Uneven bed after lift help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toppdawg, May 12, 2016.
  1. May 13, 2016 at 5:35 PM
    #61
    VLocos24
    VLocos24 Well-Known Member
    I kee hearing about those. What's the benefit of those?
  2. May 13, 2016 at 5:35 PM
    #62
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
  3. May 13, 2016 at 5:35 PM
    #63
    T4RFTMFW
    T4RFTMFW Well-Known Member
    That isn't taco lean.
  4. May 13, 2016 at 5:46 PM
    #64
    toppdawg
    toppdawg [OP] Well-Known Member
    Josh
    Jackson, TN
    2012 TRD Sport 4x4
    Any idea how much longer the rear should be from the front measuring from the center of the leaf. I'm guessing no more than an inch or so.
  5. May 13, 2016 at 5:47 PM
    #65
    VLocos24
    I'm not exactly sure but it's not too much. My icon AAL was maybe 1 1/2" difference. Maybe less
  6. May 13, 2016 at 5:48 PM
    #66
    VLocos24
    Let me try to measure
  7. May 13, 2016 at 5:52 PM
    #67
    VLocos24
    Mine is 15 1/2" to center in the front and 18" to center in the rear
    toppdawg[OP] likes this.
  8. May 13, 2016 at 6:01 PM
    #68
    toppdawg
    Josh
    Jackson, TN
    2012 TRD Sport 4x4
    Just checked and yes the shackles are moving freely.
  9. May 13, 2016 at 6:17 PM
    #69
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Tons of flex with increased weight capacity. Really big benefit is axle drop. Allows the tire per side to come way down, limited by shock travel. You'll want to pick shocks based on what you want. @SMKYTXN has done this. His is the cleanest one I've seen and smartest options picked.
  10. May 13, 2016 at 6:32 PM
    #70
    toppdawg
    Josh
    Jackson, TN
    2012 TRD Sport 4x4
    Mine are much shorter than yours and they are the same length front to back 22 inches total length. 11 inches center to front and 11 inches center to rear.
  11. May 14, 2016 at 5:42 AM
    #71
    toppdawg
    Josh
    Jackson, TN
    2012 TRD Sport 4x4
    Anyone have any ideas on how to fix this?
  12. May 14, 2016 at 6:15 AM
    #72
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I'm almost certain the fix is a new leaf pack. The "taco lean" is a none issue that only gets exemplified when doing the AAL.
  13. May 14, 2016 at 7:21 AM
    #73
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    I think you are on to something.
  14. May 14, 2016 at 8:25 AM
    #74
    toppdawg
    Josh
    Jackson, TN
    2012 TRD Sport 4x4
    The length is the same from front to pin hole and rear to pin hole.
  15. May 14, 2016 at 9:12 AM
    #75
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I didn't. My body shop did.
  16. May 14, 2016 at 9:16 AM
    #76
    VLocos24
    He wants to make sure your driver leaf is the same length as your passenger leaf
  17. May 14, 2016 at 10:18 AM
    #77
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Yes, your 4 year old single aal is shitty. Either your stock leaf pack or your aal on one side is shot. You can try a new aal, but if your leaf pack is flat on one side that won't help. The only other option would be a new leaf pack.
    Edit: And if that doesn't work, I'm not sure what the problem is. You might have a bigger issue.
    Anderson likes this.
  18. May 14, 2016 at 10:19 AM
    #78
    deeezy
    Dana
    Hawaii
    Did you even try loosening and retorquing the leaf bolts while the truck is sitting on it's own weight at ride height?
  19. May 14, 2016 at 2:42 PM
    #79
    toppdawg
    Josh
    Jackson, TN
    2012 TRD Sport 4x4
    Not yet. I'm assuming I just leave the truck sitting on level ground and then loosen all 4 bolts from the ubolts. Then retighten them down.
  20. May 14, 2016 at 3:54 PM
    #80
    toppdawg
    Josh
    Jackson, TN
    2012 TRD Sport 4x4
    I loosened and re tightened the ubolts and now the drivers side is only about a half inch higher than the passenger side. Still visibly uneven but it is better.
