uneven wear on nitto grapplers?
Discussion in 'Wheels & Tires' started by gupster88, May 31, 2010.
  1. May 31, 2010 at 7:16 PM
    gupster88
    gupster88 [OP] Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    i have some 265/70/17 nitto's on stock sport wheels, .85" lift on the front. i noticed the other day that the outer tread is wearing more than any part of the tread on the front tires. so i first thought my alignment was off, took it in to sears since the alignment is still under warranty.
    he put it on the machine, printout came back perfect within specs. nothing out of specs or extreme. he said being that it is an aggressive a/t tire it might wear unevenly. i know that is true but would that account for an uneven wear like i stated earlier??? anyone with nittos have this same problem?
    Also, i am rubbing at when i make hard turns at low speeds. it doesnt have to be full lock to rub either. thought 265/70's did not rub???
  2. May 31, 2010 at 7:17 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Rotate them every 5k miles at a minimum. otherwise they will wear unevenly.
  3. May 31, 2010 at 7:20 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have some Nitto DG's and they wear out evenly. I rotate them about every 5K.:cool:
  4. May 31, 2010 at 8:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Post your alignment print out...They may say "Specs", but if its not right, the tires will weear.
  5. May 31, 2010 at 8:10 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    Ill post my specs tomorrow. Im at work right now. I only have 3k on these tires. Havent even put enough miles on them to have to rotate.
  6. May 31, 2010 at 8:12 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Too much positive camber.. Tires shouldnt wear like that if the alignment is in 'spec'
  7. May 31, 2010 at 8:47 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    Thats what im thinking too!
  8. May 31, 2010 at 8:50 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    something isnt right
  9. Jun 1, 2010 at 5:24 AM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    Ok here are my alignment specs:
    FL CAMBER: .06
    FR CAMBER: .08
    FL CASTER: 2.1
    FR CASTER: 2.6
    FL TOE: .02
    FR TOE: .04
  10. Jun 1, 2010 at 3:12 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    the specs seem to be pretty good imo
  11. Jun 2, 2010 at 6:32 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    Bump. Anybody have an idea?
  12. Jun 2, 2010 at 6:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Those specs are good, but the only thing causeing un even wear is the alignment. When was the last it was done?
  13. Jun 2, 2010 at 6:38 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    How about tire pressure?
  14. Jun 2, 2010 at 6:40 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    if it's warn in the middle your tires are over in flated, if the edges are worn it's under inflated....i think:eek:
  15. Jun 2, 2010 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. But if its one side, or the other, its alignment.
  16. Jun 2, 2010 at 7:06 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    Alignment was done in march by Sears. Barely 3000 miles on them since then.
    Sensors havent came on. any idea what is a good pressure for the nittos?
    Its on both front tires, edge of the outside tread only. which originally made me think too much camber but obviously not.
  17. Jun 2, 2010 at 7:11 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    i think 32psi front and 34 rear is good... or vice versa. but it may vary for nitto tg's
  18. Jun 2, 2010 at 7:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  19. Jun 2, 2010 at 7:30 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
  20. Jun 2, 2010 at 7:34 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Mine are wearing good.. I rotate every 5k. I wouldn't not take my truck to sears... I heard too many horror stories. G/L
