Understanding relays...
Discussion in 'Technical Chat' started by chadderkdawg, Sep 23, 2011.
  1. Sep 23, 2011 at 7:23 AM
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Hoping someone can help me wrap my head around automotive relays. I'm wanting a relay that will have obviously a 12v input and a ground, with one output that can be activated by 1 of 2 inputs (one, the other, or both). Any help is appreciated, thanks :)
  2. Sep 23, 2011 at 7:35 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    All relays can do that.
    Can you be specific as to what you actually want to do? What is the application?
  3. Sep 23, 2011 at 7:39 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Application is to the the DRL mod without spending 50 bucks + shipping on inflated relays. I'll have the output going to the center lights, and the inputs coming from the parking lights and some sort of accessory light, ie radio/ignition/etc...
  4. Sep 23, 2011 at 8:12 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
  5. Sep 23, 2011 at 7:00 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Don't be offended, but if you are asking us to help you understand relays, you are probably going to wish you just spent the 60 bucks and bought the factory stuff.
    I have a pretty decent handle on electrical wiring, and when I sit and try to figure out how to mimic the factory drl flasher with regular relays, my head starts hurting.
    If you can figure out how to do it, then much respect for you. I will be buying the kit when I get around to doing mine.
  6. Sep 24, 2011 at 10:10 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I figured out a cheap way to do it, but it makes the middle lights mimic the outer parking lights, which isn't ideal. If you get a basic bosch relay from your local auto parts store, you basically just wire your positive and negative, output is to the middle light, and the switching wire comes from the positive feed on the parking lights. But parking lights don't act the way drl's should act, so I pry wont be doing it.
