undercover classic vs undercover SE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baldy54, Jun 24, 2011.
Undercover Classic Vs Undercover SE
Poll closed Jul 24, 2011.
  1. Classic undercover
    11 vote(s)
    50.0%
  2. SE undercover
    11 vote(s)
    50.0%
  1. Jun 24, 2011 at 11:18 AM
    baldy54
    baldy54 [OP] Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    I am getting a undercover for sure for my 06 dbl cab. I Do not know which one to get the classic or the SE?? That is why i put a poll up to see which one is the most common to buy..and which one is the best to buy..
  2. Jun 24, 2011 at 11:34 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    not sure on a double cab, but on my reg cab my undercover se looks sexy as hell this is more pricey than most, but imho they are worth it.
  3. Jun 25, 2011 at 5:00 AM
    Greywolf
    Greywolf Well-Known Member
    mike
    Virginia Beach, Virginia
    2011 Prerunner MGM Grey
    undercover tonneau color matched, wet okole seatcovers, n-fab step bars, AMP research bedstep, Maxtrac Spindles with toytec 3" ULK. 285-70-16 toyos and Fuel Throttle wheels
    I bought the SE and had it painted to march the truck looks great and like the looks. the only draw back is it can be a PITA to put on.
  4. Jun 25, 2011 at 9:45 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    The original black cover ($600) looked great right out of the box with many of the Tacoma colors. If the black looks good on your truck, I would get this one. The SE is a more "stylish" looking top, and I would probably only consider this one if I were to want to color match. I believe the manufacture did not recommend painting the original one for some reason, so the SE may be the best option if you wanted to paint match.
  5. Jun 25, 2011 at 2:05 PM
    JoeBama
    JoeBama Well-Known Member
    Joe
    Arab, Alabama
    '10 PreRunner SR5 speedway blue
    Westin nerfs, Smitty bull, Undercover SE tonneau (all black)
    I've got the SE. I like the looks better and the single keyed latch. However, be aware that the raised "spoiler" along the back will hold some water and possibly pour down the front when raised.
  6. Jun 29, 2011 at 11:03 AM
    Adam3612
    Adam3612 Member
    Halifax, NS
    '11 Double Cab TRD Sport
    Undercover SE Tonneau WeatherTech Floor Liners
    I went with the Undercover SE, it was pretty easy to put on and I think it looks great on my '11 DC LB. If you're interested in a painted cover go with the Undercover SE Smooth, it's identical to the SE but comes ready to paint so there is no prep/sanding before paint.
  7. Jun 29, 2011 at 11:05 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I ended up with the classic and am very happy. The styling of the SE I was just never too sure about. I liked the hinges and lock that came on the SE and wish Undercover had made them on the Classic also, but the regular hinges and two locks don't seem to be a problem on the classic. SE comes in the original textured black finish and a smooth version(must be painted which means more $$). Classic only comes in the textured black.
  8. Jun 30, 2011 at 10:06 AM
    High Pockets
    High Pockets Member
    Fred
    Southcentral PA
    Silver 2011 DC TRD Off-Road
    Viper 5101 Remote Start, OEM Bed Step, OEM Tube Steps, TRD Wheel Centers, Weathertech Hood Deflector and DigitalFit Floorliners, Always on Rearview Camera, Lighted 4X4 Switch, 12V-140A USB/AC Converter mounted to passenger side tunnel, Undercover SE Tonneau, Bestop Supertop, Bed Mat, TRD License Plate Frame w/ TRD Capped Screws, BLU Logic Bluetooth
    I went with the SE, liked the single lock and hinges. A bonus I found out later was that I didn't need to remove the bed mounted hardware to install my Bestop.
  9. Jun 30, 2011 at 10:32 AM
    JWC
    JWC Well-Known Member
    2010 DC SB TRD Sport 4x4
    I've had my Undecover SE on my 2010 dbl cab Sport for a few weeks now. I really like it. My truck is black - and I thought the black plastic SE looked pretty good on it - kind of matches the black pastic bed rail caps and the plastic cover on the rear bumper. I've seen trucks with the Undercover SE Smooths on them and they also look really good with the cover painted to match the truck. However, I believe the paintable smooth versions of these covers are quite a bit heavier. The undercover SE on my dbl cab only weighs ~55 lbs - and the way it mounts to the existing bed rails makes it really easy to take off - it even come with hooks you can mount to your garage wall to hang the cover on if you need to take it off.
  10. Jun 30, 2011 at 10:37 AM
    JWC
    BTW - I think the classic looks good too. I went with the SE because I liked the single lock - and I thought the little bit of extra styling on the SE looked good with my TRD Sport. The place I got the cover from gave me the same price for both the SE and the Classic. If the Classic had been a little cheaper - maybe $50 bucks, or more, less - I would have gotten it.
  11. Jul 1, 2011 at 6:31 AM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Looking at the black too, prefer the single lock one...any chance you can post a few pics?
  12. Jul 2, 2011 at 1:59 PM
    aphex
    aphex Well-Known Member
    Pittsburgh, PA
    11 DC TRD OR
    Undercover Classic Tonneau, EGR Aerowrap Bug Deflector, Consolevault Custom Safe, Britax Boulevard 70 Baby Seat!, Retro TRD Shift Knob, Factory Bed Mat, Rear Leaf TSB, 265/75-16 BFG All-Terrain KO's, KMC Enduro Wheels, Front Bilstein 5100's set @ 0" w/ Toytec/Eibach Springs, Rear 5100's, TRD Grille Emblem, OEM Roof Rack, AntennaX 14" Billet Antenna
    Here's my '11 DC SB with the undercover classic. I was considering the SE as well at the time, but like the more "plain" look. Very happy with it.
  13. Jul 3, 2011 at 7:27 AM
    2chains
    Calgary, Alberta
    aphex
    cover matches the bumper cover, your truck looks great! iI'm thinking this texture would be less maintenance than color match surface? thanks for posting the pic
  14. Jul 3, 2011 at 8:00 AM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    I absolutely love my Undercover Classic. I have had it for 2 years. The only reason I would recommend the SE is because of the hinges. With the classic, in order to be able to remove it without effort, the back has to hang a little bit off the tailgate IMHO. If you push it up to give it a more "flush" look, you have to move the brakets back in order to take them off. Still love it and wouldn' t change it out for anything else!
  15. Jul 3, 2011 at 9:38 AM
    aphex
    Pittsburgh, PA
    11 DC TRD OR
    Thanks. Can't speak for the smooth color-matched surface, but the standard matte black finish that comes with the Classic doesn't require any maintenance at all. My dad has had one on his GMC for ~5 years and it still looks pretty much new.
  16. Jul 3, 2011 at 11:20 AM
    jeanyves
    jeanyves not junior member
    red deer
    08 trd offroad
    lr uca,trd supercharger,light bar ,4 lightforce striker 170,toyota alu. step for winter,black nfab for summer,fog light mod,toytec ultimate lift kit with 5100,18'' fuel boost with 275/65 nitto terra grappler
    got the undercover se on the way,liked the style a bit more and 1 latch will be easier to handle when you gotta hand full of beer and nachos :rimshot:
  17. Apr 24, 2013 at 5:04 AM
    yellowdotz
    yellowdotz Well-Known Member
    SiNNeR
    Pasadena, CA
    13 tacoma i42.7L 4x4 manual access
    does anyone know the exact difference with the hinges between classic and sc?
  18. Apr 24, 2013 at 2:08 PM
    Sigo
    Sigo Active Member
    Bruce
    I've got the SE and prefer it over the classic for a couple of reasons. I prefer the look of the SE and I like the single lock.
  19. Apr 24, 2013 at 6:01 PM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    They should make the classic with a single lock mechanism. I love the simple, functional look of the classic. This was the first thing I bought for m truck. Still on there. I can remove and install it by myself if the need arises. It is always desert dry in there.
  20. Apr 25, 2013 at 12:13 PM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    The difference between the hinges depends on the cover model and/or the year of the truck.
    The Classic has both. Newer model trucks use the SE Style hinge. Older models had the tab/slot style secured with a spiral ring. CLASSIC INSTALL
    The SE covers all use the newer style hinge. These are similar to the hinges on the hood of the truck. SE INSTALL
