Uneven Wear on Back Tire
Discussion in 'Wheels & Tires' started by HSmith_11, Feb 15, 2018.
  1. Feb 15, 2018 at 12:44 PM
    HSmith_11
    HSmith_11 [OP] Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I noticed the other day that my back passenger tire is wearing considerably more in the middle than all my other tires. What’s the fix? I was thinking it’s the tire pressure and I could also do a tire rotation soon.
  2. Feb 15, 2018 at 12:48 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    your tire pressure is too high
    outlawtacoma likes this.
  3. Feb 15, 2018 at 12:49 PM
    HSmith_11
    Hunter
    Madison, Va
    That’s what I figured. Any idea what I should be running close to? I have 33x12.50r15 KO2s. I’ll probably just match the other rear tire.
  4. Feb 15, 2018 at 12:51 PM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    Look on the inside of your drivers side door, where the latch is, should state tire pressure there.
    outlawtacoma and HSmith_11[OP] like this.
  5. Feb 15, 2018 at 12:51 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    I usually run about 35 in my front tires and 31-32 in my rears which seems to give me best wear.
    Keep in mind I have a 3rd gen (heavier truck) and a couple hundred pounds in the bed at all times
  6. Feb 15, 2018 at 12:53 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Meme revival
  7. Feb 17, 2018 at 9:15 AM
    HSmith_11
    Hunter
    Madison, Va
    I just checked and altered my rear passenger tire. I dropped it to 29 psi (from 32-33psi) to match my other rear tire. So, should I get my tires rotated soon since my fronts still have a good amount of tread and I haven’t rotated them for a while (but I’ll check for confirm).
