Undiagnosed driver side clicking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pnolan88, Feb 25, 2019.
  1. Feb 25, 2019 at 10:45 PM
    Pnolan88
    Pnolan88 [OP] New Member
    2013 Tacoma TRD Sport
    Hello all,
    I have an unusual clicking and snapping noise (not a vibration) coming from the drivers side dash or steering column. Sound seems to be from inside the dash, lower than the steering wheel. It’s not very loud so I’ve had a difficult time figuring out it’s specific location. Noise doesn’t start until >70mph and then persists in approximately 1-3 second intervals. Noise goes away once I’ve slowed down to the 30-40mph range. Happens when I’m going straight, turning, accelerating, decelerating, braking. Nothing but slowing down makes it stop. Same goes for a/c or air vent selection or modes, tried changing all that. I have no warning lights or any indications that could be associated. I’ve looked under the dash and don’t see anything loose, but it was a pretty quick check with a flashlight.
    Any help would be greatly appreciated!
    Vehicle specs:
    2013 TRD sport, ~85000 miles. All terrain tires.
  2. Feb 25, 2019 at 10:59 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Speedo cable, maybe
  3. Feb 25, 2019 at 11:11 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It’s been like 20 years since they used those
  4. Mar 6, 2019 at 10:59 AM
    Pnolan88
    Solved:
    Loose/detached splash shield in front left wheel well. Thanks for the help!
    Patrick
  5. Mar 6, 2019 at 11:04 AM
    JerzRob
    JerzRob Well-Known Member
    Rob
    South Jersey
    2009 SR5 TRD Sport
    Was just going to tell you to check that... Mine was passenger side.
  6. Mar 6, 2019 at 11:04 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    It not right to find the problem so quick. It takes away from all the entertaining responses.
    JimboAnz likes this.
  7. Jun 13, 2019 at 11:14 AM
    YOTAKROACH
    YOTAKROACH Member
    Crank up the Base. First Yota, couldn't afford eco boost so i got a stick 4banger.
    None yet, just got her.
