Uneven Wearing
Discussion in 'Wheels & Tires' started by Srf4life858, May 4, 2011.
  1. May 4, 2011 at 9:37 PM
    Srf4life858
    Srf4life858 [OP] Well-Known Member
    Kevin
    2010 Toyota Tacoma
    2 12" md subwoofers, GrillCraft Billet Overlay Grill, Billstein 5100's, WickedFlow Muffler, debadged, Anti-theft Tailgate Mod, HIDs, 16x8 raceline wheels, BF Goodrich ALT tires, CB Radio, 4 Hella 500s, Lightbar, HIDS, Window Tint, Camburg UCA
    I currently have stock wheels and tires on my sr5 2010 Tacoma along with Billstein 5100s. However my tires are wearing uneven, even though I have had my wheels aligned before. Does this mean I need a new UCA?
  2. May 4, 2011 at 9:39 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    means your alignment is off. what are your 5100s set at. what pressure you have in the tires.
  3. May 4, 2011 at 9:40 PM
    Srf4life858
    Kevin
    2010 Toyota Tacoma
    They are set at the highest setting, I do not know my tire pressure off the top of my head. Should I lower the height of my shocks then?
  4. May 4, 2011 at 9:41 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah, sounds like your alignment might need to be redone.
  5. May 4, 2011 at 9:41 PM
    Srf4life858
    Kevin
    2010 Toyota Tacoma
    My left tire (front passenger) is balding on the outer portion while on the right side ( front driver) is not.
  6. May 4, 2011 at 9:45 PM
    Srf4life858
    Kevin
    2010 Toyota Tacoma
    Thank you for this info!
  7. May 4, 2011 at 9:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Only issue I have with that link is the "Feathering". Feathering is normal for steering tires, and is common if tires are not rotated in a timely mannor.
  8. May 4, 2011 at 9:48 PM
    Srf4life858
    Kevin
    2010 Toyota Tacoma
    When I eventually get new larger tires, should I consider buying an aftermarket UCA?
  9. May 4, 2011 at 10:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A good alignment tech can get it close....aligned twards the max ends of the spectrum, but to get it perfect, UCA's are a good choice.
  10. May 5, 2011 at 7:28 AM
    Srf4life858
    Kevin
    2010 Toyota Tacoma
    I am getting my oil change down today, I will ask Toyota to align it because I don't know of any good alignment techs.
