at the dealer. Very good job.
    Probably not worth what I paid but still good. Can't remember what I paid for it exactly...too much is the only real answer.
  8. Oct 29, 2010 at 3:59 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Dealer done in house by Platinum Mitsubishi in Calgary, they also did a full detail looked perfect top n bottom when i got it. Yes I actually crawled underneath :D and i've got an X-Runner, no easy task that is.
  9. Oct 29, 2010 at 4:18 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I also decided against it mainly so I can see what's going on and fix it accordingly. Also, it's nice to be able to get to every nut and bolt if needed. I'm sure if I lived in a area that used salt in the winters I'd use something to help protect everything, but I'm in a desert enviroment where they use lava rock when it snows. I just get under the truck a few times a year and clean, then do touch-up with rustolem (mainly just around some of the welds.) So far in 3 years the only thing that's rusted is the muffler...but that's to be expected.
  10. Oct 29, 2010 at 7:22 PM
    mich3210
    Dan
    Upstate NY
    Thanks for the input everyone. I'm really torn on what to do. I want to protect it, but I don't also want to increase the probability of causing rust problems by trapping in moisture.
  11. Oct 29, 2010 at 7:45 PM
    Mr.Tacoma
    Mr.Tacoma Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    If its a New truck i dont see why not. After a year or two you can start spraying Krown oil spray for RUST proof..my 2C.
  12. Oct 29, 2010 at 8:22 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Problem is there is not enough paint on the frame and underside. So undercoating bare metal is really not the best idea. Undercoats dont contain rust inhibitors which is the item needed most in order to protect metal.
    You can spray them but there is really nothing to hold on to for undercoats so its going to be yearly ordeal probably.
    If you can buy some farmer grade primer and paint and paint it first. then when is dry spray with undercoat.
  13. Oct 29, 2010 at 8:46 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Get it sprayed with Krown undercoating. To date, Krown is the best undercoating substance I've come across. It's not a rubberized compound, rather a proprietary oil-based blend which "creeps" on metal surfaces, actually moving around corners, into seams, etc... It's amazing stuff. Now, it needs to be re-applied annually, but $130/yr. is cheap insurance for rust proofing.
    TA 4 likes this.
  14. Oct 29, 2010 at 9:00 PM
    mich3210
    Dan
    Upstate NY
    Only way to apply Krown is if I do it myself, which I'm thinking about. There are no Krown dealers in the States that I can find.
  15. Oct 29, 2010 at 9:05 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Look up Carwell. Its our version of Crown.
  16. Oct 29, 2010 at 10:50 PM
    mich3210
    Dan
    Upstate NY
    Closest one is over 2:30 minutes away.
    Decisions, decisions... do nothing, have Ziebart undercoat it or try to protect it myself with something like Carwell and clean/prime/paint yearly.
  17. Oct 29, 2010 at 11:58 PM
    UrbanAngler
    UrbanAngler Member
    BOSTON
    05 D-CAB
    If i were you, I wouldn't loose too much sleep over it. I have spent alot of time thinking about the rust on my frame, but when it comes down to it, it is just the frame of your truck. do what you think you should do, and if it rusts, it rusts. if it doesn't, even better.
    I use a wire brush and some rubberized undercoating every year, although i only did it once, and looking at the calender, it's about time for a fresh coating. If the rubberized isn't the best idae, then screw it, at least it looks good, and I don't see any rust, which gives me the peace of mind.
    Also, if the frame does rot out, then at least toyota will have our back, at least they did with the first generation.
    good luck
  18. Oct 30, 2010 at 3:22 AM
    WNYTACOMA
    Clarence, New York
    For the money you pay for the trucks, or any behicle for that matter, its the smart move. I wouldn't listen to the guys who say to do nothing. There are plenty of pictures around here of people who do 'nothing' and i wouldn't want my vehicle looking like that if i can do something about it. Living in NY, you know waht the salt does to anything driven on the roads. ...and it will help when you re-sell it it it doesn't look like shit underneath.
    The Carwell process only takes about an hour or so. Do it when its new and before the salt flies. Make a road trip out of it. Take your girl to lunch in teh area. The 2.5 hours will give it a chance to drip elsewhere other than your driveway. For about $130.00, and the cost of gas you will have a year to think about whether you want to keep doing it. You could always get the stuff to do it yourself after the initial application.
    yesmar likes this.
  19. Oct 30, 2010 at 3:30 AM
    Black Sheep
    Black Sheep Well-Known Member
    Jeff
    Pittsburgh, PA
    2011 Black Dbl Cab TRD T/X Pro
    6" Pro Comp Suspension lift with Pro Comp leveling kit, Bilstein 5100's, Full leather interior with seat heaters, Go Rhino step bars, Sony XNV-770BT Head Unit with NAV, DVD, XM and Blutooth, Tonopro toneau cover, Tinted windows, Black mesh grille, Projector headlights with HID lows, HID fogs, Crystal Eyes rear LED taillights, Weathertech mats front and rear
    I pick up my new Tacoma later today. I had them throw in the rustproofing and undercoating package. They had the truck taken yesterday to have it done. I live in Western PA and the salt that is on the roads in the winter is terrible. I want my frame to last more than a couple of years.
  20. Nov 9, 2010 at 4:26 PM
    ryguy
    ryguy Well-Known Member
    Riley
    Central California
    06 Silver Double Cab 4x4 TRD Sport
    What do you guys use to do touch ups on the rust? i have heard of sprays that you can use that actually reverse the chemical process of rust and turn it back into something stronger than what it was origionally, however i have no idea what it is called, what are you guys using and if you have heard of what i am talking about what is it called? thanks
