Undercoating beware
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Germoktrd, Feb 8, 2016.
  1. Feb 8, 2016 at 6:49 PM
    Germoktrd
    Germoktrd [OP] New Member
    2005 Tacoma crewcab trd sport
    If you get your frame under coated by Toyota and it still rusts out your screwed I have an 05 that was undercoated in 2014 and now its all falling off and it is rusting underneath I have a rot hole in the bottom of my front crossmber the one the front diff mounts to! So I took it to Toyota and they said there is nothing they can do for me! Ounce the initial inspection is done and they decide it just needs under coated that's it a one time deal it either gets a new frame or it gets undercoated so when they under coat it over all the rust it doesn't just magically disappear its still there and it's growing! They said it slows the rusting down oh like that's a great solution to a major problem! Just replace all the frames they know there bad!!!!
  2. Feb 8, 2016 at 7:52 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I'm sure they didn't expect so many issues, they did it as a courtesy, but they keep extending the vehicles affected. So some genius said how about we offer to undercoat people's frames, that aren't that bad yet and make them in eligible for frame replacement down the road. Cost them a lot less and they still think that are satisfying customers. (Which they are until they get pissed that it's not a perminate fix and it keeps getting worse, then they flip shit because they want a frame replacement but now they can't, so all satisfaction is gone at that point)
  3. Feb 8, 2016 at 8:01 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I thought I read somewhere that once you did the inspection/undercoating, they warrantied it for 5 or 10 years.
  4. Feb 8, 2016 at 8:26 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I recall seeing something along those lines too, the OP should probably go visit another Dealer or call Toyota Corp.
  5. Feb 9, 2016 at 2:19 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Doesn't sound right. When my 2002 was recalled and undercoated the warranty was extended to 15 years. Rusting through before 2017 would have gotten me a new frame. Call Toyota corporate and get the real info.
  6. Feb 9, 2016 at 3:59 PM
    Germoktrd
    Well I haven't heard anything about a warranty but I just bought the truck from a gmc dealer so I don't know if the warranty if any is transferable. But Toyota corp said there is nothing they can do for me so I'm guessing not.
  7. Feb 9, 2016 at 4:13 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Undercoating doesn't work when the frame is already rusting out.
    Keeping bugging Toyota and take it to a different Toyota dealer.
    You said you just bought it, did you not check the frame prior to purchase?
  8. Feb 10, 2016 at 9:45 AM
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    I just had mine undercoated at the dealership. A friend of mine who has a 1st gen had his undercoated and 3 yrs later his gas tank fell off. He took it back to Toyota and they replaced the whole frame.
  9. Feb 10, 2016 at 10:05 AM
    tgear.shead
    tgear.shead Well-Known Member
    Either the dealer is lying to you, or they were drunk when they read the recall documentation.
    The way it works, is if you are offered the inspection and the coating, and you REFUSE it, then you FORFEIT warranty.
    If you ACCEPT the coating, THEN AND ONLY THEN, the extended warranty kicks in.
  10. Feb 10, 2016 at 2:40 PM
    Germoktrd
    Yeah I checked the frame before I bought it it appeared to be OK. Only upon detailed inspection did I find the hole. But I will call the original dealer who did the undercoating and see what they say thanks everyone for your input it is quit frustrating to go through all this!
  11. Feb 26, 2016 at 6:24 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Check check check again Any hole in the frame.Mine was on the driver side cab/ body mount by the wheel well.I cleaned it out with a screw driver and kept scraping and chiseling.A hole an only one!I keep my 05 Anally Clean! Ask my friends they told me to marry it!!!!!Wire bushed ground scraped every year had car well spray Krown coating.Yes even por 15 !!!The Shit is in the metal where ever bent cut welded It Doesn't Stop.It is a rust Terminator.It won't stop Ever!!!!!!!!!
