Uneven Ebrake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by styran, Jul 12, 2024.
  1. Jul 12, 2024 at 11:00 AM
    styran
    styran [OP] Active Member
    Eugene, OR
    2006 Prerunner TRD-Off Road 1GR-FE 6speed
    The e-brake does a very poor job at holding the truck still on hills.
    Upon taking out the cup holder, one of the wheels' e-brake cable has a lot more slack than the other.
    How do I fix this?
    Here a video of what I am taking about:
    https://youtube.com/shorts/58n6Y2o2TUE?feature=share
    With the rear axle lifted, and e-brake re-adjusted and applied, left wheel is locked and right wheel spins freely (bad).
    06 Prerunner V6 6 speed
  2. Jul 12, 2024 at 2:04 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    See that nut on the center/forward cable? You can adjust the e-brake tension by tightening that nut.
  3. Jul 12, 2024 at 2:09 PM
    styran
    Eugene, OR
    already did that as mentioned in the post. zero improvement
  4. Jul 12, 2024 at 2:11 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    If you've run out of adjustment, I'd bet your cables are stretched and it's time for new ones. You can likely get by on just the rears or in your case, possibly even just the right one but I'd do both and call it good for another 20 years.
  5. Jul 12, 2024 at 2:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are both rear brakes properly adjusted?
  6. Jul 12, 2024 at 2:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you checked to see if the cable is broken where it goes into the back of drum?
    It's common for the cable sheath to break there. If it has, you are fighting a loosing battle.
    Jimmyh likes this.
