Uneven Front Brake Wear, 1st Gen, 4wd
Discussion in 'Technical Chat' started by mltitlntd, Feb 25, 2012.
  1. Feb 25, 2012 at 10:13 AM
    mltitlntd
    mltitlntd [OP] Well-Known Member
    Steven
    New Orleans, La
    99 Tacoma 3.4 V6 4WD SR5
    None
    Just changed the front brakes and rotors on my '99 Taco 4wd cause the right side was grinding. Did the right first, and as expected the pads were down to metal. When I got to the left, I saw that I still had a fair amount of friction material left on each pad. I also noticed that the right rotor was also more worn down on the side that had not yet made metal contact. In any case, I renewed rotors and pads on both sides. I've included a couple of pics.
    Anyone have any ideas as to why the uneven wear?
    Thanks!
  2. Feb 25, 2012 at 10:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    bleed the brakes and see if it helps? :notsure:
  3. Feb 25, 2012 at 6:23 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    Was the worn out pad on the inside or outside? Did your truck pull bad to one side when braking? Did you lube everything when you put the new pads on?
  4. Feb 26, 2012 at 7:59 AM
    mltitlntd
    Steven
    New Orleans, La
    None
    Of course we are talking about last time i did the work, so I don't remember exactly what I did. This time I lubed the pins, though I realized after getting the pads and pins in place I didn't lube the pad ends, where they ride on the calipers. In another thread, I read that if the pins are not smooth, that can cause the pads to stick. It never really pulled to one side. Worn pad was on the outside.
  5. Feb 26, 2012 at 9:34 AM
    Rmesa1
    Rmesa1 Well-Known Member
    Do you drive hard into corners the floating rotor design will allow the rotor to shift on hard turns and cause outer pad wear. Also a loose wheel bearing can cause this issue
    mltitlntd[OP] likes this.
