Undercoating
Discussion in '1st Gen. Tacomas (1995-2004)' started by HeadlampRevamp, Feb 2, 2011.
  1. Feb 2, 2011 at 9:26 AM
    HeadlampRevamp
    HeadlampRevamp [OP] Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    This past summer I took my truck in to get the undercoating from the dealer. I passed inspection, but "barely'' according to the service rep (that made me feel really good...).
    Fast forward to now, as I look under my truck, its obvious that the frame wasn't treated at all before the coating was applied, as its now falling off in sheets. I'd say that maybe 50% of the coating is still left on the frame, the rest has fallen off.
    My predicament: Should I go ahead and take the truck in to Toyota and have them respray it, or should I wait a few months and go ahead and let the coating come completely off since I "barely" passed the first time. To the naked eye, my frame looks really bad, I would much rather have a new frame then the safely hazard that is my current frame.
    Thoughts?
  2. Feb 2, 2011 at 9:33 AM
    FuzzyRuttin
    FuzzyRuttin If it ain't broke, fix it
    Syracuse NY
    05 TRD Sport 4x4 6-ON-THE-FLOOR
    What's the latest on frame rail rust recall? If you fall in that category maybe Toyota will take care of you. They gave me a good chunk of change for my 97 last year. From reading around on this forum it sounds like they've resorted to frame replacement now instead.
  3. Feb 2, 2011 at 9:35 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'd personally let it rot and let them replace it since undercoating it is a waste of time after the fact.
  4. Feb 2, 2011 at 11:44 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I agree with you, this is probably what I'll end up doing.
