Undercoating Protection. Worth it?
Discussion in 'Detailing' started by StuckinOhio, Sep 10, 2012.
  1. Sep 10, 2012 at 6:56 AM
    StuckinOhio
    StuckinOhio [OP] Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    This may not be the right section for discussing undercoating but it pertains to keeping my brand new tacoma looking nice and rust free. Whats your guys thoughts on it? I live in NE ohio with salt white roads in the winter. We see alot of freeze thaw cycles which means the roads are always wet. for $300-390 I am considering it. I know i could buy alot of wire brushes and spray paint for that money tho. What is your guys thoughts? I plan on keeping this truck for at least 8 years maybe more.
  2. Sep 10, 2012 at 7:09 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Sounds like you made up your mind already.
  3. Sep 10, 2012 at 7:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you plan on keeping the truck that long, do it now before it starts rusting. It's a PITA to do later.
  4. Sep 10, 2012 at 7:22 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Do it, I live in n.e. pa. And had mine done before I took it home.
  5. Sep 10, 2012 at 7:34 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Search a product called Fluid Film here on TacomaWorld. Just get some cans and spray your whole undercarriage. Undercoatings crack with time and cracks hold salt!
  6. Sep 10, 2012 at 7:39 AM
    Pugga
    Massachusetts
    Have you undercoated your undercarraige with fluid film? Just curious because I have the whole fluid film kit in my garage, ready to go.
  7. Sep 10, 2012 at 8:05 AM
    hillbillynwv
    Fairmont, WV
    No, I have not but I will this fall before the salt begins in November. I usually coat my undercarriage with two WD-40 Big Blaster cans. It has worked well with only some minor rust here and there. I received my sample can of Fluid Film and used it on a wheel barrow that stands out in the weather up against a wall. After many rains pounding down on it the film has remained thick and has not washed off which has impressed me. I can buy Fluid Film at my local John Deere dealer for $10/can.
  8. Sep 10, 2012 at 8:12 AM
    Pugga
    Massachusetts
    Did you get the whole kit with the pressure pot gun and everything or are you just using spray cans? I also got the free sample and used it up on some minor rust spots on the Taco, some exposed black iron piping for my propane line and some other small items. I've got the gallon can and the gun for the frame. That will also likely happen this fall.
  9. Sep 10, 2012 at 8:15 AM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Are there any warranty issues with applying an undercoating spray?
  10. Sep 10, 2012 at 8:18 AM
    Pugga
    Massachusetts
    No, unless the undercoating causes something to fail (say if it was really slopped on and clogged a breather or plugged up a sensor, etc). Just applying the coating wouldn't cause you any warranty issues.
  11. Sep 21, 2012 at 8:53 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I had the entire underside of my 2000 rhino-lined.
    I bought it off a older gentleman in arizona, so no rust. Living in Salty Hell (utah), i need something on the underside of the vehicle.
    Rhino lining applied thick, still is tacky, and hold up very well (except gasoline will dissolve it. (discovered while changing fuel filter)
  12. Sep 21, 2012 at 9:37 PM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    I had mine done as a dealer option. It was a steep $500 or so but I didn't necessarily get it for the coating, I got it for the warranty that accompanied it. Lifetime repair or replace, as long as you drop by the dealership and have it inspected once every two years. Hopefully I don't have to use it, but I'm glad knowing that I'll be covered in case that it happens. So many nice truck in Hawaii have gone to waste due to rust, I don't want to be one of them!
  13. Sep 22, 2012 at 11:30 AM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Yea that is nice. I was looking at an independent detailing shop to do it. It was 400+ tax but was lifetime touchup. I am planning on getting it next paycheck. It takes 2 days for them to do everything. I was a bit skeptical at first so I stopped by and talked to the install guy to check out their work.
  14. Sep 22, 2012 at 12:12 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I didn't on this one. I had my '99 undercoated and touched up every year and the frame rust recall still got it. Personally I don't think it's worth it after that.
  15. Sep 22, 2012 at 4:17 PM
    Tim2012dctaco
    Tim2012dctaco Member
    Tim
    Ohio
    2012 TRD double cab short bed
    I just bought the fluid film kit as well. I plan on doing my 2012 with it. I guess time will tell. If you do buy it from kellsport use the "tacoma" code to get 15% off. I haven't decided if I am going to do the inside of the doors or not. I'm kinda freaked out about drilling holes in them.
    Tim
  16. Sep 30, 2012 at 9:11 AM
    Tim2012dctaco
    Tim
    Ohio
    I just applied fluid film for the first time using the "pro" gun. It worked beautifully. Adjusted the gun to get a nice "mist" and it went on evenly without any heavy blobs. I will say the air pressure recommended (80psi) may be a little high, I will lower it next application and see how it works. I will let you know how it holds up.
    Tim
  17. Oct 13, 2012 at 2:01 PM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    So I took my truck in to get undercoating. Did not take pics before, but here is the aftermath. $395 plus tax. They sprayed the whole undercarriage and drilled and sprayed inside the doors. The process took 2 days (one to clean and spray, the 2nd day to let it cure in order to guarantee their work). I am happy I got it done before winter. They laid it pretty thick on the front skid plate but it doesn't really hurt. Went to Z Tech in Canton, Oh.
  18. Feb 18, 2013 at 7:29 PM
    evanwile
    evanwile Canadian Pomp
    Evan
    Canada
    2018 TRD Sport 6M
    I had mine undercoated the first time at Krown undercoating. They drilled it out, sprayed everything etc.
    Since then I purchased a massive pail of RustCheck no drip undercoating (clear) and coat the entire truck with an undercoating gun at least twice a year.. makes a mess...attracts dirt... but its protecting my investment!!
  19. Sep 6, 2013 at 7:16 PM
    Hotrodroxie
    Hotrodroxie Active Member
    NEO
    08 Tacoma dbl 4x4, poor girl stock
    I'm in Green, do you LOVE it? is it working? What about any surface rust before they spray it...buff it off? Did they do any prep? Like I want it detailed and rust cleaned off...then coated...who does THAT
  20. Sep 6, 2013 at 7:17 PM
    Hotrodroxie
    NEO
