Undercoating your truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hayden08, Sep 20, 2017.
  1. Sep 20, 2017 at 12:47 PM
    Hayden08
    Hayden08 [OP] Lifted 2nd gen
    Hayden
    Pennsylvania
    2008 Tacoma 4x4 2.7 5speed SCLB
    3" lift up front 5.25" in the rear. 32" bfg's on -5 offset vision warrior's. 2" wheel adapters. LED's.
    what do you guys do to undercoat your truck? I like to do things myself, so I decided to undercoat my truck with motor oil and gear oil and cut it with diesel. put it into a spayer or spray bottle and spray the f*** out of it. I do it probably once a month. makes the truck and frame look good with having the black oil on it. plus the dirt soaks up the oil and you re apply and it gets really thick.
  2. Sep 20, 2017 at 12:50 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  3. Sep 20, 2017 at 6:53 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Boiled Linseed oil is a lot neater then motor oil and does not attract dirt once it drys.
    highriserkaiser likes this.
  4. Sep 20, 2017 at 7:31 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Fluid Film just had my truck done along with about 15 other people at a fluid film meet and greet
    TOMB
    BigMacMcCoy, Hunter.415 and 90yota like this.
  5. Sep 22, 2017 at 8:02 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I do nothing.
    Spending no time or money on frame undercoating. If mine rusts Toyota can fix it.
    I especially will not spray my frame with motor oil that holds contaminants against it.
  6. Sep 24, 2017 at 9:05 AM
    Justyn98
    Justyn98 Well-Known Member
    Justyn
    West Virginia and Kentucky
    09 barcelona red tacoma trd sport DCSB
    Led pod fog light inserts, kn cold air intake, Bilstein 5100 with 2 inch coil combo and progressive AAL. Touchscreen pioneer stereo and infinity components with 2 kicker comp r10's and jones turbine exhaust
    ive gotta take my 09 taco to the stealership for the new frame coating they put on there, anyone know about the stuff they use?
  7. Sep 24, 2017 at 9:12 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Mmmm, multiple trucks with freshly applied Fluid film? That must have smelled good.
