Undercoating/Rustproofing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hp303, Feb 18, 2025.
  1. Feb 18, 2025 at 4:03 PM
    hp303
    hp303 [OP] uhhh
    East Coast
    2022 Toyota Tacoma TRD Pro
    My used taco came from the north being exposed to a lot of salt and it seemed the past owners didn't wash it that often. There are some spots of surface rust. I'm currently looking to fix this issue. It seems power washing is enough to remove and if needed, sanding. If anyone has done this on their own, any advice?
    I am also curious about services like undercoating and rustproofing. Has anyone done any of these two? Recommendations on what chemicals should be used? Complaints? Myths?
    Trying to make it so my truck lasts and stays in good condition.
    Thanks
  2. Feb 18, 2025 at 4:11 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    A lot of people on here talk about using Fluid Film to protect against rust.
    I'm sure someone will get on here with more information to help you out.
  3. Feb 18, 2025 at 4:22 PM
    Josephray70
    Josephray70 Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla Pro XS exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace. Rock Sliders that I fabricated.
    I went to Menards and picked up three cans of surface shield and did my truck in about 20 minutes. a painter’s mask with filters is definitely recommended.
    tneynop and Taco Egghead like this.
  4. Feb 18, 2025 at 4:32 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Cosmolene...the rest is...crap
  5. Feb 18, 2025 at 4:58 PM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Woolwax/Fluid film is good. I got it on mine, in cold temperature it became like thick glue.
    DO NOT use any RUBBERIZED or even paint under coating over rust. Only use OIL BASED.
    First remove the rust with sandpaper or blast, then spray WD40 on bare metal, let it sit 5 min or so and then paint over. After that, you can spray Fluid film or Woolwax. You can also have it done in body shop, on site they have some shops who do it. Whatever you do, do not use rubberized undercoating
  6. Feb 18, 2025 at 5:15 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Surface rust on the frame is normal, getting yearly rustproofing is key! Rust on the body panels is a different story.
    Krown rustproofing for the win!
    WheelinDev, Chew and hp303[OP] like this.
  7. Feb 18, 2025 at 5:45 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    If it's light and you can put in the work to remove and rust convert it, you can topcoat with cosmoline, which will last the longest. Otherwise I'd liberally spray the frame inside and out, the underside of the body, wheel wells, body cavities etc with fluid film, and keep an eye on and re-coat any areas that get a lot of wheel spray yearly.
    hp303[OP] likes this.
  8. Feb 18, 2025 at 5:51 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  9. Feb 18, 2025 at 6:20 PM
    akimmel
    akimmel Well-Known Member
    Alex
    2019 TRD OR DCSB 6MT
    It sounds like op isn't in a salty area, the truck just came from one originally. You can probably get away with wire brushing the rusty spots and then either hit them with spraypaint, or spot treat with oil undercoating spray. You could just do the whole thing, but it would probably be a waste for you and make it messier to work on. On my GTI, which sits over the winter, I have the control arms, subframes, bolt heads and threads, etc. fluid filmed cause they had some surface rust like you described, which I wanted to not get worse but I also didn't want to take everything apart and repaint it.
  10. Feb 18, 2025 at 8:29 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    As for existing rust, try wire brush/sanding and a rust converter spray.
    For undercoating services, Fluid Film, Woolwax, Krown and NHOU are all good choices. Stay away from the rubberized coatings. (Oil-based coatings repel water; ‘hard layer’ coatings can trap water.)
    And if you’re the DIY sort, Cosmoline and CRC Marine Corrosion Inhibitor are excellent products, as well as the FF/WW/Krown/NHOU sprays.
    Or - get a 5-gallon bucket of 30w bar-and-chain oil and a paint sprayer, and go to town on the under-carriage. Then, blow sawdust all over everything. (I’ve never had a chain saw fail due to rust!). :thumbsup:
    hp303[QUOTED][OP] likes this.
  11. Feb 19, 2025 at 4:49 AM
    Old metals
    Old metals Well-Known Member
    02 x-cab 4x4 2.7 2018 TRD Sport 4x4 3.5
    Original
    I had the same scenario when I purchased my 2018 6 months ago. I had time to spare so I wire wheeled and sanded everything I could and used chassis saver paint. Then went after it with wool wax. I also took a lot of things off just so I could do it the best I could. However, 5 years ago, after saving for 3 years, I had a pad poured and installed an outdoor lift. Expensive but worth every penny. Use to do this on jack stands when I was younger.
  12. Feb 19, 2025 at 10:15 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I agree, I get it done every year and it also keeps the mice out of the engine bay etc cause they don't like the taste of Krown.
    truckmike26, Tocamo[QUOTED] and Chew like this.
  13. Feb 19, 2025 at 10:39 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I coat mine once or twice a year with T9 Boeshield. It's made to protect airplane parts. I use a cheap air paint sprayer and wear a full face mask. So far it's the best and easiest I've found.
    Bronxguy likes this.
  14. Feb 19, 2025 at 11:05 AM
    KevlarBear
    KevlarBear Well-Known Member
    SSM 2023 TRD OR DCSB
    I actually just started applying Fluid film at my last tire rotation when I had more access. Trucks a 2023 and going through it's first Wisconsin winter so wanted to at least get some protection on suspension components/hardware. In the spring I'll probably do a more indepth application to the frame/crossmembers/spare tire area.
  15. Feb 19, 2025 at 1:56 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Never thought of that, good point Gilles! :cheers:
    Chew likes this.
  16. Feb 24, 2025 at 6:59 PM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    Yep, Krown or Rust Check.
    Chew likes this.
  17. Feb 25, 2025 at 3:07 PM
    MegaHurts777
    MegaHurts777 Well-Known Member
    Jacob
    ID
    2019 Tacoma TRD Off-Road (MT)
    I personally use AmsOil Heavy Duty Metal Protectant myself, as it also repels mud and debris making it easier to clean after an outing.
    It dries to a somewhat hard wax like film that can be removed with cleaners like Simple Green.
    I've only used it for a little while so we'll see how it does more long term, but so far it's not messy in the slightest and doesn't rub off easily.
  18. Feb 25, 2025 at 3:19 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
