Understanding Off sets
Discussion in 'Wheels & Tires' started by badguybuster, Aug 31, 2010.
  1. Aug 31, 2010 at 7:54 AM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    So, I was pondering off sets: positive, zero, and negative. I never really gave it much thought until I decided to put 35's on my Tundra. I got to looking around and found this info. Based on what I am reading here, having a large negative offset, lets say -18, is about the same as putting wheel spacers on your truck? Is that right? Since it puts extra stress on the hub and suspension.
    http://www.discounttire.com/dtcs/infoWheelOffsets.dos
  2. Aug 31, 2010 at 3:12 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It really depends on the width of the rim as to how much the wheels stick out, but yes, the more negative the offset, the further out the wheel mounts from the center-point of the rim.
  3. Aug 31, 2010 at 3:15 PM
    KPT
    09 Prerunner
    Here's a site that explains some more.
    As you can see from the chart about 1/3rd of the way down, the backspacing of the wheel depends on both the offset and the width.
    https://www.rsracing.com/tech-wheel.html
    What you'll want to do is find out what the ideal backspacing is for a trundra to run 35's. Then when you find rims you like, you'll be able to use their wdith to determine what offset gets you to that ideal backspacing number.
  4. Aug 31, 2010 at 7:22 PM
    badguybuster
    Michael
    yeah, I saw that one too. Still doesnt answer the question tho. Does large negative off set cause the same issues are running spacers?
  5. Aug 31, 2010 at 7:27 PM
    KPT
    09 Prerunner
    I can't think of a reason it wouldn't cause the same wear issues.
    As you know, a spacer is basically just adding thickness to the rim seat, giving it an more negative apparent offset. So I don't see a difference between the two as far as stress goes.
  6. Aug 31, 2010 at 9:02 PM
    badguybuster
    Michael
    Thats kinda what I figured. The rest of the tires should be here this week, then the testing starts. I really like my wheels, so if they dont fit I am gonna be really bummed out.
