Undercover vs Undercover SE?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buckeye, Dec 15, 2009.
  1. May 6, 2012 at 5:46 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Only way that would matter is if you are hauling something that sticks out above the bed. If not, then the rail system tie downs are useless. If it sticks outside of the bed, the cover isn't going to be on it, so then you can use all the rail system again:thumbsup:
  2. May 6, 2012 at 6:21 PM
    Voodoochild 2k9
    Voodoochild 2k9 Well-Known Member
    Randy
    Florida
    TBD
    Undercover SE; DD Pioneer Radio
    I don't think that's true. Can't say from personal experience but it's what I gather from the many reviews I read. It seems as if the Velcro rails on many of the roll-ups use the factory rail system for mounting. And even when the thing is rolled up it you lose use of them. Plus the cargo divider uses the rail system, and it can be useful with or without oversized cargo.
    Another concern I have is that I was going to mount bicycle fork mounts on the front rail. But that may be totally out of the question. More important to have a weatherproof cargo area.
    With this cover, does the entire setup remove, making the truck completely stock? Or is there a frame or hinges or anything else left behind that takes up the front rail space? The front rail is where my bicycle mounts would go.
  3. May 6, 2012 at 6:52 PM
    06ToyTaco
    06ToyTaco Well-Known Member
    CA
    06 4x4 DCLB Sr5 Silver
    OME 885X, 1.5" AAL + TSB, LR UCA
    I have the Undercover cover. The Undercover SE might be different. When the cover is off, there will be two hinges (one on each side in the front, by the cab. This becomes the pivot point.), two L plates by the tailgate (this is where the locks come into play), and two eye-bolts (where the shocks/struts attach). Nothing really takes up the front rail by the cab.
    PDF of installation guide.
    http://sportcompactonly.com/manuals/Brand/Undercover/uc_ig_toyota_tacoma_4060.pdf
  4. May 6, 2012 at 7:13 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
    Sweet, thanks!
  5. May 6, 2012 at 7:19 PM
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    This is correct...front rail is completly clear
  6. May 7, 2012 at 8:34 AM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    I was refering to the undercover...not the velcro. Also, someone else on here had a brand new canvus cover and someone flicked a cigarette on it when he was in a store and burned a whole in it. This won't and can't happen on and undercover. Mine is even water tight :D
  7. May 7, 2012 at 8:43 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    heres my se i like the single lock design and imo looks a little smoother than the original just my .02
  8. Nov 21, 2014 at 11:31 AM
    V0X
    V0X Well-Known Member
    Eric
    Ooltewah, TN
    TRD Pro Grille, MB TKO Wheels, BFG TA KO 265 70R17, Pop and Lock (color matched), Undercover SE Tonneau.
    sorry to bump a 2 year old thread, but I just ordered the undercover SE after seeing at at my local truck and trailer dealer in Chattanooga. This thing is very solid, and weighs only 58 lbs. The hinge points and gas struts both have quick release mechanisms which allows you to remove the top for full bed access in just a few minutes.
    The thing I really liked was how the cover covered the caps and doesn't create a channel for water to infiltrate. It's a one piece ABS composite. The security of this compared to other similar covers is comparable. If someone wants in to ANY bed cover, they will get in. I combined mine with a pop-n-lock tailgot lock and pipe clamp mod for the tailgate.
    I purchased mine for $775 with free install.
  9. Nov 21, 2014 at 3:35 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Another feature you'll like is the low maintenance of it. Maybe some Armorall or some other treatment every-so-often and it's good. I've only treated mine once or twice, in the 6 years I've had it and it still looks good.
