Underhood sticker - tune up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raylo, Jun 26, 2022.
  1. Jun 26, 2022 at 11:57 AM
    Raylo
    Raylo [OP] Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    So, whilst looking for an A/C sticker under my hood (which I didn't find???), the only one I found was for "tune up" info. It specifies intake and exhaust valve clearances and says "no other adjustments" necessary. Does anyone here ever check or adjust the valves on their 1GR-FE? Are we supposed to? At what mileage?
  2. Jun 26, 2022 at 12:16 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Yes.
    Its in the maintenance section of the owners manual. Forget the mileage interval.
    Not sure how common it is within this community.
    Edit: Additional reading from a different thread.
    https://www.tacomaworld.com/threads/when-to-do-valve-adjustment.83310/
  3. Jun 26, 2022 at 2:42 PM
    Raylo
    MD, USA
    I just found another thread that lists the entire recommended maintenance schedule and it said to do this every 60,000 miles. Interesting. I have never adjusted valves on a modern vehicle except when replacing a cam or head gaskets. And I don't recall any discussion of this in my entire time on TW.
  4. Jun 26, 2022 at 2:57 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Most people never check/adjust them on Tacoma's due to the amount of work involved as the cams must be removed to change the shims if the require adjustment.
    I haven't seen where anyone has had any problems from not checking them, most Tacoma engines seem to go well over 200k and never get adjusted.
    Most other engines have hydraulic buckets/lifters and never need adjusting as the lifter takes up the slack but many of the older Toyota engines had solid buckets that were supposed to be checked/adjusted although it seems it was rarely done exept on a rebuild or headgasket job.
    Raylo[QUOTED][OP] and TnShooter like this.
  5. Jun 26, 2022 at 3:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No, I never have checked or adjusted mine.
    I have no plans to ever do so either.
    I’ll wait until I get a crank/cam correlation code and “think” about it then.
    Because you’ll 75% of the way there doing a timing job.
    Raylo[OP] likes this.
  6. Jun 26, 2022 at 3:08 PM
    TnShooter
    Deogee
    STOCK
  7. Jun 26, 2022 at 3:11 PM
    Raylo
    MD, USA
    So, basically the cams and valvetrain are set up kind of like a DOHC motorcycle. Got to pull the cams and swap shims... or lifters in this case? Uggghh. My Triumph bike is also due for this work, but I haven't done that one either. That was supposedly due at 12,000 miles.
  8. Jun 26, 2022 at 3:11 PM
    Raylo
    MD, USA
    I am with you on this one.
    TnShooter[QUOTED] likes this.
