Uneven Rake!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jareds Toyota, Dec 23, 2013.
  1. Dec 23, 2013 at 7:21 PM
    Jareds Toyota
    Jareds Toyota [OP] Well-Known Member
    Jared
    Washington
    2008 AC TRD Sport
    After installing 5100s and setting them at 1.75 and adding a 1.5 inch aal in the rear, I have noticed that the passenger side has more rake than the driver side. I also realized after installing the lift that the end of the coil (where it sits in the spring perch) is facing forward on the passenger side, while on the drivers side it is facing the rear. Could this be the problem? Or is it something with the aal..? Thanks for any input!!
  2. Dec 24, 2013 at 4:33 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Define rake,
    Front end lower that rear or rear lower than front?
    Either way make sure the springs are on the correct side. Some springs have a passenger and driver side. Same goes with the rear. They should have some kind of cokor marking on the to tell it apart. So might wsnt ti double check
  3. Dec 24, 2013 at 10:42 AM
    Jareds Toyota
    Jared
    Washington
    2008 AC TRD Sport
    Rake as in front end lower than the rear. I know the springs are on the right side. It is the drivers rear that is noticeably lower than the passenger rear.
  4. Dec 24, 2013 at 11:46 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    What are your measurements? The "taco lean" isn't unusual in these trucks. The fuel tank is on the back driver side, so with a full tank you will lean a tad towards that side.
  5. Dec 24, 2013 at 11:52 AM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    taco lean would mean more rake on the driver's side due to additional weight on that side. sounds like you have reverse taco lean.
    when you say more rake on the passenger side you mean the angle is greater on that side, right?
  6. Dec 24, 2013 at 12:02 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    "It is the drivers rear that is noticeably lower than the passenger rear."
  7. Dec 24, 2013 at 1:52 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    driver's rear billy set different than the rest?
  8. Dec 24, 2013 at 1:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    On flat ground , what are the hub to fender measurements in on all 4 points ?
  9. Dec 24, 2013 at 6:08 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The rear Bilsteins aren't adjustable. Only the fronts.
    You're going to have some difference in the height. How much difference between the 2 sides are you talking about? I've always had some difference on my trucks.
  10. Dec 24, 2013 at 9:27 PM
    Jareds Toyota
    Jared
    Washington
    2008 AC TRD Sport
    These measurements are on flat ground from ground to fender. Sorry OZ I did it previously in my garage and recorded it.
    LF:37
    RF:37.25
    LR:38.75
    RR:39.5
    This is with a half tank of gas
  11. Dec 24, 2013 at 9:29 PM
    Jareds Toyota
    Jared
    Washington
    2008 AC TRD Sport
    I know it doesnt sound like much, but with a full tank of gas it is even more noticeable. I have seen people report the rear to be off by a quarter inch, but not any more than that
  12. Dec 24, 2013 at 9:31 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    Do from hub center to fender.. Even on "flat ground" the measurements can be thrown off by a number of things, but the hub to center measurement will account for most of them..
  13. Dec 24, 2013 at 9:42 PM
    Jareds Toyota
    Jared
    Washington
    2008 AC TRD Sport
    Okay, Ill take the measurements tomorrow when I put my truck in the garage again. I guess tire pressure will affect those measurements...
