Undercoating new Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaNY11040, Oct 27, 2022.
  1. Oct 27, 2022 at 6:40 PM
    TacomaNY11040
    TacomaNY11040 [OP] Member
    2006 Tacoma SR5 2wd
    Hello I have a 2022 Tacoma bought it brand new first brand new truck I ever got I upgraded from my 2006 Tacoma which I undercoated with fluid film cause the 2nd gen frames are known to rot did they fix the issue on the 3rd gens do you think it’s worth under coating a brand new truck I live in New York
    SilverBulletII, Tocamo and KY_Rob like this.
  2. Oct 27, 2022 at 6:40 PM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    Totally worth every penny. Do it every year.
    Tocamo likes this.
  3. Oct 27, 2022 at 6:41 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Fluid film yes. Undercoating no. There is a huge difference.
    shakerhood, SilverBulletII and Chew like this.
  4. Dec 10, 2022 at 10:56 AM
    Irishblessing
    Irishblessing So Cal Is Where My Mind States
    2023 Tacoma OR
    Elaboration? I have read about people using Cosmoline but that sounds like DIY, I'm looking for something with a warranty.
  5. Dec 10, 2022 at 11:53 AM
    OuchIDied
    OuchIDied Well-Known Member
    2021 Silver Sky Tacoma Off-Road
    He's probably referring to the rubberized undercoating that traps moisture and causes more rust.
    I personally have used Cosmoline with fantastic results. Pretty easy to apply. Doesn't hold onto all of the dirt like Fluid Film. Lasts much longer.
    One place that seems to rust super easily (not that it matters, but for reference) is the rear shock bolts/nuts at the top. I applied Cosmoline two years ago (pretty shoddily) and there isn't a speck of rust. It also makes hardware look Kashima coated if you're a mountain biker and know what I mean.
    hiPSI likes this.
  6. Dec 10, 2022 at 12:10 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I think the only way you'd get a warranty like that was if you bought a contact to have your truck inspected every year, and they would reapply ff or whatever rust inhibiter as needed.
    I'm no fan of fluid flim as its a pita to keep up with it every 6 months here. I used cosmoline rp-342 this time when my truck was new. So far all is still good like the day i did it. I only did a 5 minute touchup between the rear leaf springs. Cosmoline even works better on my tractors mower deck.
    shakerhood and hiPSI like this.
  7. Dec 10, 2022 at 12:13 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Do it, do it!
    But not just the frame, do it all. Save those rocker panels, doors, fenders, etc.... KROWN Rustproofing for the win!
    RotorRPM likes this.
  8. Dec 10, 2022 at 12:57 PM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
    zoo truck and hiPSI like this.
  9. Dec 10, 2022 at 1:08 PM
    DeepFriedTaco
    DeepFriedTaco Well-Known Member
    Teddy the Taco
    2021 MT OR Taco
    I use woolwax basically a thicker version of fluid film with no horrible smell but I’m thinking of giving cosmology a try next year since the woolwax like FF holds all the dirt to it
    SilverBulletII likes this.
  10. Dec 10, 2022 at 1:17 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Undercoating is a petroleum based rubberized coating that is about a sixteenth inch thick. As it fully dries over the years it cracks and salt water gets in behind and starts rusting but you can't see it until too late.
    POR or Cosmolene is a thin coating that protects well but needs to be reapplied every year. You don't need a warranty with this because it works as long as the owner makes sure all surfaces are covered before the first snow.
    The undercoating guys offer a warranty simply as a sales tool. Most of the warranty they offer is 3rd party and by the time the owner notices the rust a few years down the road the undercoating guy is gone or warranty is useless.
    Find a quality shop to coat the underside with Fluid film or POR and do it every year and you won't have a rust problem. Google it.
  11. Dec 10, 2022 at 1:23 PM
    jackbullock79
    jackbullock79 Well-Known Member
    Jack
    2023 Lunar Rock TRD off road
    about how many cans do i need of the cosmoline?
  12. Dec 10, 2022 at 1:41 PM
    robe689
    Bob
    SE Connecticut
    My recollection is that I used 3 or 4 cans.
    jackbullock79[QUOTED] likes this.
  13. Dec 10, 2022 at 2:03 PM
    Walliby
    Walliby Well-Known Member
    Massachusetts
    2023 TRD OR DCSB Auto
  14. Dec 10, 2022 at 2:14 PM
    86_MR2
    86_MR2 Swallow my tranya
    North Chicagoland
    2022 TRD Off Road M/T, Neil Armstrong Edition
    WADR, I don't think you are correct.
    - EDIT: I don't think hiPSI was referring to Cosmoline when he mentioned cracking. I read it incorrectly. I believe he references the rubberized coating that cracks.
    Please refer to "Features / Benefits" on the data sheet: https://www.cosmolinedirect.com/content/Cosmoline-Industrial_Grade_RV_342_TDS.pdf
    - "Film won’t crack or flow from - 40º F to 175º F (-40º C to 79.4º C)"
    CdnSldr did an impressive writeup complete with many photos of his (beyond excellent) job: https://www.tacomaworld.com/threads/rust-veto-342-cosmoline-undercoating.651180/#post-22805203
    - read the whole thread. He references his experience with FluidFilm. Don't miss that part.
    - also, don't miss the part about FF and Cosmoline incompatibility. In short, if you start with FF forget covering it with Cosmoline - you're now committed to FF and its yearly application unless you completely remove it. Good luck with that...
    - you do not need 5 gallons. A single gallon is more than sufficient - if - using a compressor and spray gun (see below). If you use the Smith contractor pump sprayer you might need more than a single gallon. Wasteful!
    Don't buy that noise about Cosmoline not flowing / creeping. It can be thinned with mineral spirits to the point it runs like water. Just takes a little longer to dry.
    - EDIT: the DRY film will not flow. When it is in suspension with the solvent it will, obviously.
    From experience, don't use the Smith contractor sprayer. Yes, it works but the finest spray using the adjustable nozzle is like a water fountain and wastes a lot of product. If you have a compressor, definitely go with the other sprayer Cosmoline suggests on their site. You can find it cheaper at the Chemicar (manufacturer) site here: https://www.chemicarshop.com/undercoating-gun-ra-1t/
    - the wands can be found as an option in the "Unit" drop down box, e.g. RA1T + SWK
    - I initially bought the Smith sprayer and realized my mistake right away. The Chemicar sprayer is the far, far superior option and is actually cheaper in the end due to its efficiency and precision.
    I'm sure FF works but you're gonna be doing it every year. CdnSldr gives an update or two in the above referenced thread and says he only needed to do spot touchups after a year driving on gravel roads. It would be great if he is reading this and would give us another update soon.
    Bottom line is that, whichever you choose, it's a messy, dirty job. It's just a question of how many times you want to put yourself through it.
  15. Dec 10, 2022 at 3:29 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Not all undercoating is rubberized
  16. Dec 10, 2022 at 3:35 PM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    Wool Wax or Fluid Film. Annual recoat. Your undercarriage will be super protected.
  17. Dec 11, 2022 at 5:16 AM
    coopnugz
    coopnugz Well-Known Member
    Cooper
    2022 Black Trail
    This I hadn't considered. I would like to go with Krown eventually but cannot this 1st winter.
    Anyone know if FF and Krown play nice together? I was planning on using FF until I can get around to one of the elusive Krown shops in the US.
  18. Dec 11, 2022 at 6:00 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
  19. Dec 11, 2022 at 7:35 AM
    OuchIDied
    I'm a big fan of CRC's Marine Corrosion inhibitor which is a cosmoline based inhibitor.
    Mines lasted 2 years with no degradation in protection. 3 cans is all it took, but I'm not crazy and spraying the underside of the cab or anything.
    Late Camaro likes this.
  20. Dec 11, 2022 at 11:25 AM
    zoo truck
    None
    6-8 cans will cover 99% of the chassis thats steel with 2 coats. You want to remove the tires, and put the truck on jack stands removing the engine shield, and air dam if it has one. Remove the rear bumper covers, and spare tire to. You want to get inside the boxed frame sections also. I ordered more of it to get inside those rockers in the future.
    Gatafly likes this.
