Undercoating - new to the salt belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skynet Surfer, Sep 25, 2021.
  1. Sep 26, 2021 at 6:29 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Since nobody else has asked. Are you willing to do it yourself or do you want to have it done by somebody else? I live smack dab in the heart of the rust belt, so I can offer sage advice, but I need to know these answers first.
    tacotoe likes this.
  2. Sep 26, 2021 at 7:41 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP, Do not block or close the weep holes. DO NOT block or close the weep holes.
    Yes, I said it twice.
    The weep holes are there by design to allow water to drain out. A yearly or every 6 months, the weep hole should be checked and cleared.
    Keep the truck as clean and dry as possible.
  3. Sep 26, 2021 at 7:49 AM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    yeah was wondering why you would coat the weep holes… you want them to weep….
  4. Sep 26, 2021 at 1:04 PM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
  5. Sep 26, 2021 at 1:11 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    That's what I'll be using because I could get it cheaper. Supposedly it's the same formula with a black dye mixed in, so surface rust gets hidden. People also say something about the dye makes it smell less.
  6. Sep 26, 2021 at 1:20 PM
    Ruminator
    Mark
    Ah. Thanks...
    By the by, regular FF will become black with dirt. The FF rep told me "This is good." and to not wash it off as the dirt helps with the adhesion.
    Took my Taco into a local shop for a full fluids change. Went to pick it up and the mechanic came over and said "Yeah, it was really greasy underneath for some reason. I tried to clean it up a bit."
    I told him I'd prefer he didn't do that next time.
  7. Sep 26, 2021 at 1:33 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Woolwax straw color, heat up in tub of hot water, 100 psi on the compressor.
    Ruminator and steelcity2 like this.
  8. Sep 27, 2021 at 3:07 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I usually warn anyone working on the truck that’s it’s messy under there because it’s coated with fluid film
  9. Sep 27, 2021 at 3:26 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    If a new rust free truck, its a no brainer for cosmoline.
  10. Sep 27, 2021 at 3:33 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I was going to apply some FF to mine and even ordered the kit and spray gun.
    Looking at the consistency of that stuff, the thought of crawling around underneath the vehicle, the amount of mess it would make on everything else...
    I took it to Ming Auto and let them undercoat it for me. They pull it over a pit and have guys in wet suits that spray the underside with a power washer. Then after it completely dries, (the following day) a guy in a hazmat suit applies the goodie.
    If the place called Ziebart was still in business I'd take it there. Ming is the next best thing.
    Look for a Ziebart in your area. It will be the best $600.00 you ever spent.
  11. Sep 27, 2021 at 4:06 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    600 dollars Holy crap! I don't charge enough then lol. Shop near me charges 150-250 and can go up if they need to descale or anything
    tacotoe[QUOTED] likes this.
  12. Sep 27, 2021 at 4:22 PM
    spitdog
    $49.50 a gal for wool wax will last me 3 yrs. I use 1/3 of gal a yr. and it takes me about 45 min. because I remove the spare and heat up the wool wax.
    tacotoe likes this.
  13. Sep 27, 2021 at 4:22 PM
    Too Stroked
    Tom
    I beg to differ - based on a ton of personal and professional experience. My 2014 Tacoma was Ziebart undercoated (for $800) and got every one of the "free annual resprays." That's the first (of many) Ziebart lies. You pay for those resprays up front, and when you come in for your respray, you get your arms (and legs) twisted off for additional services by extremely high pressure sales folks. No thank you.
    Then there's the product. Understand, classic rubberized undercoating does not stop rust. At best, it helps prevent it. But it is not 100% effective. So why the annual resprays? So they can cover up the rust that's already started so you can't see it. Once covered, it continues to corrode unseen until it's too late. At least you get overspray all over the place every year in case they missed something. I had so much overspray on one wheel one year that I had to remove the globs to cure the wheel shake - and that's after I specifically told them to avoid the wheels!
    Finally, there's the process. The product(s) are applied by minimum wage flunkies under pressure to do as many vehicles as possible in a day. Want to guess what that leads to? Results that are all over the place - kind of like the overspray. Car dirty when you bring it in? No worry, they'll (supposedly) power wash it - then undercoat right over the water. (Guess how I know that?) At least that allows the rust to start or keep growing. Get the inner body protection? Yea, right. You might want to pull a few door panels off to notice the pathetic amount of product haphazardly sprayed in one corner. (Guess how I know that?)
    Nope. Ziebart might have been good years ago, but it's absolute junk these days.
    jpereira2 and tacotoe[QUOTED] like this.
  14. Sep 27, 2021 at 4:36 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    @Too Stroked , I think what you mentioned, much of it has to do with the particular dealer possibly. The last time I purchased the Ziebart was in 2001. That was on a 2001 Tacoma and I never took it back for annual inspection. In 2011 when that truck was traded it had no rust and the frame was solid. Now granted we drove that truck almost straight to the Ziebart right after new purchase. At that time there was a charge for clean and undercoat every year, and also a requirement for whatever warranty they had. The guy that owned the shop had been in business a very long time and asked me if I was interested in purchasing the shop. I didn't have the means back then but think now it would have been a good opportunity.
    I've seen good results on more than one vehicle with the stuff.
  15. Sep 27, 2021 at 4:42 PM
    #35
    spitdog
    The beauty of wool wax is there’s is no over spray like with FF. I use to use FF and when I got through there was a wet layer on the drive. With wool wax nothing. It’s thicker and last longer. Ff is good for inside the rails and places where it doesn’t get blasted by road spray.
  16. Sep 27, 2021 at 4:45 PM
    #36
    Too Stroked
    Tom
    My personal and professional experience is with 4 Ziebart shops located within 45 minutes of my house. I also used to work at a Toyota dealership that used to use Ziebart for all of their rustproofing. (They no longer do.) You should have seen the junk work that came back to my detail bay to get fixed. I wouldn't send my worst enemy to them. Just my personal opinions though. You have the right to yours.
