Undercover Flex - Leaks on OUTSIDE of drain hoses
Discussion in '2nd Gen. Tacomas (2005-2015)' started by topflight70, Aug 14, 2012.
  1. Aug 14, 2012 at 6:47 PM
    topflight70
    topflight70 [OP] Member
    Kenner, LA
    2012 TSS
    Well, I installed my Undercover Flex (from Scott at truckaddons.com), and have run into an interesting issue. Yes, I took my time and carefully aligned everything, centered the cover, checked all areas thoroughly during installation.
    We had a bit of light rain this afternoon and I found water in the bed... more than a couple of drops. :mad:
    Once I got home and looked, I noticed something about the drain fittings on the rails. The rails are mounted in the bed, and I notice that the 90 degree elbows that feed into the drain hoses don't really appear to have a decent seal inside the rail. Using a paper cup and a steady hand, I poured some water into the rail. While most water did correctly flow through the hoses and drain properly, I noticed quite a bit of water flowing on the OUTSIDE surface of the drain hoses and going into the truck bed.
    Has anyone seen this happen before? Has anyone tried to put any kind of sealant (such as silicone) to seal the drain tube into the rail? :confused:
    Although I had a great experience with truckaddons.com, I am starting to doubt the Undercover Flex. Almost tempted to try to return it for a BakFlip Fibermax. Thoughts?
  2. Aug 14, 2012 at 6:53 PM
    topflight70
    Kenner, LA
    2012 TSS
    Also, I THINK that this is the only place the leaks are coming from. Still plan on doing more checking.
    ALMOST FORGOT: The drain hoses were MISSING from the Undercover package. Truckaddons DID take care of getting this worked out, but I fault Undercover for such a glaring error. Is their quality control having issues?
  3. Aug 15, 2012 at 4:15 AM
    nathan3306
    nathan3306 Well-Known Member
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    I would call undercover and leave them a message. They have good costumer service and should be able to work with you. I've heard some few bad things on the flex but you have to understand that this is a brand new product from undercover. They don't have all the bugs fixed but I'm sure they would be more than happy to help make your cover right.
    I'm waiting for the bakflip VP myself.
  4. Jun 21, 2015 at 7:42 PM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    Same problem, did you find a fix?
