Undercover tonneau on '10 Taco question
Discussion in 'Tonneau Covers, Caps and Shells' started by All Beef Taco, Sep 10, 2009.
  1. Sep 10, 2009 at 1:04 AM
    All Beef Taco
    All Beef Taco [OP] Well-Known Member
    Joe
    Thornton, CO
    2010 TRD Off-Road DC 4x4
    Rattle canned wheels, Weathertech Floormats, Undercover Tonneau, DIY Hi-Lift jack bed mount, Demello Sliders, ARB Bumper w/ ARB Fogs + anytime fogs mod, IPF 968's, Warn M8000 w/ Amsteel Blue & Billet 4x4 Hawse Fairlead, Rear Leaf TSB, Toytec Adjustable Coilovers and AALs, Rear Bilstein 5100's, BFG MT KM2's, Safari Snorkel, Rear Diff Breather Mod
    I'm thinking of picking up an Undercover tonneau for my new Tacoma (DC SB). The instructions mentioned that you might have to trim or modify any bedliners... is that the case with our Tacos? I just want to know what I'm getting into if I go this route.
  2. Sep 10, 2009 at 1:09 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    With my '08 'long' bed no trimming, just put the hardware in the rails and snap it up.... pretty easy.
  3. Sep 10, 2009 at 6:52 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    same here on my '09. Kinda a pain to remove because of the size (LB) but totally doable in 15-20min
  4. Sep 10, 2009 at 8:09 AM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    I had to loosen up the bed on my 09. The bed was installed wrong from the manufacture and one hook would touch the cab. Make sure that you check the space between the cabin and the bed. The cover it self is very strong. I put two bike racks on top and the installation took 30 min. No cutting was necessary.
  5. Sep 10, 2009 at 8:18 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    The tacoma does not have a bedliner. They have a composite bed.
  6. Sep 10, 2009 at 10:17 AM
    All Beef Taco
    Joe
    Thornton, CO
    Those of you that have had an Undercover for a while... how does it do as far as far as keeping the bed dry?
  7. Sep 10, 2009 at 10:29 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I just sold mine to a guy here, since it was to hard to get the spare tire and jack out of the bed. But I never had ANY issues with leaking even from a pressure washer. I had to do a little play work to get the fit I wanted, but it was good to go :D
  8. Sep 10, 2009 at 11:09 AM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    I really like mine. I can get it on and off by myself if I have to. But when the wife is around to help it is a breeze. The wall hooks work well also. No water leaks on mine. The only problem I had was one of the locks was a little sticky. Called Undercover and they sent me out a new set within a week.
    HTH
  9. Sep 10, 2009 at 1:48 PM
    virgilus11
    kearny, nj
    09 sr5
    I have my cover for about 5 months and we had some good rain this spring in north east. Not one drop inside. The only place that may leak is in the front by the hinges. They sent my cover with one extra door seal at that time was a special. I cut a piece and installed that on top of the bed (in the front), maneuvering around the hinges. Bone dry.
  10. Sep 12, 2009 at 11:11 AM
    All Beef Taco
    Joe
    Thornton, CO
    I forgot to ask-- can you still use the OEM cleats in the rail system with the Undercover on the bed?
  11. Sep 12, 2009 at 11:37 AM
    jaws revenge
    jaws revenge Well-Known Member
    you can use the cleats, but it touches just barely with the bottom of the undercover. i also have a toyota oem cargo divider, and it too justs barely touches. no big deal though. luke at truck truckalternations also sells them.
  12. Sep 12, 2009 at 9:02 PM
    virgilus11
    kearny, nj
    09 sr5
    Unfortunately in my case-No. For me the selling point was-light,strong and waterproof. But I believe they have something else (smaller cleats) that's little bit smaller that would fit under. Try to look into Toyota catalogs I am certain that I saw something. In my 05 dc I had a ARE painted to match the color. Was twice as heavy, almost twice the money and I always felt bad when I had to put my bikes full of mud on top. This one I am really pleased with.
    Good luck with your decision.
  13. Sep 13, 2009 at 7:06 PM
    Bodete
    Bodete Well-Known Member
    Missouri
    2009 SR5 DC LB 4x4
    Eibach springs w/ 5100 Bilstein shocks set to "0", Rear TSB
    I have a 09 double cab long bed. I had mine installed by the guys that sold them and they did not have to trim anything. Mine never leaks. Also you can't use the large tie down cleats but you can buy some mini tie down cleats from toyota that work fine. You just can't use them from where the shocks connect to the bed, back to the tailgate because they interfere. I really like it and it looks good.
  14. Dec 3, 2009 at 1:47 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
  15. Dec 3, 2009 at 2:16 PM
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Kalifornia
    MGM 09 AC 4WD V6 TRD-OR w/ 2013 FWC Finch
    Grillcraft, Demello Sliders, Bilstein front and rear with OME coils and springs, Wheelers Bumpstops front and rear
    I've got one and it is great for a tonneau. No trimming but if you install it yourself you will have to get in under it to get the mounts square with the bed. Loosen here, tighten there and repeat.
    On my 99 I had a Snugtop tonneau. The Undercover is way lighter and easier to remove. If you have the short bed it will be even lighter! I go to a high pressure wash and some water gets in but very little. Go for it.
  16. Dec 3, 2009 at 5:01 PM
    dalesrn
    dalesrn Tacoma TSS
    Dale
    Southeast Louisiana
    2008 Tacoma PreRunner DC with TSS Package
    Borla exhaust system, Sirius Satellite Radio, Chrome package, Trailer Hitch, Clazzio Leather seat covers, TSS badging, Anytime on fog lights mod, Daytime driving lights mod, Dual backseat DVD players w/monitors, 3rd Brake Light "TSS" mod, Bed pocket lights mod, Seat belt chime mod, Bed storage compartment auxillary outlet mod, Shorty antenna, Armor Lid Tonneau Cover, Line of Fire tailgate light
    If you are in the market for the hard tonneau cover, consider the Armor Lid. I bought mine in August and love it. It is almost exactly like the Undercover, but it is smooth underneath. It has a LED light built in and does not leak at all. Mechanics Warehouse offers free accessories with the Armor Lid, but will lower the price if you do not want the accessories (http://www.mechanics-warehouse.com/armor.htm). Price is $550 if you take the "free" accessories and have it delivered to a commercial address. I was able to install it myself in 1 hour.
  17. Dec 3, 2009 at 5:56 PM
    trdhrdr
    trdhrdr Member
    Chicago
    2010 Taco TRD 4X4
    I had one installed on my 2010 DC SB today and no trimming was required. I stood with them as it was installed. The large tie downs will fit on the sides but not after the shock to the rear. $650 out the door.
  18. Dec 3, 2009 at 6:09 PM
    edc
    edc Well-Known Member
    ILLINOIS
    09 tacoma trd crew cab 4x4
    rcd 4.5" lift,relentless fab front bumpers,trd cai,17x9 motometal955,flowmaster40 muffler,cobra sxt cb,k2motor headlights,kl71 kumho tires
    Just got mine two weeks ago $850 installed with built-in led lights.so far no leaks even through automatic car washes.
  19. Dec 3, 2009 at 6:37 PM
    ETAV8R
    ETAV8R Out DERP'n
    The Armorlid looks good too. Better clearance in the truck box. The Undercover has a light as well. There was also a slim metal/alluminum tonneau but I can't find the link. Do a cost/comparison of different ones and go for it.
  20. Dec 7, 2009 at 4:25 PM
    Duvallite
    Duvallite Active Member
    Washington
    2010 Magnetic Gray DC SB, 4x4, TRD Off-Road
    I have been strongly considering the Undercover for my 2010 DC SB, mainly based on all of the glowing comments here on TWF. So I went to a local canopy dealer that carries Undercover so I could see one close up first hand. They had display samples of both the Undercover Classic and the new Undercover SE, and the SE looks way better to me than the Classic version (which looks good also), plus it has a couple of solid improvements that seem better also. Unfortunately, the dealer said they weren't available for my truck. When I got home, I called the manufacturer for the Undercover, and they told me that it may be a couple of months before the SE is available for the Toyota Tacoma. I'm in no rush, so I will definitely be waiting for the SE to be released.
