Undercoating question for 3rd gen owners.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Astonebrook91, Jun 15, 2020.
  1. Jun 15, 2020 at 6:11 AM
    Astonebrook91
    Astonebrook91 [OP] Member
    Andrew
    Buffalo, NY
    2019 Black TRD Sport Access 6MT 4X4
    None yet
    Within the 1st 6 months of owning my 2019 Tacoma, I bought a case of Eastwood Rubberized Rust Encapsulating aerosol cans, and sprayed my skid plate, cross members, frame rails, and leaf springs. I noticed a bit of rust poking through on the leaf springs because they flex, obviously. Lessons learned, I should have listened to the internet and avoided the rubberized undercoating. I guess I figured it has the rust encapsulating feature... anyways my real question is can I spray over the eastwood product with fluid film? or will it soften it and cause even more of a headache... Thanks
  2. Jun 15, 2020 at 6:18 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Fluid Film is Lanolin based and will not soften hard or rubberized coatngs although many have wished it would after using the wrong undercoating.
    You can safely use lanolin based corrosion inhibitors over rubberized coatngs.
    stun gun likes this.
  3. Jun 15, 2020 at 6:34 AM
    2020cement
    2020cement Active Member
    Fluid film would be my choice of undercoating. Reapply a few cans every year.
  4. Jun 15, 2020 at 7:29 AM
    KVTaco
    KVTaco Well-Known Member
    Generally speaking rubberized is a huge no-no as it traps moisture and promotes rust even faster than no rubberized. Yes, you might apply it to metal that is completely dry, but when it gets a puncture, tear, moisture will get in.
    Fluid Film is the trusted choice. Buy a 6-pack on Amazon and that will do you.
    Furthermore, do not power wash it off, just let it sit and re-apply as needed, usually once a year.
    Finally, it will stink for a time, best to do it outside and let the vehicle sit outside.
    Big tall dave likes this.
  5. Jun 15, 2020 at 7:45 AM
    MRM69
    MRM69 Well-Known Member
    SE CT
    2020 Tacoma TRD Pro (Gone)
    Another alternative to FF is Wool Wax. Same lanolin base as FF, but it's thicker and doesn't have the smell of FF. I used Woolwax last year after a few years of FF and it seemed to hold up better, though we had a pretty weak winter this year, so who knows...
  6. Jun 15, 2020 at 9:38 AM
    OverlandExpress
    OverlandExpress Well-Known Member
    NE Ohio
    2020 Taco TRD PRO
    I just did our new taco in cosmoline RP 342 Black.
  7. Jun 17, 2020 at 5:41 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've always used fluid film for the under carriage of my tundra, but considered something more loner lasting for my 2020 tacoma knowing you have to apply the fluid film every year cause it washes off. I went with cosomoline rp-342 after seeing a vehicle done with it.
