Understanding 4X4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Buddha717, Jan 24, 2016.
  1. Jan 24, 2016 at 3:07 AM
    Buddha717
    Buddha717 [OP] Well-Known Member
    Ron
    Harrisburg, PA
    2016 Inferno Tacoma TRD sport DCLB PTJBL
    So this will be my first modern 4X4. My question is about the from diff while driving in 2 wheel drive. I'm installing larger tires 275/70-18 on my truck. If I were to get a front flat tire would I be okay to install the stock spar tire? Does the front differential spin freely? Or if I got a rear flat I would have move a tire from the front to the rear and install the spare in the front.
  2. Jan 24, 2016 at 3:18 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You can use your spare. Just don't be going 90. Get it fixed as soon as you can.
    MQQSE and robssol like this.
  3. Jan 24, 2016 at 3:23 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Yeah, what he saido_O
    MQQSE likes this.
  4. Jan 24, 2016 at 6:25 AM
    Buddha717
    Ron
    Harrisburg, PA
    even on the drive line? So if I got a flat on the rear your saying put it on the rear? Th reason I have such reservation is I got a flat on my STI and the tire size for the aftermarket tires were one size larger. I put the spare on and every 10 miles we had to pull over because the diff was overheating.
  5. Jan 24, 2016 at 9:43 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Mechanically, you are fine driving in 2wd with a different size tire on either the front or back, but handling and braking will be off, so you should put a matching tire on as soon as possible. I am also guessing that the traction nannies should be turned off as they are going to detect mismatched wheel speeds and possibly try to compensate. You should NOT drive in 4wd because the smaller tire will cause the driveline to bind. I have an Outback, so I know how sensitive Subarus are to differences in tire diameter. Their AWD systems are a different beast altogether (especially the STI), you cant even replace a flat tire with a new one of the same size without replacing all four because of the new tire's tread is thicker.
  6. Jan 24, 2016 at 9:50 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I think he's talking about driving in 4 wheel drive with the smaller spare tire on the truck. If you are on diet it's fine, and you shouldn't be in r wheel drive when on sticky surface or pavement anyway
  7. Jan 24, 2016 at 9:56 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    V
  8. Jan 24, 2016 at 10:33 AM
    Buddha717
    Ron
    Harrisburg, PA
    thanks guys.
