Underwhelmed with a 2010 DC TRD OR
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DanielJay23, Jan 8, 2017.
  1. Jan 8, 2017 at 10:46 AM
    DanielJay23
    DanielJay23 [OP] Active Member
    Daniel
    Took a 2010 TRD OR DC for a test drive yesterday. I got in the truck and felt like I was driving a car. Ride was super smooth and really low to the ground. Granted I am confident.i g from a Ranger with a 6" lift rolling on 35" tires. Do the rides in newer models ride differently than 2010? Thinking I just need to put a lift and different suspension on one to really make it feel like my stiff truck now. Any suggestions?
  2. Jan 8, 2017 at 11:03 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    it was definitely a offroad you sure of that? did it have a locker and inverter?
  3. Jan 8, 2017 at 11:06 AM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Obviously it's going to sit lower and ride different than your ranger with a 6" lift and 35" tires...
    Personally I don't think the 3rd gen drive that much different.
    HawkShot99 and Silverspool like this.
  4. Jan 8, 2017 at 11:06 AM
    DanielJay23
    Daniel
    Yep it had the buttons for the locker and inverter. Had the OR stickers on back. But the one thing that threw me was the autocheck sheet he printed out said Tacoma SR5 on it. Is there an SR5 off road edition?
  5. Jan 8, 2017 at 11:08 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    all offroads are sr5.they ride great stock. a lift will change it some depending on what type of lift you put on it
  6. Jan 8, 2017 at 11:12 AM
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    They are tuned a bit softer. The Sport will ride more stiff.
  7. Jan 8, 2017 at 11:13 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Drive a Sport
  8. Jan 8, 2017 at 11:15 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    coming from the factory the second gen's do have a car feel to them on how they drive, but it will change once you start modifying the suspension. My first gen has more of a truck feel to it than my 08 and is probably why I drive it so much more still.
  9. Jan 8, 2017 at 11:16 AM
    Plain Jane Taco
    USA
    That's not to say the Sport rides rough. It does not. But it does have a bit more of a taunt, controlled ride.....assuming the dampers are healthy
  10. Jan 8, 2017 at 11:27 AM
    DanielJay23
    Daniel
    I was thinking I should stick with an OR. Only for the fact that I do like to do a fair bit of driving on sand @ Silver Lake sand dunes in Michigan. Thought the locker would help if I got stuck. Sounds like I'm going to have to lift it 3" and put different shocks in it.
  11. Jan 8, 2017 at 11:29 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Mods to get it YOUR way are half the Fun of a Tacoma!
    desertrunner24 likes this.
  12. Jan 8, 2017 at 11:36 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    The OR suspension is softer than the Sport and standard SR5 suspensions. I was concerned about that when I bought mine but learned to really appreciate the feature when offroad and driving rough roads.
  13. Jan 8, 2017 at 11:38 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    My 06 drives like a glorified station wagon. It's stock. The mod$$ is modding the kids teeth with braces. :D
  14. Jan 8, 2017 at 11:53 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I believe the OR and SR5 share the same suspension. IIRC, there was only 2 6 lug suspensions for leafs and coils. Base/SR5/OR had the same coils and the same leaf packs. The Sport had different coils and different leafs (4 leaf instead of 3 until 2014MY when they all went to the same 4 leaf packs).
    The only real difference was shock absorbers.
  15. Jan 8, 2017 at 12:47 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    The off road does have different coils that the SR5.
  16. Jan 8, 2017 at 12:48 PM
    T4RFTMFW
    Source? Just curious.
    First time I've heard it and don't remember seeing a coil weight variation in technical data outside of the two I referenced above (Sport/all others).
    What's the difference in an SR5 and an OR coil?
  17. Jan 8, 2017 at 12:50 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Don't buy it if you don't like it.
  18. Jan 8, 2017 at 12:50 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I thought the sr5 coil was the same as OR too. the sport was a stiffer spring cause it's a sport suspension
  19. Jan 8, 2017 at 12:52 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Maybe the shocks on the 2010 OR are worn out. Mine were super soft at 70k but replaced them and much stiffer. The Ranger probably has newer shocks if it's lifted. My dad had a Ranger once the miles add up on those it wasn't worth fixing. The Tacos seem to hold up better hence the higher resale. happy hunting.
  20. Jan 8, 2017 at 12:54 PM
    T4RFTMFW
    No stock Tacoma is going to ride like a Ranger on 35s and a 6" lift.
    So.. hm.
